I have no remote for my unit . How can I manually access the menu to adjust the settings?
    Top Expert:
  • Televison & ... Master
  • 51,191 Answers
You could spend 12.00 for a remote
Posted on Apr 11, 2015
  • Stevens Briceno
    Stevens Briceno Apr 11, 2015
    I obviously know that but I asked about manually because I already. Bought a universal remote and the menu button doesn't access the TVs menu
3 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: Menu
to acess the menu push the channel up button and the volume up button on the front panel or the channel down and the volume down.and the menu will appear.but you can get the originald remote at www.partstore.com good luck
Posted on Mar 26, 2007
  • 979 Answers
SOURCE: Need access to service menu to adjust vertical size
No service menu for this set. Sounds like you have a bad yoke winding on this one....accordianman
Posted on Oct 20, 2007
KV-x2162u lost remote
To access the picture settings menu, you must have a remote control. There is no Menu button on the front of this TV to select inputs.
Dec 26, 2012 | Televison & Video
Panasonic CT 27 SL - 13 GL how to connect external speakers
This TV is set up to connect to an external amplifier which that controls the speakers. It has an analog audio output which means you need an RCA audio cable (2 RCA plugs (red and white) on each end. You can't directly connect a set of speakers. The audio output jacks at between the antenna in and the video inputs. Then you need to enter the menu and enter the Audio submenu. Go to the Speakers item. Turn the TV speakers to off and fixed audio out.(The amplifier will adjust the volume.) Use the Up/Down arrows to navigate through the menu options, press enter to enter a sub-menu and the volume up button to change a setting.
There is also a headphone jack which may be compatible with computer speakers. That has a 3.5 mm jack. To use headphones, set the Speakers Audio item to TV speakers Off and variable audio out. (The TV controls will adjust the volume.)
To use a Universal remote to set the audio or modify the channel list, you need one that matches the Menu function of the original remote. You may need to try multiple codes for Panasonic TVs to get the button to work. Some low-end universal remotes may not have the menu button; get a different remote or use the menu button on the front panel of the TV.
To set the channel list, press Menu and select Setup. Go to the Prog Chan option. Then set your Mode in the first option (Cable or Air). Then choose Auto Program to scan all channels or Manual Program to edit the channel list.
The manual for the TV is available at retrevo: http://www.retrevo.com/support/Panasonic-CT-27SL13-TVs-manual/id/275ag210/t/2/ . You will need to enter a code to access the manual. See page 5 of the manual for the input connections (page 7 of the PDF).
Sep 13, 2012 | Panasonic Televison & Video
How do I adjust the color, brightness, contrast etc using this remote
go to the manufacture website and look up your model of remote. Then program your remote to the tv. If you have done this then this next part is just for you. Usually u can adjust all the tv settings from the menu button. Be sure you are on the right input and AV setting if you can not access these settings then either go to manual operation or follow up with manufacture specs for your tv
www.eliztech.com/remotes/ge-howto.php
May 30, 2012 | GE Televison & Video
Hello I was wondering how to use the VM acess with my phone. I want to be able to call from a different number and listen to my messages how do I go about doing so
I have a similar model. You need to configure a remote access code on the phone. Then, when you call your phone, you enter the pin after your message starts.
(From the manual)
Using a touch-tone phone, you can call your phone number from outside and access the unit to listen to messages or change answering system settings. The unit's voice guidance prompts you to press certain dial keys to perform different operations.
Remote access code:
A 3-digit remote access code must be entered when operating the answering system remotely. This code prevents unauthorized parties from listening to your messages remotely. The default
setting is "111".
Important:
To prevent unauthorized access to this product, we recommend that you regularly change the remote code.
1 {MENU} {#} {3} {0} {6}
2 Enter the desired 3-digit remote
access code.
3 {SAVE} {OFF}
Below is a link to the manual. The remote access instructions are on page 35.
http://static.highspeedbackbone.net/pdf/KXTG4031-MUL.pdf
Mar 05, 2011 | Panasonic KX TG4031 Cordless Phone
I have a panasonic PV-M2768 and i don't have the original remote. I have a RCA universal RCR312W. I have tried all codes I can find. (interesting side note: the remote manual says to enter a 4 digit...
Universal remotes are a very limited devices for a replacement of a remote.U get the tv for power on/off,channel up/down and volume up/down,the basic that all u will ever get it out of the universal remote.No button said Menu on the front of the tv for acessing tv Menu,than sorry no combination of buttons,will help u to access the tv Menu.Sorry,but now,u must buy the tv original remote.Try website like Remotes.com to buy an original remote.
Mar 03, 2011 | Panasonic PV-M2059 Combo
Cant set clock or access menu using universal remote
Haven't found answer to that, but there is a remote contol specifically for your unit now on EBAY at http://cgi.ebay.com/SHARP-VCR-RRMCGO173AJSA-Remote-Control_W0QQitemZ350117240995QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116. The whole thing is under $10 including shipping. If nothing else, copy the model # of the remote and you might be able to find it cheaper someplace else.
Dec 04, 2008 | Sharp VC-H973U VHS VCR
Hitachi onscreen menu access
Afraid only the original remote will fix this. All universals and aftermarket remotes will not have the function you need. try going here www.vancebaldwin.com and use there remote finder and see if they have the one you need
Feb 26, 2008 | Televison & Video
Accessing menu without a remote
You will need to get an original replacement remote or the original to access the menu. An original replacement remote for this TV set is not cheap! You can see what you need here
http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=SDP50A5K&brand_pn=PIONEER_SDP50A5K&mode=large&uid=11944400246090
Good Luck
Nov 06, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
On screen display menu
I scratched my head over this for an hour. The manual says you can access the OSD from the unit, but I see no way to do this. From the remote, you have to select the "AMP" setting at the top of the input list. Then hit the OSD button. Assuming your monitor is set up correctly, this will bring up the On Screen Display. Then hit the "Menu" button also on the remote, and you can make your adjustments. Good luck!
Mar 06, 2007 | Marantz SR-7200 Receiver
Oct 25, 2006 | Emerson SpongeBob SquarePants TV
Televison & Video Logo
Top Televison & Video Experts
