I did not use my dishwashing machine for 8 years. Do you think that the plastic pipes have dried out and it could be dangerous to start the machine ?
The machine is 16 years old
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Should b fine unless some critters have taken up ress
Posted on Apr 12, 2015
Problems disconnecting the wastepipe on an AEG Dishwasher
Pour some bleach into the stinky backwash. I know that this is not good for the environment but it will take the stench away while you get a new dishwasher. Sorry but you have plumbing problems out of my range.
Oct 25, 2012 | AEG 24 in. Favorit 80800 Free-standing...
We have a whirlpool adp 5440 and the start button is flashing 8 times after a cycle. Dishes do not get properly clean. What oes that mean? Thanks Sonja
The start light is flashing. I checked the bottom of the dishwasher and saw a black pipe coming out of the electric motor is leaking.
Is it possible to replace only the pipeline or have to replace the entire engine?
Feb 19, 2011 | Whirlpool 24 in. ADP6940 Dishwasher
Why does the interior of my dishwasher look so dried out? And why are my NEW and old plastic dishes getting hard and white? I just traded dishwashers out and my other one didn't have this problem. Can...
Are the plastic dishes you mention dishwasher safe. they should have a symbol on them to say they are? What you describe is a typical sigh of overheating, but it may be possible that the new machine thermostat may be faulty and is running too hot. If you feel this is the case and the machine is new, it is safer to consult the dealer rather than risk losing your warranty because the machine was tampered with.
Feb 18, 2011 | Whirlpool Dishwashers
Hi there, Just moved in to a new place and loaded up this dishwasher. First set it to "normal wash", dry "off", "start". Made noises but after a couple of minutes I heard...
Lorraine.. It sounds like the water valve under the washer is stuck or maybe partially shorted. It is a solenoid coil activated shut off valve. The coil may be overheating, and valve not opening.. so motor is running dry.
If you want to tackle it, you need to remove the kick plate at bottom of front, and see where the water pipe comes in to a plastic block with a couple wires attached.
If you shut off the water under the sink, and cut off the power to machine, you can unscrew the pipe fitting from the block, with a wrench, unplug the wires, and remove the screw or bolt holding the valve on. sounds easy but you'll be working on the floor in a narrow space.
Take it to a hardware store and buy a replacement, or find one online.. When reconnecting the water pipe make sure to use some teflon tape (from hardware store) wrapped around the threads to get a water tight seal.
Dec 22, 2010 | GE Nautilus 24" Built-in Dishwasher
My dryer is taking about 1 1/2 hours to dry. It still has the heating element working but no matter what setting I put it on, it is taking 91 minutes, 95 minutes to dry. Any ideas why it started to take...
How is the filter and exhaust pipe? Have you cleaned them recently? I think your machine has a clog somewhere between the filter and the outside vent hood.
Pull your machine away from the wall, remove the pipe ... if it is plastic, please consider replacing it with a metal one. Metal will not burn. Vacuum the pipe end to end - then check the flapper outside ... is it clogged? clean it.
Thanks for your interest in FixYa.com
Jun 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
SHOWING E3 ON DISHWASHER
Had the same problem (apart from the code) and the answer is to stop putting plastic in the machine ! It seems the dishwashers need the heat radiated from the Ceramic plates, stell knives etc to help dry. The plastic simply absorbs some water and then your dishwahser spends most of its drying time trying to get that water out again. Also Plastic doesn't radiate any heat to help. As soon as we stopped putting plastic plates and tupperware containers in, hey presto the dishes are drying again
Apr 13, 2010 | Kenwood KDW243A Builtin Dishwasher
My 6 year old Kenmore Elite DW has started leaking and has a musty smell. The dishes are clean but food residue is left on the inside door and black gunk builds up on the bottom of the dishwasher.
Use a wet/dry shop vac to clean out the strainer and drain from the inside of your machine. A musty smell is a sure sign that food particles have clogged your drain BUT can also mean that your wash/spray heads have become clogged as well. Use a pipe cleaner on the spray heads and run water over the jets to make particles flow to the big hole in the center of your wash heads, then reassemble. Don't forget to put those little plastic looking rings back exactly the way you found them or your wash heads wont turn properly. They are usually made of teflon to lubricate the spray heads.
Mar 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My kitchenaid dishwasher heating element looks as if a coating is coming off of it in a small area. I would like to replace the element...how is easy is it to replace.
I just replaced mine. I ordered the part from Kitchenaid and just got it today. I turned the power off at the breaker, turned the water valve off under the sink. Two screws hold the machine in place under the counter top. I slid the machine out about 8-10 inches and disconnected the water supply tubing on the bottom left side of the machine and then was able to pull the whole dishwasher out from under the counter top. on the bottom in the back are two white plastic hex nuts with a wire connection going to each. I pulled the wire connections off each and loosened the white plastic wire nuts. Then I went into the washing tub where the heating elements is. I shook the two contact ends loose and pulled the element out. I put everything back in the reverse of this. You will then need to reset your panel by pressing the sani wash and the heat dry buttons back and forth a couple of times. All the lights will then go on and the machine will reset itself. Give it a go. Best to ya!
Oct 11, 2008 | Dishwashers
Replace a dishwasher
Hopefully there's enough slack in your water supply hose for you to just pull out the machine and unscrew the hose.  Be sure to turn off the water before you unscrew it.  You might be able to unscrew the bottom plates to access the supply connection from the front.  Your new machine will probably have a 3/8" female connection.  I'd suggest having a 3/8" street elbow and an adapter for 3/8" male to whatever your plastic pipe.  The other thing to watch for is whether your machine is hardwired for electricity or has a cord and plug.  You can use your old cord and plug on the new machine, if the new one doesn't have one.
prem
Oct 20, 2007 | Dishwashers
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
