Question about Garden
Back right tire on my JD 130A lawn tractor went flat and had new tube put in, put back on the mower and now the back wheels won't engage (turn); mower starts fine, but wheels aren't engaging; can't figure out what the problem is!! Help!!
  • Larry Stull
    Larry Stull Apr 11, 2015
    It was the shear pin on the axle shaft......THANKS!!!!!
  • Garden Master
  • 2,536 Answers
Has your drive belt come off? Did you lose the shear pin out of one of the drive pulleys?
Posted on Apr 11, 2015
Testimonial: "Thank you so much....it was the shear pin on the axle shaft!!!!"
I took the left rear tire off my John Deere lawn tractor and when I put it back on the tire won't engage to run
on some of the mowers there is a slot on the axle and on the inside of the rim that a metal key goes in. you line up the two slots and put this key in and then tighten the wheel. it locks the rim to the axle. i am guessing it must have fallen out when you took the tire off. find it and put it back in you should be good to go.
Apr 22, 2016 | John Deere Garden
How do I remove a valve stem from riding mower rim?
If your simply replacing it with a new one or installing an inner tube you take a sharp knife and cut back side off. Don't cut completely as you want to catch that piece before it falls inside the tire. Then you simple pull the stem breaking that piece off, catching the back piece as it falls.
If you wanting to put back in a new stem for tubeless use you need a t-shape valve core wrench. After you place the new stem in the hole you thread the tool on and pull the new stem into place.
Jun 22, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Murray 42" tractor drive won't engage
Does the wheel you took off only have one centre nut?
If so it whould appear that you may not have put the key in the keyway of the shaft and the wheel when you put it back on. Maybe the key was in the wheel and hs fallen out at the repairers.
Sep 28, 2017 | Garden
Lawn mower won't engage forward or reverse "drive belt is not broken
If it's a JD rideon make sure you have pushed the lever back in all the way!
Apr 17, 2013 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Dealer installed John Deere tires won't hold air
the only way to know without taking them off but most leaks on mower wheels is rust on the beads have them install tubes and be done with it because the y will never seal like new
Apr 15, 2012 | Garden
How do you remove a stuck tire on the back of a craftsman lawn tractor?
sound like you broke a clip inside the trans you will need to split the case open to see when i get the wheels that are stuck on i just pop the beads and do it right on the mower it seams like more work but it's not
Apr 06, 2012 | Craftsman Garden
Freewheel lever broken
For the wire to come all the way out lever on top of the trans must be broken. I've seen a few. Jack rear of mower up, remove rear right wheel and find remnants of lever. With pliers turn this all the way forward, mower will now go. But to fit new lever trans will have to be removed. Dont forget the axle key.
Nov 12, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I removed, re-inflated and reinstalled back right tire on my Poulan 42", 18 hpr riding mower, now it won't engage in gears and move forward or backward. I've compared the reinstallion with...
there is a slot on the axle for a square key to fit in.
when you took off the wheel it might have fallin off.
look around for a little square piece of metal.
like a little bar.
put it in the slot and put wheel back on.
don't forget to vote for me.
thanks
Jul 16, 2011 | Garden
I have a Craftsman mower 917.280810.It barely moves when clutch is released,even on flat ground.I changed the belt-no help.The transaxle pulley is engaged,and when I put my hand on the tire,the tire stops...
I don't quite get you, if the belt is running but the rear axle is not turning then your transmission is shot. If the belt is running and the rear axle is spinning with no forward or backward motion, then someone took the back wheels off and put them back on without installing the keyways.
Sep 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
