The dryer won't start while the washer does start. I have replaced the dryer time and the high temp limit thermostat.
I have a control thermostat also but would rather not lose an arm trying to put the component in place.
  • Washing Mach... Master
  • 5,323 Answers
Sounds like a bad thermal fuse not those other fuses u changed needlessly
Posted on Apr 11, 2015
Is there a way to test the control board?
You need to check element itself to see if it is grounded. That would make it stay on and overheat.
Mar 30, 2016 | Dryers
The dryer was drying, and suddenly stopped and control panel says call technician. Then says door open, won`t start after unplugging to reset it. The inside light stopped working at that time.
It may have overheated. Wait a couple of hours and try again. If it still doesn't work you will need an engineer to diagnose the problem. As it went out during a cycle it could be high limit thermostat or high limit cut out. Both are available on eBay and Amazon. Those parts fail if the dryer gets too hot caused by bad airflow, clogged filters, exhaust pipe or stuck vent slats outside.
Mar 16, 2016 | Frigidaire Fasg7073Lw 7.0 Cu Ft Steam Gas...
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
Have a kenmore model # 110.72822101, where's the thermostat located, my dryer gets hot then cold
The cycling thermostat or the high-limit thermostat may not be the problem but rather the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify this condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Note: This is an image of an electric dryer but the thermostat and the thermal cut-off (cut-out) locations are the same.
Disconnect each of the thermostat wires then connect and insulate them properly. Once done, reconnect power and start the dryer. The gas valve solenoid coils are indeed faulty and both need to be replaced if the problem still persists. Click here for the procedure in replacing the solenoid coils.
Gas Valve Solenoid Coils Replacement Procedure
Either or both of the cycling thermostat and the high-limit thermostat are malfunctioning if the dryer continues to heat up with the thermostats bypassed. Disconnect power then reconnect the cycling thermostat wires but keeping the high-limit thermostat bypassed. Reconnect power then start the dryer. The high-limit thermostat is the culprit if the dryer continues to heat up. If not, then the cycling thermostat is the culprit.
Also do the other way; that is reconnecting the high-limit thermostat wires but keeping the cycling thermostat bypassed. The cycling thermostat is the culprit if the dryer continues to heat up. If not, then the high-limit thermostat is the culprit.
Replace the faulty thermostat and it should solve the problem.
Nov 08, 2010 | Kenmore 72822Gas Dryer
I have a thin twin stacking whirlpool washer/dryer. The high limit switch is kicking off the element within 2 mins of running. So heating element heats up red hot, then clicks off after 2 mins. I have...
I think you are on the right track with a faulty high limit switch. When i serviced these units we always replaced the operating thermostat and the high limit switch together they came in a kit. The operating thermostat in theory should never let it get hot enough to trip the high limit switch, which is really just a safety backup for the operating thermostat. Get the kit and replace both, and also make sure your exhaust vent going outside has good flow at the outside vent,a restricted vent system will cause similar issues.. Good Luck
Oct 07, 2010 | Whirlpool LTE6234D Top Load Stacked...
Thermal cut-off blows and high limit thermostat is working with vent clean.Replaced thermal cut-off, high limit thermostat and heating element. Still blows thermal cut-off.
Any time a thermal cut off blows, it's because the cycling thermostat is bad. When it's bad, the machine cycles off of the thermal cut off rather than the cycling thermostat allowing the dryer to over heat. The thermal cut off is a re-setting safety and is not made to cycle off of. The thermostat you are looking for looks like a high limit thermostat but it cuts power to the element at a lower temp. Around 158 degrees + or - 25 degrees. It's located close to the high limit. It's a normally closed switch that opens on the rise and it will show closed now but the problem with it is that will not open. Replace it and your problem will be solved. Good luck.
Oct 16, 2009 | Kenmore Dryers
My washer/dryer starts to dry and then stops after a short while with an error message - E10 (I think its a 10)
I am not familiar with the Zanussi, but it sures sounds to me like maybe there is a problem with the high limit thermostat. It may be mounted on the side of the dryer. You can check it out with an ohm meter and you should get no resistance. If there is resistance, then the thermostat is bad and must be replaced. It is sensing high temps and is shutting down the machine. This is only a guess on my part, without looking at it. Sure hope it helps you. Good luck.
Jul 16, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Slow to dry cloths
Remove the vent from the back of the dryer and see what the temps are. The cycling (or operating) thermostat is on the blower housing and opens more than 100* lower than the 266 you are reading. That, combined with the long dry times indicates an airflow issue. Check your lint screen....fabric sheet and lint can combine to coat and restrict air flow through it. Also check down in the blower housing with the lint screen removed. You'll see lint build up by looking down the slot with a flashlight. If it's restricted, so is the blower wheel and the blower housing. Also make sure the flap, or lovers at the vent hood outside are opening fully. Remove any accumilation of lint from there.
The high limit control is just that........If you cycling thermostat has failed, or does not open because there is no airflow, the limit control opens as a safety. On a normally operating dryer, the high limit control will never open.
The neptune dryer is designed to move more air than a regular dryer due to the higher capacity load it get's from the neptune washer. That is the case with most front load laundry pairs.
May 06, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Replaced high temp sensor on whirlpool front loader
The high limit thermostat should have been replaced also.
If there are no obstructions that will fix your problem.
Mar 13, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer hets to hot
I would check the temp at your outside vent while the dryer is running temp should anywhere from 180 to 225 at the high end and should cycle down from there so u should get like 225 then will drop down to 90's then come back up to the high temp and check on all temp settings. if it does not your operating thermostat may be bad go back over the instructions that came with your thermostat kit to double check your wiring the tech sheet should be in the control panel with the wiring diagram.
Feb 21, 2009 | Whirlpool LER4634J Electric Dryer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
