Question about Troy Garden
How do I adjust troy built lawnmower deck. Front bar attached. To deck came off and trying to put it back on
  • 2,027 Answers
I think the way it looks you will have to unscrew the bar and put it in the hole then put the part back together. You may have to move your base one way or another to do this as well.
Try moving your base up or down or side ways before you unscrew it as well You may have to just line it up to make it work.
Posted on Apr 11, 2015
    Sergeant:
  • Troy Expert
  • 187 Answers
Looking at the picture, I am not entirely sure, but it looks like the hole that holds the end of the rod with the adjusting nut, is split. It looks like the rod would just fall back out, true?
That rod is called the front draft rod. If the split is not too big, then slide the short end of the rod into the hole. Rotate it through the hold when you get to the bend. Slide the long leg of the L all the way down till the large adjusting nut makes contact.
The cutting deck needs to be supported up off the floor. I use 12" pieces of 4x4, under both sides of the deck, to keep the deck raised. You cannot get the short leg of the L through the hole in the bracket on the deck support if the deck is on the ground.
The picture below shows how the Front Draft Rod looks on another machine.
How do I adjust troy built lawnmower deck. Front b - 25641294-3kkyg54pxgo4gl4kitgj1khp-4-0.jpg
Posted on Apr 12, 2015
  • Eugene Rounds Apr 16, 2015
    That is problem you have the draft in backwards, Refer Kprime picture for the way should be attached.
  • 10865 Answers
SOURCE: broken deck belt for troy built model 13ax60tg766
here is the troy bilt website. you will find exactly the model and the belt that you need.
http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_TroyBilt_10101_19502_-1
Posted on Apr 25, 2009
bargainbin2
  • 123 Answers
SOURCE: I have a Troy Built lawn tractor, after removing
Clearly the cable either broke, came loose.
Posted on Aug 26, 2009
  • 582 Answers
SOURCE: How do I level the mower deck? I have a 48
the easyest way i have found is to use 4 pieces of brick , get the mower on a level surface place one oiece of brick under each corner of the deck and make adjustments until the deck starts to raise off the bricks
this should be the three inch level . my mower had the same problem and this worked for me
Posted on Sep 03, 2009
  • 89 Answers
SOURCE: I have a Troy Built 6605 lawn tractor. The engine
check your belt might be off a pully or maby your spring is off
Posted on Nov 09, 2009
e-Guru
  • 3917 Answers
SOURCE: Deck belt broken, l need
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 20, 2011
Where are the grease fittings ona Troy built riding Lawnmower that has a19hp Koehler engine and the mower is called bronco
There are only 4 I know of inside the 2 front wheels on the axle and 2 on the steering knuckles.. you may have some on the deck spindles but most of them are sealed now days
Apr 24, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Troy Bilt zero turn Mustang Xp 50" deck height. My
raise the back as high as you like but unless you raise the front as well it will still cut short. If you want it higher and there appears there is no adjustment left you may have to re thread the adjusting screws to shorter dimensions or if it is on levers you may have to drill new holes further up the bars.
Jun 02, 2013 | Garden
How do I repair height adjustment on a CMM1200?
The front wheels link to the height adjustment controlled at the right rear wheel. The spring loaded link arm attaches to a pin on the height adjustment control. The link arm has come off the pin.
Tools: Long shaft bladed screwdriver and a pry bar.
Adjust the rear height adjustment so the second to last notch is engaged.
Position yourself with one knee on the front deck. This will allow you to control the height of the front and the back-n-forth movement of the link arm.
Position the pry bar with the short "L" section upwards, under the lawnmower. This will allow you to control the side-to-side position of the link arm.
Insert the screwdriver from the rear of the lawnmower. The rear wheel axle can be used for leverage This will allow you to control the up-and-down position of the control arm.
A little perseverance and you will be able to position the link arm back on the pin. It may be useful to remove the plastic cover of the lawnmower to allow a better view of the mechanism and link arm
Aug 05, 2012 | Black & Decker Cmm1200 24v 19" Cordless...
I have a troy bilt 17.5 hp pony riding manual lawnmower and my belt located above the deck keep jumping off track after engaging the blades a couple of times,do i need to tighte my belt,if so how?
Those units are self adjusting. No way to adjust it. It sounds like you have a bad idler pulley or a bad spindle bearings, which would cause the pulleys to be out of alignment.
Sep 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
How to change an engine to deck belt on a Troy Bilt riding lawnmower
Either put the front of the mower on a jack or ramps and lower the deck. There should be adjusters on the pulleys which hold the belt on. Loosen these, then put on the new belt and use pulley tensioners to adjust the belt securely.
Aug 05, 2010 | Troy Garden
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I have a troybuilt push lawnmower with a honda motor, I was wondering where the oil plug was where I can drain the oil.
It is under the mower, you will need a 3/8 ratchet and extension to take it out...make sure NOT to tip the mower over, you will have to raise it, but make sure the spark plug end stays up!!!
Apr 25, 2009 | Garden
Garden Logo
165 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
