Question about Moultrie MFH-DGS-D55 - Game Spy D55 MFH-DGS-D55
Flash not working any more, how to fix
Trail cam
.Can not take pictures at night with my Moultrie 1100i trail cam. I was informed that there are numerous SD cards that should not be used.
Not being able to take pictures _at night_ likely has nothing to do with your SD card. If the SD card works during the day, it should be fine at night, too.
Any camera needs some light to take pictures. Many use flash to take night time pictures, or infra-red (IR) lighting. I don't know your camera well enough to know if you have either or how to configure how to turn that on.
Nov 11, 2015 | Max Electronics - Others
Can i play a video from a sb card on a iview 105hd
Probably the wrong format. Use your PC to convert the video. DVD players usually handle AVI files, and sometimes DiVX. The resolution coming off the trail cam might also be a problem. DVD players handle files with a native resolution the same as DVD 720x576 or 720x480.
Check the manuals for both devices to see if there's some common ground of file format and resolution.
Sep 18, 2014 | Iview "NEW" 105HD 1080P All Region DVD...
When is tasco trail cam model #119256cw actually turned on
I can't see why you'd need to, but it can't hurt. The settings on the camera will be preserved as long as the battery's are left in.
Jul 22, 2014 | Tasco 3 MP Trail Cam Game Camera 119213C
How can I set this camera up to overwrite the images on the SD card?
For many of these types of Trail Cams, you cannot instruct it to overwrite images, you just need to reformat the SD card using the camera's menu option for that function.
May 15, 2014 | Simmons 119422C ProHunter Trail Cam 6mp...
5210A camera not working
What kind of 'nothing' happens? The camera is designed to be stealthy, so don't expect noises or lights. Slide the switch all the way from TEST to OFF. Then slide it from OFF to ON and close the cover. At this point you should see a red LED flashing just 8 times (to tell you it's working) - then nothing.
This link has good tips: http://www.google.co.uk/url?sa=t&rct=j&q=troubleshoot+ltl+acorn+5310+no+video&source=web&cd=3&cad=rja&uact=8&ved=0CC0QFjAC&url=http%3A%2F%2Fwww.ronburyswildlife.com%2F2012%2F09%2Fltl-acorn-5210-and-6210-trail-camera.html&ei=Uox0VKPqDsblapjLgMAC&usg=AFQjCNEy5FUsjkrJuIb-kjektR_p3lW94A&sig2=7K1t-I9WL-AWU0idlZmHag
Mar 07, 2014 | naou_china Ltl Acorn 5210a Ltl-5210a Low...
Moultrie i40 digital game camera will not flash
run diagnostic test and cover sensors with thumb...may have to shade IR flash array to see it glow red...menu may start countdown...if flash doesn't glow you will get a 020000 error(flash/flash charging error).To fix you need to remove batteries,sd card,rubber plug from remote slot, 5 screws from face;lift out face and turn over. Remove 4 screws, keeping separate from other screws, from camera card and carefully unplug (3 plugin connectors) and carefully lift camera card out..no soldering required up to now..2 conductors,a red and a black, connect to the flash array at one corner...these go to the sensors on the face,slightly under main board...either the sensors are bad or the array is bad...getting replacements is the problem unless you can get them...I buy "as is" cams off eBay.
Dec 14, 2011 | Moultrie I40xt I40xt Trail Camera 50 Mp
Range on my trail cam is not very far would like to know how to change this
Range on a trail cam is maximum 45 feet, in perfect conditions. 20-25 is more realistic. Are you getting that kind of range?
Jun 18, 2011 | Tasco 3mp Trail Cam Black-cameras
I currently bought a tasco 3mp game camera at walmart works fine in the daylight but flash isn't working am I DOING SOMETHING WRONG OR IS IT A DEFECT
I, too, recently purchased this camera. The Chinese got us this time. My flash works, but it seems like nothing else does. I'm a scientist. I got if figured out. And, what I figure, is this trail cam is a piece of ****. Nothing on the packing is remotely true of the camera.
Sep 01, 2010 | Cameras
Moultrie MFH-DGS-D55 - Game Spy D55 MFH-DGS-D55 Logo
132 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
