Question about Refrigerators
Plugged in sylvania mini fridge but can not hear the pump or motor working. There is power because the light inside works. Not sure if there is a reset or something.
  • Refrigerators Master
  • 473 Answers
Has to be a control to turn on somewhere. On some min units it on the back outside. On some its inside mounted to either the left or right side or center back wall. If electronic control maybe top front above the door.
Posted on Apr 11, 2015
Fridge stopped working light on motor not running
Robert,
Need more info. I am unaware of a "light on the motor". There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. Normally none of these have a light. If you are referring to the light inside the box that turns on with opening the door AND the frig is not cooling, we must go to the very start. 1. Verify power at outlet.
2. Do you see (or inside the box- hear) the two fans running. 3. Is the compressor smoothly vibrating?
Oct 12, 2013 | Smeg FR158SE 1 Compact Refrigerator
Galaxy mini fridge stopped working
The thermostat, which is also an ON_OFF switch has failed (@ 99% probability).
No, the little fridge doesn't have a pressure switch to turn the compressor off when freon is low. And no, auto freon is the wrong kind and it wont work in the little fridge. The freon that your little fridge uses is the stuff that all the fuss has been about (with the ozone layer), so it is not sold to appliance owners but only to licensed techs.
If this is helpful I hope you'll take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Koolatron Mini Fridge Compact Refrigerator
Mini cooper convertible top won't go up
do you hear hydralic motor if not use test light while operating control switch up and down position, you need a helper for this procedure.if power is at switch, see if power at hydralic motor while helper work the control switch, if no power at motor hook test light to good ground if no power at hydralic motor check fuse.if power at hydralic motor and you hear no sound hydralic motor bad.if power going to control switch and not to hydralic motor either control switch bad or you have broke loose wire at switch going to motor.if all electrical system okay and when you work the up switch and hear hydralic motor running your hydralic fluid level low reason why convertible top not going up.check fluid level at the side of the motor and pump you should see screw type check plug.you should have see through side reservoir fluid level should be between min and max marks.if fluid is low check for leaks at the pump hoses and hydralic cylinders.
Nov 27, 2011 | Mini Cooper Cars & Trucks
Refrigerator was bought 5yrs ago(brand new)it worked perfectly until then....put it in storage 4 six months...when i moved it into my house i plugged it up...can hear it on but yet to get cold....left it...
Hi
Is your fridge compressor motor working and can you hear it turn on and off every hour or so. Not to be confused with the sound coming from the fan inside the fridge.
If the motor is working but neither the fridge or freezer compartment are getting cold, then there may have been a rupture during transport and gas has escaped.
Ash
Sep 02, 2011 | Hotpoint Refrigerators
My frost free, Admiral, side by side freezer just stopped working, i plugged it out for two days and when i plugged it back in neither the freezer or fridge works. Its actually warm inside both sides and i...
Whoops
The fridge has a refrigerant leak, or the thermostat has failed.
Try replacing the thermostat, if that does not work then you will need to call a technician in to find and repair the refrigerant leak and regass the fridge
Mar 30, 2011 | Admiral 26 cu. ft. Side-By-Side...
Sanyo SR-3660 Mini fridge doesn't run
How long was it in storage?
A fridge doesn't like to be laid down then stood up and plugged in. Reset the overload circuit.
Aug 07, 2009 | Refrigerators
Fridge dont run
if all fan working check compressor call service
Mar 31, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
