Question about Food Processors
How to remove blade? - Food Processors
  • Food Processors Master
  • 1,267 Answers
If the blade is stuck on then there is likely damage to the hole inside the blade and the shaft sleeve it fits on to so you should expect to replace both or it's going to happen again and again. Brute force is going to be the answer. I have a chain that I wrap around the blade shaft where it goes onto the motor sleeve. Sometimes I secure it with a shackle or radiator hose clip then attach the other end of my chain to my workbench and accelerate the processor motor assembly away. Chain goes tight, big thump and blade flies off.
Posted on Apr 13, 2015
Food processor blade stuck on motor shaft
my friend if you had not removed that blade for a while it will certainly stuck due to the moisture that forms on the shaft of the blade holder causing it to have corosion you will have to carry that item to be removed by a qualified tech by you doing it your self could cause damage,which could cost you more.good luck
Jun 16, 2007 | Cuisinart DLC-5 Food Processor
How to remov blades
The blade will be stuck on the shaft and both will be damaged and require replacement. With that knowledge you now understand that drilling a hole sideways through the blade cap isn't wrecking anything you are going to use again. You can then get something into the hole for leverage. Here in NZ blades are under $20 and motor shaft sleeve is about $5.
Aug 11, 2014 | KitchenAid Food Processors
Can't remove the container from the motor housing
It will be the blade holding the bowl on. The blade has become locked onto the motor shaft, in the end you are going to need to replace both. Take it to a K/A service agent.
May 22, 2012 | KitchenAid KFP750 Food Processor
Attaching blade inserts onto Farberware v-blade mandoline slicer
You don't mount the blade inserts to the safety insert. The safety insert is only for storage so that someone doesn't cut themselves. Remove the safety insert then install your selected the blade/insert you wish. When finished place the safety insert back in for - safety.
Jun 15, 2010 | Food Processors
Cuisinart DLC-7--blade stuck--cannot remove from bowl.
First off, is it a BLADE that's stuck, or a DISC?
If it's a disc, and the disc is blocking your access to the center post, put a ziploc baggie full of ice on top of the disc (right in the middle) and let it sit for about half an hour. That should shrink the plastic enough to pop it out.
If it's a blade, you can try the ice trick, or you can try Pam (or another food grade cooking spray) to loosen it up, and then just try to take the workbowl off like you usually would (aka, DO NOT grab the blade, or you'll risk cutting yourself--you can just pull up on the bowl, and the blade should pop off.
If you need further help, you can always contact Cuisinart--their phone number (according to their website, www.cuisinart.com ) is 1 800 726 0190
Good luck! :)
Aug 31, 2009 | Food Processors
How to attach grating/shredding blades to GE Food Centre FP22
When you remove the regular chopper blade, it should fit on top of the stem. The chopper blade must be removed to use the slicer / shredder attachments.
Jan 05, 2009 | GE Food Processor
How do you remove the blender blades from the ultimate chopper?
Press and hold down the center shaft of the blade assembly and lift the blades straight up. You can go here: http://www.ultimatechopper.com/chopper_ul_manual_eng.pdf for a downloadable pdf copy of the user's manual.
Jan 03, 2009 | Ultimate Chopper Food Processor
We can`t disasemble it with the dough blade in, any tips?
All of the blades "lock" (rest in a groove) when rotated clockwise. This is so they'll stay put when in operation. When you take the bowl out with a blade in, you're moving the pair in a clockwise direction. So, you lock the blade in, thus locking the bowl down. Either remove the blade first by rotating it counter clockwise, then up or move the blade back 1/10th of a turn after rotating the bowl as far as it will go clockwise.
Jan 02, 2009 | KitchenAid KFP750 Food Processor
Stuck dough blade
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
Dec 27, 2007 | Cuisinart DLC-5 Food Processor
Food Processors Logo
138 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
