Question about Janome Memory Craft 9000 Computerized Sewing Machine
How do you change the default stitch length for the straight stitch.
I have set the length I want and press and held the default button to try and change it but it will not change. The machine constantly moves from my setting to the default while I am sewing (not while I'm stitching). It doesn't actually change while sewing, when I stop stitching for a minute it goes back to the default setting of 2.0. I would like to use a stitch length of 3.5 and if I could set this as default it wouldn't switch on me. It doesn't change while stitching, but while sewing if I stop the machine for a minute it will go back to the default. It only has a default, cancel and Ok button, no Memory Set Machine is MC9500 I'm trying to set the straight stitch setting Thanks for the replies
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 42 Answers
I really would contact Janome. I don't know which stitch you are changing. Some stitches change and some don't and still there are limits for those that do.
Posted on Apr 15, 2015
    Top Expert:
  • Janome Master
  • 10,875 Answers
If you set the length and then push and hold the default button,then the machine WILL GO TO THE DEFAULT SETTING,if you set your stitch and press memory or set,then it will do YOUR STITCH
Posted on Apr 12, 2015
    New Friend:
  • 4 Answers
A setting change while you are sewing should not happen. Sounds like you will have to take your machine in for service.
I have a Singer Curvy 8780. All I want to do is sew a straight stitch. What are the settings?
You'll need stitch pattern 01 in the first group after you press the utility stitch button (top button on the left of the 4 way arrow keys). Press button A (the left most up-arrow below the LCD screen). Use buttons B (move left) & C (move right) to select the needle position and D (shorter) & E (longer) to adjust the stitch length. E is the right-hand button in the group. Start with the tension set to Auto and adjust as needed based on your fabric and thread. For normal straight seams, start with the default settings.
Singer has the manual for the Curvy 8780 on the product site: http://www.singerco.com/products/1545/8780-curvy#type-support . The direct link to the manual is http://www.singerco.com/uploads/download/089a99d1802347d9441d83e8a591e6d0db17b80c.pdf . See page 30 for the stitch pattern; page 40 starts a longer discussion of straight stitching.
I hope this helps.
May 25, 2016 | Singer Sewing Machines
What is the setting for regular straight stitching?
Stitch length @ 2.5mm (between 2 and 3 on the scale).
Stitch width @ zero.
Top selector lever @ 1 / 2 or (1 slash 2).
Needle position @ center.
That's it, no rocket science here. Stitch length will vary per application and per user choice. The 2.5 setting is only a suggested default.
Sep 22, 2015 | Bernina 1008
Babylock denim pro
I'm not sure what you've actually got, since your question mentions two different machines. Straight stitch is typically the default setting (the thing that comes up automatically) on computerized or electronic machines. On other machines, there may be an indicator for straight stitch (often stitch 0 or 1 if numbered), or it may be a zigzag stitch of width 0, length whatever.
Jan 25, 2014 | White Sewing 1418 Mechanical Sewing...
My Kenmore sewing machine model number is 17630, & when I try to set the stitch length from a Straight Stitch setting to a Straight STRETCH Stitch setting, there isn't any difference. I have the length...
Take a look at the stitch length dial. If you turn that dial counter clockwise (to about 7 o'clock), it will set to stretch stitch. Then all of the stretch stitch features will work. When you want to go back to straight stitching, just move that dial back to what ever stitch length you wish.
Nov 26, 2010 | Kenmore Sewing Machines
Inspiration 4205 stitch length won't change
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
Feb 21, 2010 | Singer Inspiration 4206
Ordinary straight stitching
When you turn on a #1 Husqvarna Viking the machine defaults all the electronic settings to do a straight stitch at a 2.5mm stitch length, that equates to approximately 10 stitches per inch. The top tension dial sets itself automatically and the only other dial is on the left side of the machine. That dial sets the pressure on the foot that holds down the fabric. It's normal setting is 6.
Sep 02, 2009 | Husqvarna Viking 1
How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Changing stitches on a White 1418 sewing machine...
I have a White 1418. Here's how you do it:
1. Attach the buttonhole presser foot (should have come with your machine) and place the fabric underneath.
2. Set the stitch length knob to 0, the zigzag width knob to 5, and set the needle position to center. Sew 3-5 stitches.
3.Change the stitch length to 0.5, the zigzag width to 2, and the needle position to left. Sew to the entire length of your buttonhole.
4.Set stitch length knob to 0, zigzag width knob to 5, and needle position to center and sew about 3-5 stitches
5. Set the stitch length knob to 0.5, zigzag width to 2, and set needle position to the right. Pressing the R button (reverse button), sew up to the top stitches.
6. Remove the fabric and open the button hole with a button hole cutter.
Sounds complicated, but it's really easy. I love this machine, you just have to know how to use it!
Sep 18, 2007 | White Sewing 1418 Mechanical Sewing...
Janome Memory Craft 9000 Computerized Sewing Machine Logo
218 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
