Question about Amana Kitchen Ranges
Where can purchase door hinges part32052801 - Amana Kitchen Ranges
    Problem Solver:
  • 5 Answers
W.l.may company on 7th and hawthorne blvd. Portland,Oregon
Posted on Apr 13, 2015
    Top Expert:
  • Amana Master
  • 10,875 Answers
WHP 32052801
they have it
  • Amana Master
  • 932 Answers
Arthur,
I checked two websites that I normally go to and they both say the part is unavailable. I usually check Sears parts direct and repairclinic.com. Sorry, the only thing that I can suggest is to Google it and see if there are any small dealers that might have it still in their inventory.
Why door hinge popping noise
Hello friend, thank you for your inquiry!
I see your door hinge is making a popping noise on your Frigidaire refrigerator. It sounds like the door hinge may need to be replaced or the door could use an adjustment. I would recommend contacting a professional to come out to diagnose the appliance to avoid any unnecessary part purchases. I hope this helps. -Matt
Sep 06, 2014 | Frigidaire FRS3R5EMB Side by Side...
How do i get squeaking door to stop kenmore
Can you be more specific with the description? Where? Top? Bottom?The best solution is to identify if the alignment is correct. If the alignment is good, look at the hinges for excess wear. If there is no sign of the hinges being worn, needing replaced; apply some light oil, "Three in One Household Oil". This will only take 1 or 2 drops in the pivot point of the hinge. If the alignment needs adjusted the hinges will need moved. You will need the tool (whatever is used by the manufacturer) and something to block the door. Purchase new hinges if they show wear. Loosen or replace the hinges, position the door in the desired position, tighten the hinges securely, careful not to strip out the threads. Check the door function and alignment make adjustments as needed.
Mar 16, 2013 | managemylife.com
Oven door will not close the whole way
Your oven door hinges(s) are broken, the springs that hold the door closed inside the hinges are either weakened or their mounting points have become worn.
You need to purchase a pair or replacement hinges which you can fit yourself if you have some basic mechanical skill. Don't try to just replace one side if you determine which side has failed as the extra strain put on the old hinge can cause the door to twist and break the door.
Mar 05, 2012 | Tappan Kitchen Range
Can I buy a new door. Current door is cracked on the corners.
You easily replace the door on most microwave ovens by opening the door all the way up and lifting straight up at the hinges. The door should lift off of the hinge pins. On some microwave ovens, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
There are several parts sources available that you can may try to purchase replacement parts:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer helpful exploded view parts listings to aid in parts identification and location. Just type in your model number and locate the parts listing for the door. Some manufacturers only sell the door as a complete assembly. Others may sell individual parts. To save money, you may also try just purchasing the door facing parts that are cracked. If you have any questions, or require additional assistance, please post back with your complete MODEL NUMBER and let me know. I hope this advice is helpful.
Dec 16, 2010 | General Electric Microwave Oven
Repair door sag on a Chevy Suburan
The door hinges have pins in them. The pins have bushings in the hinge. If you go down to your local parts parts store you will be able to purchase them. They are brass colored. You will need to unbolt the doors and use a punch to hammer out the bushings and use a hammer to replace them.
Jan 09, 2010 | Chevrolet Suburban 1500 Cars & Trucks
Parlaiment hinge problem
Yes the hinges are faulty take them back and exchange them at the hardware store you purchased them at.
Sep 13, 2009 | RTO M-D Building Products Carpentry &...
Door does not close tightly. If I lift door it
If the hinges aren't too worn, you can sometimes loosen the screws (just loose, don't remove) that hold the hinges to the case of the frig, have someone lift the door by the handle.
Have them lift it firmly while you retighten the screws for the door. Your door may fit better and it's a quick fix.
If the hinge is getting worn, you can purchase replacement parts. Check at repairclinic.com ...they have a huge selection and the parts can be matched to their photos... great help when making sure they're correct.
Best of success on this.
K
Aug 29, 2009 | Amana Refrigerators
Volvo 2002 s60 fuel door
My guess is that the hinge clips are broken - it's hard to see how it works after the clips are broken off. I purchased and installed a replacement hinge from Myswedishparts.com. I emailed asking for help and they provided direction, but it's pretty easy. Use a small punch to drive the centers out of the plastic attachement pins to get the old hinge off. Replace the hinge, press the center pins in and re-attach the door. There was a drawing on the referenced web site when I replaced mine, but I just looked and didn't see it. I'm sure there are many places to purchase the replacement hinge - that's just where I bought mine.
May 28, 2008 | 2002 Volvo S60
Kitchen Ranges Logo
97 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
