Question about Refrigerators
The icemaker is not working how do i fix it? - Refrigerators
  • Refrigerators Master
  • 5,323 Answers
ICE MAKER not making ice:
Inspect Water fill tube, Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If nothing obvious has caused the ice buildup then suspect the inlet valve, tubing or low water pressure. Inspect the outlet tubing from the fill valve to the ice maker fill tube for any signs of restrictions and replace if necessary.
WATER INLET VALVE:
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing. Some water inlet valves may have a screen to filter debris before it can enter the valve. If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve. If dirt has gotten into the valve it may not shut off completely and will continuously drip water into the ice maker fill tube and will eventually freeze up. Low household water pressure or a restriction at the manual shut off valve will also cause the water inlet valve to not shut off completely and create this same condition. Self piercing saddle valves are the most common shut off valve to cause this problem as the hole that is pierced in the water line is often too small and will more easily become restricted.
The water inlet valve is operated by line voltage supplied through the ice maker control. Power is applied for approximately 7-9 seconds during the harvest cycle and energizes the solenoid on the valve to allow water to flow.
You can check the solenoid for continuity with a multi-meter. On models with multiple solenoid inlet valves, you will need to determine which portion or portions of the valve are used for the ice maker. You can normally follow the inlet tubing from the ice maker back to the valve. Unplug the refrigerator and turn off the water supply to the valve before working with this part.
(HOW TO TEST INLET VALVE: Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear theclog, it will be necessary to replace the valve (the filter is not removable on most inlet valves). Test thewaterinletvalve for continuity using a multImeter. First, inspect the coil for an indication of it's ohm rating. If no information is printed on the coil, then use the range of 170 to 500 ohms. Set the multitester to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multitester should display a reading that matches the coil's rating or if you don't know the rating then it should fall into the range of 170 to 500 ohms. If the water inlet valve does not pass this test, it should be replaced. If the inlet valve has two coils, test the second coil in the same way (note that they may not have the same ohm rating). The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Check the tap valve.A bad tap valve-the little device that connects the ice maker's water supply tube to the water pipe-may cause the problem where the ice maker's supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the "self-piercing" type). You can buy anice maker connection kitand do this yourself, or call a repair person or plumber to install an inline water filter when replacing the valve.
Lastly the ICE MAKER ASSEMBLY:
If there are no ice buildup issues or suspected problems with the water supply, then you may have a problem with the ice maker control. The most common type of ice maker used in modern refrigerators is the heat release ice maker. The ice maker uses heat to release the ice cubes.
If the water's route is blocked or the solenoid doesn't work-or if the bail wire is lifted-the ice maker won't make ice. (Also note that your home's water pressure may not be strong enough to serve an ice maker.)
If you have a heat release or modular ice maker it will have a removable cover at the front. Behind the cover is a series of electrical test points that can be used to diagnose the ice maker. The unit can be manually operated by inserting an insulated jumper wire into test points "T" and "H" to initiate a "test harvest". On other ice makers jumper at points N & M (neutral to Motor) The jumper should be insulated 14 gauge solid wire that has the insulation stripped back about 3/4 of an inch on both ends, and bent into a "U" shape. When inserted into the test points for 5 to 10 seconds, the motor should start and the cycle will continue on its own. You may have to manually close the freezer door switch for this to operate.
This test will simulate a real harvest cycle and will operate the ejector blades, shut off arm and the fill valve in the proper sequence, and will allow you to do a proper diagnosis. This is a live voltage test and should only be performed by a qualified person. If the motor does not start, you can verify that you have power to the ice maker at test points "L" and "N". If the ice maker is getting power and does not perform a cycle, then the module will need to be replaced
On component mode ice makers the testing is done differently.
Testing a thermostat in a component ice maker:
The thermostat is located near the bottom ofthe support box. The thermostat is connected by two or three wires.Label the wire placement before disconnecting them. Remove thethermostat by loosening the clamp, by pushing back the retainerclips, or by removing the retaining screws.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat whenit has come up to room temperature (about 20 minutes after removing it from the freezer).
