Question about SmartDisk USB Floppy Drive Titanium Edition (FDUSB-TM2) External Floppy Drive
Need driver for windows 7
Do I need new driver to use with windows 7 upgrade
    Top Expert:
  • SmartDisk Master
  • 43,030 Answers
Quite likely you need to buy a new external drive as I did when I got these new laptops . old drive was not supported by the mfg.
Posted on Apr 11, 2015
Ethernet driver for windows 7
There does not seem to be a valid Windows 7 network driver:
http://ftp.dell.com/Pages/Drivers/dimension-3100.html#Network
You can try the driver for XP to see if that will work, otherwise you may need to buy a new NIC card.
Oct 14, 2013 | Dell Dimension 3100 PC Desktop
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
I have a HP m1160n, I installed windows 7 an II need three drivers. TV tuner, audio and ethernet. Any help?
Hi there
Sorry to hear you have a problem. Did you install windows 7 as an upgrade? If so, did you run the upgrade advisor before you upgraded? If you installed it as a new clean Operating System, did you check to see if your HP m1160n has drivers that will work with windows 7? I just went to the HP website to check for your drivers but it does not recognise the model you state M1160N. Go here http://welcome.hp.com/country/uk/en/support.html and put in all the numbers of all the stickers on the case or that look like HP. These maybe serial number, part number, model number, spares number until you get a match for M1160N. Then check to see if your drivers are available for Windows 7. If they are not you will need to install seperate new audio, network and TV tuner cards that er compatible with Windows 7.
All the best, Phil
Dec 04, 2010 | HP M1160N PC Desktop
Drivers
I will recommend that you download and run the free Windows 7 Upgrade Advisor. It helps find issues with your computer’s hardware, devices that might affect installing Windows 7. Go to the Windows 7 Compatibility Center find direct links to drivers, updates, and downloads.
Apr 04, 2010 | Toshiba Satellite A300-ST6511 Notebook
I have a HP Pavilion tx2620es with Windows Vista 32bits working perfectly, i buy Windows7 Upgrade Kit from HP, so i installed it and all sort of problems became: -Rotation of screen has stop working -Touch...
TRY TO DO CUSTOM/CLEAN INSTALL OF WINDOWS 7, BUT BEFORE INSTALLING IT DOWNLOAD WINDOWS 7 upgrade advisor , HERE IS THE LINK http://www.microsoft.com/downloads/details.aspx?FamilyID=1b544e90-7659-4bd9-9e51-2497c146af15&displaylang=en RUN IT ON VISTA TO MAKE SURE WINDOWS 7 IS ABLE TO BE INSTALLED ON YOUR PC. BECAUSE WINDOWS 7 IS NEW OS IT MIGHT GIVE YOU MORE TROUBLES ON TABLET PC`s, MICROSOFT STILL UPDATING THEIR DATABASE FOR CORRECT DRIVERS FOR WINDOWS 7, ANYWAYS , I`LL SUGGEST YOU RUNING UPGRADE ADVISOR ON VISTA.
Mar 09, 2010 | HP Pavilion Tablet Notebook
When we try upgrading xp to windows 7 the upgrading failed because our cpu is old can i upgrade my xp to windows 7 using a old cpu or use a new cpu
NO you cannot, on that same computer, no matter what OS, because, you MUST change your central Processing Unit, CPU. To allow Windows 7 to work correctly.
Feb 07, 2010 | Microsoft Windows XP Professional
Want to update p200 1JV t windows 7 from vista 32
Download and run the upgrade advisor from here to see if you will have any problems.
http://windows.microsoft.com/en-GB/windows/downloads/upgrade-advisor
Jan 01, 2010 | Toshiba Computers & Internet
I upgraded my system from windows XP to windows 7 32 bit and sound card is not working
leobard_orn
In regards to your sound not working in Windows 7 I can tell you that Windows 7 does handle audio differently then XP did. So you will need to go to the sound card manufactures web page to get the updated drivers for Windows 7. If it is intergated on the motherboard you will need to go to their site to get the audio driver. Note since Windows 7 just came out they may not have a driver yet. However in most cases the Windows Vista drivers would be the same so if the only have Windows Vista drivers you can try them.
Hope this helps
Issken
Dec 31, 2009 | EliteGroup K7SEM Motherboard
SmartDisk USB Floppy Drive Titanium Edition (FDUSB-TM2) External Floppy Drive Logo
891 people viewed this question
Top SmartDisk Computers & Internet Experts
terminalcon
Dennis Crouse
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
