Question about Lisle Oil Pressure Sending Unit Socket for GM # 13150
Where is the oil pressure sending unit on a 2010 gmc sierra 2500 hd 4x4 extended cab gasoline
Just got a deep socket 27mm 6 point. Will that still be good?
Oil pressure sending unit
Parts stores have a special socket for the part. It\'s a deep well socket with a large slit on the side for the electrical connector. I believe it is a 7/8 inch socket, not sure.
Dec 03, 2013 | 1997 GMC Sierra
2003 gmc 2500 sierra oil pressure sending unit where is it
Fig. Oil level sensor location on 2002-2005 4.8L, 5.3L, 6.0L
Hope this helps.
Jan 31, 2011 | 2003 GMC Sierra 2500HD
What year/model transmissions will fit a 1989 GMC sierra, 2500, 350 engine, 2-wheel drive? Thanks
A.T., VIN model "C" (4x2), TH400, 6 cyl
A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-305 (5.0L)
}A}}400}466495" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-350 (5.7L)
}A}}400}466496" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-379 (6.2L, diesel)
E>}B}}400}466497" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH700, diesel
A.T., VIN model "K" (4x4), TH400, 6 cyl
B@}}}400}466499" type="radio" name="userInterchange" />A.T., VIN model "K" (4x4), TH400, 8 cyl, diesel
A.T., VIN model "K" (4x4), TH400, 8 cyl, gasoline
A.T., VIN model "K" (4x4), TH700, diesel
FFC}B}}400}466502" type="radio" name="userInterchange" />M.T., 4 spd, 4x2, VIN model "C"
FFC}A}}400}466503" type="radio" name="userInterchange" />M.T., 4 spd, 4x2, VIN model "R"
ECB}B}}400}466504" type="radio" name="userInterchange" />M.T., 4 spd, 4x4, (VIN model "K")
M.T., 5 spd, 4x2
M.T., 5 spd, 4x4
A.T., VIN model "C" (4x2), TH700, gasoline
F=A}B}}400}466508" type="radio" name="userInterchange" />A.T., VIN model "K" (4x4), TH700, gasoline
}B}}400}466509" type="radio" name="userInterchange" />A.T., VIN model "R" (4x2)
Jan 14, 2011 | 1989 GMC Sierra
I have a 2003 gmc sierra 5.3 liter vortec why does my truck leak oil only under pressure
because your oil pressure rises to around 40psi when running and will leak at the weakest place,check your oil sending unit first and seals.
Tim
Oct 20, 2010 | GMC Sierra 1500 Cars & Trucks
Oil pressure gauge goes to 80 psi when the truck key is turned on
chances are your sending unit is not bad. These dashes have had alot of problems with stepper motors failing in the instrument cluster. does it go to zero when key is off? is it erratic? changes where it sits when running and when off? These are all problems within the cluster itself. It is not cheap to take this to the dealer. THey will want to replace the cluster. these clusters can be repaired for half the cost if you know where to go. Not sure yet what the rules are on here but i can repair these for about 325 verses over 600 from dealer and then reproggramming costs! One other note. Chevy has a recall on these! call you local dealer and ask what the criteria is for the recall. You may be able to get it repaired for free if you meet the time frame and mileage requirements.
Jan 30, 2010 | 2005 GMC Sierra
2003 GMC Sierra Knock sensor and oil pressure??
the knock sensors are located below the intake plenum,or,upper intake manifold as some call it, they screw into the lower intake, the front one is sensor 1, the rear is sensor 2. it is wise to change both if you have some miles.since you are going to be buying a gasket set to do this job.the sensors are cheaper than the gaskets.
Jun 12, 2009 | 2004 GMC Sierra 1500 Crew Cab
Low oil pressure
It is a plu located directly above your filter on the oil filter adapter housing.. its about 3 inches long with wires plugged into it.. takes a special little socket to remove it...10 dollars at auto stores for the socket...
Nov 25, 2008 | 1997 Chevrolet K1500
2004 DuraMx dual cab oil pressure guage pegs ''6 o'clock'' running
YES this is where I would start ALONG WITH A MANUAL PRESSURE TEST if Sending unit doesnt and Pressure test is GOOD ,Replace the Meter in Insrtament Cluster
I Have Pics but they will not show up in FixYa
The Oil Pressure sensor is on the Back of engine Looks like Left side 3 wire plug on 4.8L 5.3L 6.0L Can Email Pic with your Address
Nov 13, 2008 | 2004 GMC Sierra
Lisle  Oil Pressure Sending Unit Socket for GM # 13150 Logo
83 people viewed this question
Top Lisle Measuring Tools & Sensors Experts
Billy Mac
Mai Lor
Prariehog
Prariehog
Are you a Lisle Measuring Tool and Sensor Expert? Answer questions, earn points and help others
