Question about Air Tools & Compressors
Where can I buy an intake filter for my air Compressor 8-gallon (30.3 L) 058-7914-8 mastercraft?
Richard_paquin@videotron.ca
3 Suggested Answers
miket756
  • 2702 Answers
SOURCE: How are the valve plates seated on an 8 gallon
the velves are called "reed velves" look from under the head at the velve block as if you were the piston, as the piston gos down it pulls (open)the inlet velve (but the out let velve is held closed by spring presher) and on the way up it (pushes closed on the inlet velve) and pushes the out let velve open so air can be pushed into the air tank,,,has this helped you? they are held in place by light spring presher and maybe fasend by a bolt?
Posted on Oct 25, 2009
  • 574 Answers
SOURCE: mastercraft air compressor parts
just get some ptfe tape from and plumbing shop and wrap the plug
Posted on May 19, 2014
Testimonial: "tried that, nope! Lasts for about 2 seconds then... there she blows!"
Mastercraft air compressor parts
May 19, 2014 | Air Tools & Compressors
Where do I go to order repair parts?
Air Compressor Parts & Accs - eBay
www.ebay.ca > Business & Industrial > Light Equipment & ToolseBayAir Compressor Filter Regulator Industrial Quality 0 to 160 PSI. C $41.83; Buy It Now; +C ... Power Ingersoll Rand Impact Wrenches, Ratchets & Tools. C $104.65.
Clarke Air Compressor Parts‎
about.com/Clarke+Air+Compressor+Parts‎rating for about.com
Clarke Air Compressor Parts. Search Now!
Over 85 Million Visitors.
Nov 04, 2011 | Clarke Power Products Inc AC2000 2HP 6...
Looking for SCFM rating for a Mastercraft Model # 820218 air compressor
I have a Mastercraft 820218.
Specs are: 2 peak HP 5 Gallon tank 5.0 cfl @ 40 psi 4.0 cfm @90 psi max pressure 125 psi
Jan 23, 2011 | Garden
Compressor will only build pressure to 75 psi and stop and compressor keeps running what could be wrong
If you can hear air bleeding off through the air filter when you turn it off then the check valve has failed on the compressor discharge to tank line and cannot overcome the tank pressure. If there is no air coming out through the air filter than the intake and dischare valves have become weak or are broken/not seating. Post your findings, I wil see if i can help I worked on compressors for 5+ years
Jan 19, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
How dose the unloader work on a T30 compresser ? T30 compresser has small air leak sound comming from intake ? Is there a flow chart of how ther air is compressed T30 ?
There is no unloader on a 2340N5 compressor. However there is a pressure switch that cuts the motor on an off. Located inside of the pressure switch is an air bleeder. When the pressure switch is opened the motor is shut off. A small lever in the pressure switch pushes down on the bleeder valve which lets the air on the compressor head to be released. This allows the the compressor to start up freely. There should be some air heard bleeding off at the pressure switch. If air continues to bleed off all the time the tank check valve is leaking.
If air is leaking back thru the compressor an air leak sound coming from around the air filter (intake) you have a valve leaking allowing trapped pressure to escape thru the air filter (Intake).
I would search the web for a flow chart. I have not seen one.
Nov 16, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
1.fault code 970- compressor runs for few minutes and trip, why. 2.compressor is not burnt but also not working well.
Check the intake filter. Check the output line for leaks. remove pressure line and air intake from compressor and inspect reed valves. Dust and oil can hold the reeds open.
Aug 09, 2010 | Ingersoll Rand Compressors 5-HP,...
No pressure getting through to gauges
remove the intake filter and check to see if the compressor is sucking or blowing if it is blowing out air from the intake you have a bad valve
Apr 26, 2010 | Clarke Power Products Inc AC2001 2HP 4...
How are the valve plates seated on an 8 gallon mastercraft air compressor?
Oct 25, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
104 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