If the thermostat has two wires touch one probe to each wire. You should get a reading of infinity.Chill the thermostat in the freezer for about twenty minutes andretest. This time you should get a reading of zero (continuity).
If the thermostat has three wires, number them 1, 2 and 3. Test combinations 1 & 2, 1 & 3and 2 & 3 and write down the results. Two of the combinations should yield a reading of infinity and one should yield a readingof zero. Now chill the thermostat in the freezer for about twenty minutes and retest. The combination that had a zero reading before, should now have a reading of infinity. One of the two other combinations should now yield a zero reading.If the thermostat fails this test, it should be replaced.
Testing a modular ice maker 'sthermostatcan be tested and replaced individually.
Test the thermostat forcontinuityusing amultitesterset to the ohms setting X1. Start by testing the thermostat when it is cold (10 degrees). Insert one probe into the hole labeled "T" and the other probe into the hole labeled "H". The meter should indicate zero resistance (continuity). After the ice maker has warmed up, repeat the test and this time the meter should indicate infiinity (no continuity).If the thermostat does not pass both tests, it should be replaced.
Posted on Apr 17, 2015
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
Why did it stop working?
How to Fix an Icemaker-EASY ICEMAKER REPAIR - YouTube
? 3:52
www.youtube.com/watch?v=4Lmpy--Rz2I
Aug 18, 2012 - Uploaded by n4ktz If you have a Kitchenaid, Whirlpool, Maytag, Estate, Roper orKenmore Refrigerator/Freezer and the Icemaker ...
Jul 31, 2015 | Kenmore Refrigerators
Icemaker not working
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 21, 2009 | Whirlpool GD5SHAX Side by Side...
Neither dispensor or icemaker works after replacing water lines
Feb 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Whirlpool icemaker
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker not working, freezer not getting cold enough....
Jan 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker does not work
Dec 15, 2008 | GE Profile PCF23NGW Side by Side...
My icemaker is not working
Tryusing an hairdryer or defrosting the unit completely , this often getrid of blockage caused by frozen lines fixing the problem.
If all that does not fix the problem, then you may need to replace thewater valve, the icemaker solenoid, or the whole icemaker assembly.
Jun 30, 2008 | Frigidaire GLRS237ZA Side by Side...
Jun 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Open Questions:
GE Spacemaker JVM1339ww002 - looking for photo of plugs in control board plugs for reassembly or a wiring diagram? Disassembled without noting locations and now start & clear buttons do not work. I have a very old model GE spacemaker XL microwave, model# JVM1339ww002. I repaired the #1 key by cleaning contacts and reinserting the ribbon connector to the control panel. However, I did not photograph the connections. Some plugs have only 1 location where they fit. However, 2 pairs of plugs are the same size and I do not know the correct place to reinsert them. I took a guess & reassembled the microwave and it worked except for the start/clear buttons. If you press a number 2 shortcut for example, it will cook 2 minutes and the food is heated. However, start and clear do not work at all. These buttons DID work before I repaired the numbers. I contacted GE and they gave me a hard time about providing the wiring diagram which was removed or not inside my microwave. I am not sure if I reassembled the plugs wrong OR if I broke something else when I was repairing the numbers. Can anyone help me with the right locations for the 2 pairs of plugs listed below? And/Or tell me if it sounds like start & clear are a new problem or will be resolved by getting the plugs correct? These are the 2 sets of plugs that can be inserted in either location: 1) a pair of matching white plugs that snap in place along the bottom (1 has white wires only and the other has 1 white/1 black wire) 2) a pair of red and white plugs of equal size in the middle of the board. They are similar (but smaller) to plugs in wall outlet with 2 prongs. Similar to a wall outlet, you can rotate the plug 180 degrees and they still fit. In other words besides asking which plug is upper or lower, do I need to worry if the plug is upside down or this doesn't matter? The red plug has black wires, while the white plug has blue and white wires.
Apr 19, 2018 | GE Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
