The top part of agitator is not turning correctly. It should pull the clothes down into the bottom part of the agitator, but barely turns at all.
  • Nancy Wright
    Nancy Wright Apr 13, 2015
    What I meant was that I since the bottom agitator still works just fine, will just wash smaller loads so that the bottom agitator gets them all clean.
  • Washing Mach... Master
  • 5,323 Answers
Sounds like u have bad cam dogs need replacing they are only about 5 bucks, easy fix
Posted on Apr 11, 2015
Testimonial: "Jhonny Rendon's advice was exactly correct. I'll be happy to use it when my parts come in, hopefully, before the end of the week. In the meantime, I'll just wash very small loads."
  • 2 more comments
  • Jorge Rendon
    Jorge Rendon Apr 13, 2015
    THE SCREW IS 7/16 ABOUT 5 INCHES DOWN IN THE AGITATOR ONCE U REMOVE IT WITH A DEEP SOCKET WRENCH, U CAN THEY LIFT OUT THE TOP PIECE OF AGITATOR, THEN REMOVE THE THRUST WASHER AND THE CAM DOGS WILL COME OUT, BE CAREFUL TO NOTE HOW THEY COME OUT , THE TEETH MUST FACE THE GROVES
  • Nancy Wright
    Thank you. I noticed yesterday that the videos I saw that were supposed to be like mine were slightly different. I did take it apart like the video showed, but when putting it back together, realized that I really didn't HAVE to take out the bottom part. I am actually glad I did, though, because it had so much gunk under the top part, I probably would never have separated them without taking the bottom out, too. I ordered a $5 kit that has the whole part that holds the "dogs". I really don't need the whole thing, but did need that big O-ring that goes on the "Barrior cap", and could also use a new rubber washer. I found an exploded view and think I'm going to be OK now. Thank you, again.
  • Jorge Rendon
    HUM U SAID SOMETHING BOUT WASHING IS GENTLE CYCLE LIGHT LOADS? USUALLY WHEN BAD CAM DOGS U CANT WASH ANYTHING IT HAS NO INTERLOCK AND MOVEMENT? HOPE ITS NOT UR MOTOR WITH BAD WINDINGS WHICH WILL ALSO allow a soft wash cycle but not a full wash
  • Nancy Wright
    I don't think my last comment posted because I wasn't signed in correctly. What I meant was that since the bottom part of the agitator works just fine, I'll just wash small loads so that the bottom agitator will get the clothes clean.
The agitator barely moves at all during the wash cycle.
Usually once you take off the agitator cap and remove the bolt just pull up on the top half of the agitator and it will snap right up. Take note to the position of the plastic washer and how it fits. This will make it much easier to reassemble. I will bet that the dogs are the problem. The way to check them is to try and turn the top of the agitator back forth while holding the bottom. It should turn one way but not the other. If it slips at all, replace the dogs. About $8- $10.
Feb 19, 2014 | Kenmore Washing Machines
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
It leaves soap on the clothes after it goes thru the cycle and I noticed that the top part of the agitator doesn't move hardly. The washers model # is LSR8233JQO and the serial # is CK4729250, Type 111.
The agitator dogs (part # 80040) that grip and turn the top agitator to push the clothes into the bottom agitator during the wash cycle are worn and must be replaced. It costs about $5 and replacing it is an easy task to do.
Disconnect the power to the washer. Open the lid and remove the agitator cap by prying it with a flat-bladed screwdriver off the agitator top. Remove the 7/16 inch stud and seal holding the agitator to the shaft using a socket wrench with extension.
Lift the agitator off the shaft and pull the top agitator off the bottom agitator. Remove the cam that holds the agitator dogs from the top agitator.
Lay the cam upside down and install the agitator dogs on the slots. Hold the cam with the newly installed agitator dogs on one hand and the top agitator upside down on the other. Slide the cam up into the top agitator and turn the assembly in the upright position.
Align the cam and bottom agitator tabs and cut-outs and place the top agitator with the cam over the bottom agitator. Place the agitator assembly on the shaft and rotate it until the grooves match. Push the agitator down and reinstall the stud and seal. Do not over tighten the stud or the agitator will not spin properly.
Feb 10, 2010 | Dryers
Series 80 Agitator top dosent work
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
I assume that your model number starts with a 110 instead of 100.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26842692
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Following is an illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Jan 09, 2010 | Kenmore Washing Machines
Clothes get stuck between wash plate and basket,
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 26, 2009 | Kenmore Oasis 27042 Top Load Washer
Kenmore Washing Machine Agitator
Mar 12, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My washer is agitating very slowly
Feb 16, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series agitation problem
suppose to not spin unitl the lid is closed( safety reasons) the reason for the "weak agitation " is a bad set of agitator dogs. by removing the center fabric softener cup, you can get to and unscrew the center shaft bolt7/16. after removing the bolt, the agitaor will remove and the agitator dogs canbe replaced. part number 80040.youll need to split the agitator top and bottom to insall them . they simply slide into place.
Feb 14, 2009 | Whirlpool LSB6200PQ Top Load Washer
Clothes wrapping around centre spool
Jan 22, 2009 | Washing Machines
Top agitator doesnot work
Your agitator dogs are worn out. They are 4 small pieces in the agitator that act as one way clutches. They allow the top section to turn one way but catch the other way. Pretty simple fix.
If you will post the complete model number I will find the part numbers for you and try to provide instructions on replacing them.
Nov 26, 2007 | Whirlpool LSB6200PQ Top Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
