Question about Plumbing
I have a spray head that is clogged and won't allow any water thru
There is a locking pin and underneath seems to be a cartridge. Can't seem to get the cartridge out...would this be the problem?
  • Bonard Allen May 04, 2015
    Hi Maureen Holte, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What brand and where located- sink, shower, etc. Also do you have "hard water"?
  • 954 Answers
Yes, a cartridge could clog it. However, if you can't get the cartridge out, try soaking the faucet head in a container of vinegar.
Posted on May 04, 2015
3 Suggested Answers
  • 3640 Answers
SOURCE: I have a pull out
take old sprayer with you and you should be able to get one at a hardware or even at homedepot.most sprayers come apart. maybe the rubber ring is bad on inside of sprayer.
Posted on Apr 21, 2011
SOURCE: can i buy the rubber insert for the head of the faucet which you press for either a spray or straight water flow
YES.TAKE THE OLD 1 WITH U WHEN GETTING A NEW.1 SIZE WILL NOT FIT ALL
Posted on Jan 02, 2015
How do I get more water pressure from a Tuscany model 673-6070 kitchen faucet?
Remove the spray head and clean the filter screen it may have particles of mineral from the plumbing clogging it.
Nov 26, 2016 | Plumbing
I960 won't print despite new print head
Hello!!
Switch off the printer and disconect the USB cable for 30 seconds. deep clean on the black head to get it work properly.
Feb 08, 2008 | Canon I960 InkJet Photo Printer
Uppa baby vista won't lock into place when open
This is what will work. First get some WD-40 and spray it around the jammed locking pin. Give the lubricant 10 mins and then get a knife or flat head screwdriver. What you will want to do is try to pry the locking pin up. Be gentle as you are dealing with plastic and if you break the plastic locking pin your stroller is done. As you slowly pry the pin upwards you will feel or see grooves which you can use to continue to raise the locking pin. Once the locking pin is unjammed push down on it a few times to get dust,dirt or sand out of the locking pin. The pin should pop up freely every time you push down on it and let go.
Hope that helps as I also had the same issue.
Aug 25, 2012 | Vista UPPAbaby - Carlin Stroller
Hello, lost water in the house, now when it came back on, water dispensor has a slow drip (not sure if related)... the dispensor handle seems to be working fine... it dispenses water when pressed.. doesn't...
remove bottom grill.
look for tube which runs thru freezer door.
follow back towards underneath of machince/ find push fit connector.
remove pipe which run thru door from connector and blow thru quite hard. reconnect and press dispenser paddle to allow water back thru
this shhould solve problem in 9/10 cases if it doesn't then you will need your water inlet valve checked
Jan 27, 2011 | Whirlpool Refrigerators
Done all the things you advise to clear the print heads, it seems to relate to the large back cartridge, ink flow seem ok, sponge pad at base of cartridge moist with ink. All other inks fine on test print....
Yes, the print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0075.
Nov 13, 2009 | Canon MP610 Photo All-In-One Printer
Printer prints most yellow when it should be black
sory for possibly insulting ur intelligence, but you have the proper cartridges in the proper slots? If you do, have you tried using your printers program to run a diagnostic test?
Jul 15, 2009 | Canon BubbleJet i560 InkJet Printer
Inkjet printer
Your inkjets are clogged, use a damp sponge to clean heads (located where the bottom of the cartridge is) put a paper towel underneath the cartridge holder to soak up water, allow to completely dry then run ink test (head cleaner) through printer utility...its worked multiple times for me
Jan 25, 2009 | Epson Stylus C62 InkJet Printer
Bissell Proheat does not spray water along cleaning brush. Seems to spray just down either side only.
Are the brushes turning? If not then that could be your problem. If they are, check the spray nozzles, they may be partially clogged. Try water a mix of vinegar and water thru it to see if it will unlog your kines and spray nozzles.
May 06, 2008 | Vacuums
Bissell Spot Lifter
ok - this works even though it probably isn't the "best" solution. Unclog the input and output nozzle ares with a pin. The input area (behind the solution) was my clog problem - I put 2 or 3 drops of CLR into the hole, waited 5 minutes, then primed the trigger. This unclogged it! Fill the tank with a 1:1 ratio of white vinegar and warm water. Insert tank into unit and spray out the contents into the sink. This will eliminate any leftover CLR residue and clean the nozzle thoroughly. For the intake (suction part of the tank) I just rinsed through the lines with the vinegar mix and it seemed to unclog the rest. These things are a pain to take apart and if you break any pieces you'll be stuck - replacement parts have been discontinued for older models.
Feb 29, 2008 | Bissell 1715-G Spotlifter Bagless Handheld...
Plumbing Logo
240 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
