Question about Dyson DC39 Multi floor canister vacuum cleaner
The roller stops as soon as machine turns on, then air leaks with poor suction. How do I fix it?
  • Official Brand Answer
  • 2,572 Answers
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your DC39 Multi Floor, but from what you've described it sounds like your machine may have a blockage in the floor tool, wand, hose or inlet duct. This is simple to resolve by following each of the steps shown in our video guide:
If you continue to have issues with the suction performance or the brush bar in the Triggerhead floor tool after checking for and removing any obstructions, our experts are on hand to help you further. You can reach the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Posted on Apr 15, 2015
Ihave a canister vac. Bought last april low suction
Have you cleared the vacuum hoses
Dec 01, 2016 | Vacuums
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ā€ˇReview by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
No suction
I presume the motor is running, take the front brush roller off and check the fan is still intact. Possibly broken fan.
Mar 30, 2014 | Kirby Ultimate G Bagged Upright Vacuum
Suction stopped. Roller and belt working-in fine order. Checked hoses have not found any blockage. Blowing out air or sucking so little can't feel it with hand on hose end. Help!
Either a blockage or the main air filter is blocked , some it can be washed and others it must be replaced
I would check the owner manual and look at the filter, foam ones can and usually have instructions where they install to wash them.
Dec 11, 2012 | Hoover Tempo Widepath Upright Vacuum -...
Dc 24 roller brush quit working....belt is okay & there are no obstructions on roller or in head compartment & suction at head is strong
Hi there, sometimes a stretched belt will hamper the vac. from picking up. he best way to test this is to turn the machine on, then carefully put you hand on the roller. If the belt is stretched the roller will stop turning when you apply pressure. Hope this helps, Chris
Feb 09, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Suction not working
Ok first thing to do is remove & clean the 2 piece premotor filter or purchase new.
Now remove soleplate from bottom of machine to do this rotate the 3 plastic screws to unlock position. Lift sole plate off now remove any blockagers or fluff that may be built up over the brush roller.
Remove hair from brush roll using scissors.
Check short clear hose for blockages & any damage rips or tares if it is damaged purchase new hose.
Now look at belts & rotate brush roller it should turn relatively easy if it is difficult to turn by hand remove the brush roller & pull off the end caps the axle will come out with one of the caps.
Check the roller bearings clean away dust build up replace end caps & axle spin roller holding on to end cap if freely to spin refit back on to machine.
If its stiff to rotate you will need new roller.
Now pull off the 2 inspection ports check them for bits of paper etc especialy the (U) shaped port at bottom rear of machine this can contain pens pencills stones all sorts of items that hinder the suction.
Now check the long flexi hose & metal wand for any obstructions.
If after all this machine is still not working correctly go to this site http://dysonmanuals.llc.nu/
On this site you will find Dyson service manuals covering poor suction, clutch,motor, etc.
Chris...
Sep 25, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction
Chris...
Sep 24, 2008 | Dyson DC07 All Floors Bagless Upright...
Suction loss on dyson animal
Hi.
Keep the axe on hold try this first.
Chris...
Sep 21, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC39 Multi floor canister vacuum cleaner Logo
108 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
