Question about Nordic Track A.C.T. Commercial Pro Elliptical
My AC adaptor plug stopped working and the console does not turn on. Is there a battery option for this machine?
I tried to charge my psp with a few 9 volt batteries and i think i fried the motherboard it wont turn on with the battery or without the battery and connected to the AC adaptor. When i try to plug the AC...
You could try another battery.But if another battery doesn't work,sorry mate I think it's dead.In future make sure you only use what you know is compatible,also NEVER try to run the PSP with the AC adaptor without the battery in.The PSP safety and support booklet states: Do not use the PSP system with the AC Adaptor when the Battery Pack is not inserted in the system.If the AC Adaptor is disconnected suddenly,it may result in damage to the system.
If it is the motherboard that's burnt out I think you can replace it but they're expensive I think,I saw one for a PSP1000 for
Oct 04, 2010 | Sony PlayStation Portable (PSP) Console
I just purchased an adaptor for the vsmile learning system, so we didn't have to use batteries. I followed instructions on how to plug it in correctly, but when I plugged the ac adaptor to the vsmile, it...
You have to take out the Batteries.
also, the connector on this adaptor is incorrect for some Vsmile consoles. (most that are about 5 years old now).
Make sure you are using the right plug, and it is inserted fully into the console with no batteries. Then, it should work.
Jan 24, 2010 | Vtech V.Smile Adapter
My HP laptop cannot be switch on problem with virus
do a power drain
1. shut down the comp
2. unplug the ac adaptor
3. take out the battery
4. without any power connect to the comp
    press and hold the power button for 60 seconds
5.after 60 seconds plug the battery
6. plug the ac adaptor
7. turn on the comp
Oct 20, 2009 | HP Pavilion dv6000z Notebook
Battery light turns off when ac removed
one of the led's has burned out, deal with it! (Windows has a indicator all on its own btw.)
Sep 27, 2009 | ASUS Eee 4G Notebook
My (fat) psp isn't working without the ac adaptor
Your battery is dead. You will need to get a replacement. eBay is your best option.
Aug 26, 2009 | Sony PlayStation Portable (PSP) Console
TouchPad Stops Working When I plug up AC adaptor
does your trackpad heat up over time when it is on ac, and try going into your bios and setting the option for performance on ac power and battery power to the maximum
Jun 13, 2009 | Computers & Internet
The ac adaptor light is permanently red
Hook up the ac adaptor and make sure the other end is not plugged into the xbox 360. if its still red then your ac adaptor is bad. If its still green then plug the other end into the 360 and if it turns red then that means the mainboard inside the 360 is bad.
Jun 06, 2009 | Microsoft Xbox 360 Console
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    Laptop won't turn on
    The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
    Jul 11, 2008 | Dell Inspiron 5160 Notebook
    Lap top problem
    Hi
    If the AC power light is blinking, try the following steps:
    1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
    2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
    defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
    3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
    4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
    5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
    Regards
    Mike
    Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
    Nordic Track A.C.T. Commercial Pro Elliptical Logo
    311 people viewed this question
    Top Nordic Track Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Ross Metcalfe
    Ross Metcalfe
    Electro Med Services...
    Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
