Question about Apple MacBookPro 13.3 Laptop i7 2.8GHz 4GB *No HD DVDRW
I want to print from laptop to printer - Apple MacBookPro 13.3 Laptop i7 2.8GHz 4GB *No HD DVDRW
Right i have new laptop have loaded up disk for printer, and when i click print on laptop it prints something else that i printed last time i used the printer. it is a bx300f thankyou
Check what is in your print queue before printing. If a document fails to print completely it may remain in the print queue even if you turn the laptop off.
Feb 16, 2011 | Office Equipment & Supplies
Wifi laptop will not print to printer - not a wifi printer
Check if the printer has a wireless option. Actually this issue is complex. First thing first, you can print wirelessly from your laptop within the WIFI range in a case that your printer do have wireless on in. It is impossible to print wirelessly from the wired printer through LAN.
One thing, I guess you don't have a wireless router. You need to have a wireless router like LINKSYS that is easy to setup then try to connect wirelessly to the wired printer. There I am not too sure if your can do a printing option from your laptop wirelessly.
Lastly, check if you have a ROUTER and need to set it up on your laptop and on the network LAN. You may now have a NETWORK printer in this regards. Thank you.
Oct 06, 2009 | HP Compaq Presario V6000T Notebook
I have a Toshiba Laptop that wont work with any printers
have you checked the paper settings that the printer prints? often the printer has letter format as first print options, and then it doesent work. you need to change it to A4 in printer settings.
What happends when you trying to print ?
Sep 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer status says offline, and we can not print on laptop
Hi!
If you're offline with the printer, you definitely won't be able to print.
I'm assuming you're using Windows XP here. Most Windows products will be similar...
On the laptop, click on the Start button, then Settings, then Printers and Faxes. Find your printer in the list, right-click on it and click "Use Online" or uncheck the "Offline" box.
Good luck! Remember to rate the solutions!
Aug 10, 2009 | HP Officejet 6500 Wireless All-in-One...
Lost cd for laserjet 1320 cl6 printer. installed
either the usb wire is getting loose in the new laptop port.or the port is faulty.press the usb wire tightly and then try printing keeping it pressed at the laptop side and printer side too.with some bodies help. check out.
Jul 12, 2009 | HP LaserJet 1320 Printer
Cannot print from laptop to printer using wireless print server
This is probably the Software Firewall on your laptop
you should probably tell your firewall software that you have an internal network (Laptop-desktop-printer) you should add the IP range of the wireless network as a trusted network.
May 25, 2009 | Lexmark X3550 ALL-IN-ONE InkJet Printer
Dell 948 printer printing not finishing print jobs
Your printer loose documents:try to reset it ,unplug for an hour.
Or you might have interferences on your wireless :DECT phone, cell phone, or even an electric device who doesn't work propely, like tv, stove, speakers many things can parasites your connection...
If nothing does your printer as issues, think replacement...
cheers
Dec 19, 2008 | Dell 948 All-In-One InkJet Printer
Printing
If you want to print from your laptop to your desktop you can Share your printer on the desktop. Then when you add the printer on your laptop, choose "Networked printers" and as long as you are on the same network, it should show up
Apr 04, 2008 | HP Deskjet 6980 InkJet Photo Printer
Apple MacBookPro 13.3 Laptop i7 2.8GHz 4GB *No HD DVDRW Logo
258 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
