Question about Hotpoint HSS25GFP Side by Side Refrigerator
My fridge knocks when running
Pops and knocks loudly when running
  • Glenn L Apr 14, 2015
    Happens usually at night, and i mean loud intermitant popping of different intensity. Sounds like it's going to spit like a volcano any minute. Been like this for a liittle over 2 years (after moving in). Still holding temp fine in both freezer and fridge section. It's a side by side configuration. Has water and ice maker, but only use ice maker in freezer section. Working like it should but just waiting for the day it gives out. Is it worth repairing? I'm a d.i.y. guy, just tell me. Don't know the age/model (even though i used a number in above heading, i am not sure) because the info tag was ripped off inside! Thanks in advance!
  • Hotpoint Master
  • 5,323 Answers
Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts).
It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an 8-10 hours is more than enough time some say less.
the internet consensus seems to be that you should limit the amount of time the unit is not upright. And as stated above, leave it upright at least overnight before starting it. Apparently damage can arise from mixing of lubricant and coolant, so damage is more likely in an older unit with worn seals.
Posted on Apr 21, 2015
Why is my 2002 Mazda Tribute making a loud knocking noise when I start it
loud knock and for how long
is it a diesel or petrol
broken engine mount
loud tapping is tappets ..should go away once oil reaches top of motor
water pump or bearing something running off drive belts
if high milage engine
a loud knock at engine revolution or half revolution
big end bearings or
piston slap or gudgeon wear
Oct 07, 2016 | Mazda Cars & Trucks
Knocking rattling noise from engine appeared while driving loss lil power running but loud knocking in engine
You didnt state vehicle however if the engine knocks the knock sensor will back off the timing thinking its detination not an actual knock if its knocking loudly stop driving it, something is going to let loose
Oct 06, 2015 | Cars & Trucks
What makes my truck knocks when i cranked it up a loud pop sound and then it started knocking
comment on petrol or diesel
in any case have a compression test done to check for mechanical failure
Sep 25, 2015 | 2008 Ford F-150
Very loud noises
Check the rubber mounts under the compressor and look for any lines touching the sides of the cabinet. The gurgling and clunking are often normal. good luck. Roger
Jan 19, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Briggs& Stratton 14.5 starts and runs. Has a loud knock. This did not begin a while back then get worse, it simply started out loud and is still loud. I was certain it was a connecting rod so I bought a...
The loud knock can mean that the connecting rod bearing may be going bad. The engine should be torn apart to see if this is the problem. The lobes on the camshaft should also be checked as well.
Sep 20, 2013 | Craftsman Garden
Loud knocking as engine is running
if is realy loud is coud be the piston the engine needs to be checked bt am 80% is that
Jan 08, 2013 | 2000 Ford Excursion
I purchased a 2007 Aura XR. 3.6 L a month ago. The car only has 23,000 miles on it. I've been noticing a weird knock noise in the rear of the car while sitting stationary in park or in drive. It's...
I have a 2007 Saturn Aura with 3.6 L engine. Had it since new (now at 55,000mi) Here is what I found that may be what you are experiencing. Particularly in cold weather, after about 5 minutes of running a sharp "pop" occurs. Usually I just have one loud pop. I believe this is something in the exhaust system that expands and pops much like a cookie sheet put into the oven. As best I can tell, this is a harmless noise. As the car has gotten older it does this less frequently.
Dave K.
Dec 12, 2011 | 2007 Saturn Aura XR Sedan
2001 isuzu tropper 3.5l 4x4 engine runs but loud knock changed oil and still has loud knock can i just change the oil pump or do i need to change whole engine
If you are hearing a loud "knock" and it is coming from the bottom of the engine you probably have a bad crankshaft bearing(s) which means engine rebuild or replacement.
Feb 19, 2011 | 2001 Isuzu Trooper
Load knocking noise
these high efficiency compressors make noise when they are in defrost..you will sometimes hear water running, or tapping noise or even a popping noise. if it happens when its off in defrost.. it will only happen three or four times per day as this is the defrost frequency and nothing can be done without securing the heat exchanger to the suction line ..sometimes these come loose...
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
150 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
