Question about Gund Fun Peek A Boo Bear - Tan
The arms won't move. How can I fix it? - Gund Fun Peek A Boo Bear - Tan
92 olds cutlass supreme, shifter moves into gear, but car will not move. Help
It\'s right where the shifter cable goes into the shaft, look
right next to the steering cloumn under the hood,the switch
won\'t keep the car from moving tho,it just wouldn\'t start.But you
could look there to make sure the cable hasn\'t broken or come
unhooked. The cable goes to an arm about 3 inches long just
make sure the arm moves when shifting.
Duralast/Neutral Safety Switch
Mar 16, 2013 | 1992 Oldsmobile Cutlass Supreme
Tailgate won't open on 1994 GMC sierra c1500
Check to see if you can take out the tailgate handle and see if the unit is still connected to both arms that moves to release the pins are still connected and or broken.
Oct 12, 2012 | 1994 GMC Sierra
Driver side wiperarm won't move
we can start at will wiper arm move, if you move it with your hand ?
it could be striped off at connection ,remove arm and see if drive under arm is moving, the other is linkage has become diconnected at wiper motor extion arm under hood .hope this helps good luck.
Oct 03, 2012 | 1998 Mitsubishi Galant
Brake light does not work after replacing bulb
It's usually the brake pedal is sticking or you might just need to adjust the pin when you apply your brakes it makes those lights stays on. sometimes you can spray a wd-40 and it'll go away.. this pin is located on top of the brake pedal when you look underneath the steering wheel column or panel....hoped i helped you on this one...
The brake light switch may be either stuck or broken.
Get down in the driver's footwell, and follow the brake pedal arm up under the dash. Look for the switch (see link for a picture), see if the moving arm on it moves freely as the pedal is depressed. If not, try spraying some lube on it (WD-40 or the like) and working it to get it to move freely.
If the arm won't move freely, or the lights don't turn on even when you move the arm, the switch should be removed and replaced.
Buy custom car parts.
Jun 02, 2012 | 2007 Toyota Tacoma
Feed dogs won't raise and lower on my memory craft 9500, how can I fix this problem?
when your machine on your machine movable arm pushing a switch liver which will raise your feed dogs you can do one thing when your arm moves to the normal possision just given your finger to the upside movable are you see one long switch bar is there just push and see machine feed dogs will come out actualy that action to be done by arm only,you call one MC expart to resoved your problem permenetly.
Apr 21, 2012 | Janome Memory Craft 9500 Computerized...
Turntable won't stop spining
If it is a turnatable that starts spining when the arm is moved to the record, then more than likely the start/stop switch inside the turnable is broken and is fixed in the on position. Or the leaver mechanism has become detached from the arm when the record was playing and left the other part pressing on the same switch that turns the motor on or off.
Removing the bottom of the turntable should should show the trouble.
Apr 03, 2012 | Philips WMM142211 Turntable
The release handle for the hood is not opening the hood on our 1994 chevy astro van . Can we open it manually and then try to see if it became unattached?
you can open it by going either underneath the front of the car and reaching up to move the latch arm to unlock the hood or try going through the grill to move the latch arm to unlock the hood.then you can see if its unhooked or the cable is broken.you can temporarily fix it until it can be properly fixed by hooking up a cable to the latch arm and run it out the grill and fasten something to it so it won`t fall into an area you can`t reach it to unlock it from outside.
Jul 11, 2011 | Chevrolet Astro Cars & Trucks
The windshield wiper on the driver's side must be removed and reinstalled (I suppose) because it is no longer correctly doing the "wiper thing." The passanger side one works, but the driver side...
If you lift the wiper arms off the window to reduce friction and operate the wipers, do they both move? If the shaft and wiper arm doesn't move on the bad wiper, take it to a garage as it is a big job to replace the mechanism. If the shaft of the bad arm moves, the nut holding the wiper arm onto the rotating shaft should be tightened. If that does not fix the problem you should remove the nut and wiper arm and inspect the splined shaft end for wear. Clean the grooves and reattach the arm. This will normally fix most bad wipers and helps them do their "wiping thing".
Dec 31, 2010 | 2000 Chevrolet S-10
Gund Fun Peek A Boo Bear - Tan Logo
Top Gund Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Gund Toy Expert? Answer questions, earn points and help others
