Question about Hobart Dishwashers
Why would a Hobart AM14 Dishwasher just fill and not wash
The dishwasher fills and does not heat the water or go into the wash cycle
    Habit-Forming:
  • 36 Answers
It seems to have failure on the lever sensor .
check the float , probe and switch assy.
Posted on Jul 11, 2016
Rotu
  • 175 Answers
SOURCE: washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Posted on Nov 23, 2006
  • 116 Answers
SOURCE: new dishwasher fills with water but does not start washing
It is possible that the motor pump seal is locked and needs to be freed up. Remove the filter and sump screen and place an 8mm nut driver or socket into the circulation pump opening ont eh right hand side. The nut driver will engage a nut on the center of the circulation pump impeller rotate it 2 revolutions clockwise to free it up. If it does not turn at all then the motor needs to be replaced. Remove the nut driver replace the screens and check for operation.
Posted on Mar 11, 2007
  • 641 Answers
SOURCE: Fills with water but won't wash.
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem. Good luck
Posted on Aug 12, 2007
  • 112 Answers
SOURCE: Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Posted on Oct 18, 2008
SOURCE: Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Posted on Sep 04, 2009
AM14 Display will stay in Rinse Cycle
see this probably causes:
Water-heating cycle
the heating will be importante, test the hot water, and heating elements
Timer
test the timer for contact, and probably defective.see the diagram attached.
May 07, 2012 | Hobart AM14-253 Free-standing Dishwasher
We have a hobart am 14 hotwater sanitizing dishwasher that no one knows how to use, how can I get an instruction booklet?
Go to hobartcorp.com instuction manual are available on its site to download.
Makes sure all screens are in nothing in tank under them (spoons especialy). turn power switch on, shut door and it fills, should say fill on led display. once its filled open door and put tray in shut door and it starts wash cycle. led will say wash then it will go into rinse. when risnes dispaly turs of its finished. open doors take tray out. put next tray in. to drain out to clean there is a little moon shaped lever right above basket it will life the drain stand pipe greay plastic tube under screens and it will drain out shut door turn on the switch and it will fill back up and off you go. Soap wil be with a privet vendor if you have a already installed soap system call them and they most likely have reps who cann show you you basics.
Best Dishwasher Hobart ever built is the Am-14
Aug 19, 2011 | Hobart AM14-253 Free-standing Dishwasher
Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
Hobart am 14 electric heat does not turn on water temp just drops
Assuming that the machine fill cycle works properly and the float is intact, and the heater contactor doesnt pull in:
possible heater contactor malfunction: check for power to coil
High limit snap thermostat may be tripped or damaged ( needs to be manually reset). located in heater connection cover.
Thermistor probe and or wiring to it may be damaged
main control board may not be functioning properly. check output to heater curcuit
Feb 01, 2010 | Hobart AM14-253 Free-standing Dishwasher
Hobart AM-14 water temperature not maintained
Hobart AM-14 will wash and rinse in manual, but not in automatic
Oct 01, 2009 | Hobart AM14-253 Free-standing Dishwasher
AM14 tank heaters--when are they energized?
How hot is the wash temp?It should be 150-165 degrees.The model is an am14 not an am15?I'm hobart tech and repair these units weekly.Let ne know.
Feb 26, 2009 | Hobart AM14-253 Free-standing Dishwasher
Am14 initial fill
lift **** basket out and lift out samle stailees plate drain and look for stailess probe coming out of side of tank half way down there should be a white pprobably yellowed plastic ball it is a float they get old and fill fith water and don't flote telling maching I have no water keep the water coming. the float is sometimes even missing fell off andf thrown out. 10 bucks and a clip your off and running. call hobart its 110.00 and your off and running.
Aug 05, 2008 | Hobart AM14-253 Free-standing Dishwasher
Hobart AM-14 dishwasher
it has a time out function once float is up is your water pressure correct. if to low it will first few cycles be low but after the will get to correct level and that is to the top of grey plastic drain pipe it cannot or should not be higher then the Gray drain pipe top, it overflows out that any extra rinse goes down it. check the o-ring on bottom of that grey pipe you could be leaking out the drain in between loads you come back and half the water is gone.
Aug 01, 2008 | Hobart AM14-253 Free-standing Dishwasher
Dishwashers Logo
210 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
