Question about Baby Lock Esante
Feed dogs do not pull material through machines when sewing
  • Baby Lock Master
  • 1,860 Answers
Then the feed dogs need to be checked to see if they need replaced or adjusted
Posted on Jun 03, 2015
fwadley
  • 482 Answers
SOURCE: babylock ellure feed dog will not raise
go see your local parts man. he will know what you need and he will have it there or he will need to order it.
Posted on Dec 16, 2007
  • 323 Answers
SOURCE: ESPIRE SEWING MACHINE - MODEL ESp baby lock
Take it back to where you had it repaired and ask the dealer to make it work under his warranty. Maybe he can tell you exactly what's wrong with your machine. Usually it is a pressure problem or the feed dogs are filled with lint or they don't rise high enough above the needle plate to work. Take off the needle plate and check them.
sewman7
Posted on Jul 18, 2008
  • 11 Answers
SOURCE: Feed Dog problem
I listened to all that...and none of it worked...so I took the plate off and gave it a good clean. Still nothing. If your machine's a bit old like mine or tends to get stuck...physically lift up the feed dog with your fingernail or a flat screw driver or something (once the plate is off), then push the feed dog lever across and release the feed dog. It should hold in place if nothing else has worked...woo!!! :)
Posted on Feb 18, 2009
  • 1116 Answers
SOURCE: material is stuck in the machine under the feed
Remove the needle, presser foot, needle plate, & bobbin.
Snip at the fabric and remove in pieces with tweezers - do this gently.
Posted on Feb 21, 2010
  • 5 Answers
SOURCE: fabric will not feed when trying to sew, but
Check pressure of the foot that contacts the top of the fabric. Lift the presser foot up and check there is resistance there
Martin
Posted on Feb 27, 2010
Janome Machine will not feed material !!
If the fabric is not feeding, the feed dogs are probably not operating properly. Check that they have not been dropped below the needle plate (which is done when darning or free motion quilting). In this setting, the feed dogs never rise above the needle plate to grab and pull the fabric.
The other issue could be that the feed dogs are defective or perhaps seized.
Since you did not provide a model, I can provide only this assistance. It would be helpful to locate (search for make model manual) for your machine.
Dec 30, 2016 | Janome Sewing Machines
Brother CS6000i with setting 00 for straight line stitch is making a left curve stitches instead going straight.
***Your feed dog under the pressure foot seems to be pulling on one side a little harder which indicates wear. It is likely to solve the problem by replacing the feed dog.
***Before you do this try to lower the pressure on the pressure foot. If the material you are sewing is thick it will have an effect on the pull of the feed dogs. The material you are sewing that you sent appears to be jeans material. It looks like it is thick and somewhat slippery.
Oct 05, 2015 | Brother Sewing Machines
My feed dogs will not pull my material through.
Check to be sure you have not inadvertently dropped the feed dogs on your machine. Dropped feed dogs are used for 'darning' or 'free motion quilting.' Below is info from Troubleshooting Manual:
Fabric does not feed through the machine
The feed dogs are lowered. Use the feed dog position switch to raise the feed dogs. 81
The stitches are too close together. Lengthen the stitch length. 42
The wrong presser foot was used. Attach the correct presser foot. 179
The needle is bent or blunt. Replace the needle with a new one. 34
The thread is tangled. Use scissors, etc., to cut the tangled thread and remove it from the race, etc.
Apr 11, 2015 | Baby Lock Esante
How do i get the material to feed through
depending on the brand of sewing machine you have, make sure it's not in the darn mode,, make sure the presser foot is against the fabric so the feed dogs can pull it thru,,if the presser foot is against the fabric correctly then the feed dogs may need to be check to see if they need a adjustment or replacing
Dec 02, 2014 | Sewing Machines
Singer sewing machine 1030 feed dog will not pull material in
try using maximum stitch length, if still not working try removing needle plate and clean you teeth
Feb 18, 2014 | Sewing Machines
Why do my feed dogs grap my material at the beginning of a stitch
some sewing machines have what is called a buttonhole lever that
is to the left of the needle that has to be pulled down before the
machine will make a buttonhole,here is a link for a free manual
if you dont' have one
http://www.singerco.com/uploads/download/430_8280_es.pdf
Mar 18, 2013 | Singer 8280 Mechanical Sewing Machine
Machine won't feed material. I have to pull while sewing.
First of all stop pulling that will only bend your needle and cause further problems.
Check to make sure your feed dogs are engaged. There should be a switch somewhere around the sewing area front or back or perhaps under a flat bed attachment.
Oct 28, 2012 | Singer 4423 Sewing Machine
Material doesn't move
Are the feed dogs engaged? Janomes usually have a feed dog sliding switch, either on the back of the sewing machine at the bottom, or behind the accessory case. Be sure the check it out. Hope this helps!
Aug 24, 2006 | Janome 405 Mechanical Sewing Machine
Sewing Machines Logo
111 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
