Question about Bush DVD2038 DVD Player
The drawer will not open. I get error no disc. There is not a small hole underneath drawer that a paper clip can open up the drawer.
How do I get the CD drawer to open?
Normally, there is a small hole located below the disc drawer that you can put a straightened paper-clip in to open the drawer.
Feb 02, 2015 | Audio Players & Recorders
American idol karaoke machine has stuck drawer. There is no manual release hole to put a paper clip into. CDG trapped plays..
Take out the cd mech, look underneath for a wheel at the front which shoud have a small belt on, turn this with your finger til the disc becomes unclamped and the tray opens
Apr 02, 2014 | Audio Players & Recorders
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Feb 01, 2014 | BenQ FP91G+ 19" LCD Monitor
Opening cd player
What about opening the cd player?
Are you saying the cd drawer will not open when you push the button? If so, try the steps below.
Take a paper clip (Gem Clip) and straighten it out then get in front of the cd drawer where you place the cd. Look for a small tiny hole on the drawer and insert the paper clip (Gem Clip) into the tiny hole and push it in while you press the button on the drawer. Don't worry about breaking something, use a little force to push the paper clip in, that's why that hole is there.
May 31, 2012 | Samsung Computers & Internet
The disc-tray on my computer tower-block (where you insert discs) is not opening at all. It makes a noise when you press the 'eject' buttons as if it is trying to open, but it never does....
Its either got a disk jammed or the mechanism is slipping.
Look at the drive bezel, just underneath the drawer, you should see a small hole. Straighten out a paper clip and push it into the hole, quite firmly. The draw should open. This is the failsafe procedure for opening such drives.
With luck, you drive should operate normally after this.
Jun 25, 2011 | Computers & Internet
My CD writer will not open to insert the CD. What
Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. Straighten the paperclip and insert it into the manual release hole until resistance is felt.
Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
Remove the paper clip and gently pull out the drawer until the disc is accessible.
Mar 08, 2010 | BUSlink (RW4848FM) CD-RW Burner
The disc drawer will not open. How can I get it
There will be a small hole in the front tray of the DVD, use a straightened paper clip, or similar stiff wire, & push it into the hole and gently push in, until you hear/feel a "Click" gently keep pushing 7 it should now come open,
Feb 17, 2010 | Memorex MVD2042 DVD Player
The radio with a 6 disc changer stock wont eject cds in my 2001 ford windstar van with double sliding auto open/close doors
Hi
Thanks for using FixYa. Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Use a stiff wire, a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open and remove the CD.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 04, 2009 | 2001 Ford Windstar
Will not eject DVD is working is stuck I think I might need to open laptop
Power down the laptop and restart it. As soon as it restarts press the open button on the dvd drive and it will open. You may have to try a few times but it will work.
Sep 29, 2009 | Dell Studio 1737 Laptop
Dvd player doesn't open disc drawer
Get a fairly strong paper clip and straighten it into a 90 degree shape
Look at the front of the DVD unit and you will see a small hole
Put the end of the clip in the hole and push
The drawer will open
If it is not doing so under power try taking out the retaining screws underneath the laptop and remove the whole DVD unit re-fit it and see if it was down to a bad connection on the rear of the unit
Let me know how you get on
Jul 05, 2009 | HP Computers & Internet
Bush DVD2038 DVD Player Logo
41 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
