Question about Bosch TWIN PACK HEAVY DUTY CUTTING LINES TO SUIT ART26 & ART30 Combitrim COMPARES TO F016800182
Bushes at the top of the motor. Made from carbon .
Motor
    Top Expert:
  • Bosch Master
  • 10,875 Answers
Sparking from the rear air vents during use--cause and how to fix
Hi
The most likely cause is the carbon brushes that make contact with the armature are badly worn. There should bea circular port on either side of the housing near the rear. They look as if a coin would be the right shape to unscrew them.when removed you should see a spring and a carbon block on the end. There will be a severe concave gouge at the end. Perhaps almost no block at all. It is simple to replace then bushes, simply slip in the new ones and align the spring to the cover and screw back on.
Take note that the bushes may so badly worn that they will fall apart when removed.
Get new "carbon bushes"for that model drill before disassembly, they are not expensive, look on ebay. If this is not the problem the chances are It is a faulty armature, in which case by a new drill, happy fixing.
Les
Aug 02, 2014 | Dewalt DC900KL Heavy - Duty 36 - Volt...
My ge dryer model DRS483ED1WW won't turn on all it does is buzz when I try. I have changed starter switch that didn't work
does the drum and motor turn by hand freely. but i think its possibly the bushes in the motor. just have a look at motor and see if theres black carbon dust on it, you will get this on a motor anyway but not in excess
Jan 06, 2012 | GE DBSR453EBWW Electric Dryer
My bike will start just fine when it is cold but when i have been riding it a while it doesnt want to start. (when it is hot) Should i just change my starter or is there a fusible link or something?
sir, its self start motor needs service..motor inner link carbons and bushes needs to change ..when your engine get hot ,obviously the pistons get tightend and motor is unable start the engine..
Apr 26, 2011 | Suzuki GS 750 L Motorcycles
The alternator has packed up. What should I do? How do I fix it myself?
you can not do it yourself just change it mostly either the carbon bushes go bad or bearings
try it by opening it and then see if the carbons have gone small original size is almost 3 quarters of an inch
Feb 22, 2011 | Hyundai Motor 1995 Accent
The machine will not drain or spin
it could be the pump is blocked, or need new carbon bushes in motor hope it helps
Jan 20, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Machine stopped at the beginning of the spin cycle and now is filled with water and won't start, no power at all.
check the carbon bushes on the motor,sounds like they have worn out,cost about £10.00 to replace them yourslf,just put them in the way you take them out,rgds,paul
Jul 07, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Wont spin renewed carbon bushes and new motor ,belt okay.can you advise where the electronic detection device is on the machine,how can it be repaired
Usually located at bottom rear left of washer.
If not there, then located at top front right of washer together with timer control.
May 22, 2009 | Zanussi ZWF1430W Front Load Washer
Blade brake not working 1/2 the time on Hitachi C15FB chop saw
d70d03f.jpg3f82e5b.jpg38ca90b.jpg4367374.jpg063ef2e.jpg1add57c.jpg98eea3c.jpg The first picture is the only one I could find of your saw.
All saws are fitted with carbon bushes that contact the armature of the electric motor.
In time the carbon which conducts the electricity wears down, as they disintegrate there are particles of broken carbon connect with the armature giving an intermittent burst of power, eventually the bushes no longer contact the armature and the saw does not work at all.
The next photos show the approximate position of the cover to access the bushes, there is one one each side of the housing.
They usually unscrew and expose the spring plate the bush is mounted on, gently pull this out.
As you can see the bush is worn in a concave shape, and that the wide side is breaking up.
If this is your problem then take the bush and model number of your saw to a supplier or spare parts shop or the hitachi web site to get replacements.
Hope this helps.
If anyone finds this information helpful please tell fixya
Cheers
Les
Feb 10, 2009 | Hitachi C15FB 15" Heavy Duty Miter Saw
On my old Royal the motor has stopped working
If the carbon brushs are ok, then either the armature or the field is bad. You will have to rebuilt the motor, or replace it, which ever is cheaper and available. You will have to get parts from someone selling Royal parts, or maybe take it to a place that will rebuild it for you.
Apr 24, 2008 | Royal 2008Z Classic Bagged Upright Vacuum
Zanussi aquacycle 1400 fle 1416w started to make an electric arking noise when spinning now. Now it has stopped spinning. Will the motor be dead or will it just be the carbon bushes that need replacing....
Hiya Cheap6... more than likely the brushes.. which are easily checked to see if they are worn down.. otherwise its a new or RE-con motor.
Regards Faggly
Mar 21, 2008 | Washing Machines
Bosch TWIN PACK HEAVY DUTY CUTTING LINES TO SUIT ART26 & ART30 Combitrim COMPARES TO F016800182 Logo
96 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
