White line vertical on every hanel - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,417 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Apr 12, 2015
Why come white vertical line on my t.v screen in center?
You said "I checked vertical output line from main ic pin 23 found correct"
But the problem is "Horizontal Output Line" Try that.
Jan 29, 2015 | LG Televison & Video
Xerox workcentre 4250 vertical white line
This could be a developer tank problem. What colour does the white line show up in?
Investigate that colour.
Good Luck.
Aug 08, 2014 | Xerox Workcentre 4250/SM Laser Printer,...
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
Got white vertical lines on left side of display
Vertical lines on an LCD screen are not a good sign. This usually means that your screen is going bad.
Jul 21, 2010 | Toshiba Computers & Internet
One day my tv started having white lines in various places, then one day the scrren went white but still has a small line across the top that works fine
The problem is "Vertical Over-drive" and the white lines are vertical retrace lines. What has happened is a component failure between the vertical oscillator and the vertical driver circuit. The component is usually a capacitor that is leaking and allowing voltages to appear where they shouldn't be.problem component is leaking and allowing DC voltages to appear where they don't belong. It's causing the vertical driver transistor to run "flat out" and will ultimately burn out the transistor from internally generated heat.
Hope this help....
Jun 18, 2010 | Televison & Video
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Picture has white horizonal line accross it
You have a vertical collapse. Not sure if its worth fixing because i don't know what type of set it is or how old. But vertical is not usually expensive to fix. Possibly just replace vertical ic
Apr 22, 2009 | Televison & Video
VERTICAL WHITE LINES
I just read a post that said tap on the top and the line will go away. I tried it on mine and it worked! I had to tap it fairly hard. I just kept tapping harder and harder on the plastic in front of the buttons and voila! The vertical white line disappeared!
Oct 07, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
