Question about Samsung 5.8 cu. ft. Slide-In Gas Range w/ Intuitive Controls - Stainless Steel
There is no sound from the display. I already turn on the sound option but there still isn't any sounds.
  • Samsung Master
  • 473 Answers
Most electronic range controls the beeper is built into the main board. If you are sure its on--then the board would need replaced to fix it. I don't think there is any other option.
Posted on Apr 11, 2015
Dynex dx-40l150a11 tv turns on and says "Please Wait" after that goes blank with no sound or video. Changed main board and power board already.
Sounds like a software corruption. Just check it by updating its software [firmware]. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 16, 2013 | Dynex Televison & Video
Sound isn't working on my tv
Check its speaker first. Check whether the sound is muted. If all are OK, check and replace its audio output card. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
Apr 29, 2013 | Sanyo Dp50741
Overtime sound on computer decreasing.
Make sure that the sound source (iTunes, Youtube, etc...) is turned up, then check the speaker icon in your system tray (bottom right), and make sure not only that the sound is turned up for output and all the available options (CD, web browser, etc...), but also if your machine supports sound themes, make sure that it isn't on any kind of quiet preset.
If none of that helps, check that you're getting sound from both sides of the laptop. There might be a loose connection inside the machine. Also, if using headphones or external speakers, the jack will need to be plugged in all the way.
If you are using speakers that are not passive, they will need to be plugged into power, or the sound will be quite low.
Nov 07, 2012 | Dell Inspiron 1750 Laptop
I have no sound on my vizio tv
Make sure the mute button isn't on. Also sets give you the option to turn off your "on board" speakers. If applicable, make sure this option isn't turned on. Identify if this affects all inputs, and depending on your setup, check you source. Make sure it is in good working order and that your connections are correct. Outside of this, sounds like your set will need to be serviced.
Sep 09, 2012 | Vizio Televison & Video
No sound
Make sure you do not have "mute" turned on. Also, on some TV sets, you have the option to turn off the internal audio (your speakers)and enable the audio out terminals. Make sure that this isn't the case. Outside of this, you could be looking at a internal failure.
Sep 03, 2012 | Televison & Video
I turned on my t.v. and there was no sound
First thing, make sure the mute feature isn't on. If it is not, go to menu and look for a feature that lets you choose whether you can use external speakers or internal speakers. Some newer sets have this option. If your set has this option, make sure your internal speakers are turned on. If this isn't the case, you could have fault in the 12vdc/15vdc section of your power supply board or on the mainboard of the set.
Sep 24, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
My iPhone 4 sound isn't work like the clicks when
The problem you have is probably a sound option problem. This is uncommon, but very easy to fix!
To fix:
Turn on your iPhone Unlock it (put in passcode if applicable) Look around, find the app "Settings" Click it, and look for Sounds In Sounds, scroll down, and make sure that "Lock sounds" and "Keyboard Clicks" are switched on, and blue.
If this doesn't work, you've got a speaker problem.
Have a nice day!!
Jul 17, 2011 | Yahoo iPhone Apps
How do you turn the printing sound off as you type?
If you are talking about a beep on each key depression CODE "S" if you are talking about the printing noise you must have the display option, if this isn't a WW6 but a WW30 ets there is a key in the right thst says print mode.
DickyO
May 03, 2011 | Lexmark Wheelwriter 6 Series II Typewriter
Problem setting up DVD home theatet sound system sc-pt460 with my vierra panasonic TV. The two appropriately connected with HDMI plus Optical cables. Mainly wish to use it improve TV sound. Have got it...
to see the dvd sound menu option you must be on the correct input selection for your tv. ie. if its Scart, then AV1, or if HD then HDMI 1 etc. then you see the options. as for sound being variable, you can adjust the sound for each speaker in this mode. Main thing for having surround sound with normal TV is to turn on the sound enhancement mode. also, on your viera link on the tv remote, make sure sound its selected as home cinema. word of warning, leave dvd on D-In option, and when turning the TV off, use standby mode, which turns both systems off, ensuring the link does not break.
Aug 18, 2008 | Panasonic Televison & Video
External Microphone - Not working
ok sir .....if u r using vista then click on start and then click on the the start search option and type in sound and hit enter ......it will take to the sound proprities,,,,,then click on the option that select the option that says microphone click on it and select the option that says configure....... and then select the option that says test clcik on next and then ur microphone isn ready to work....
Apr 15, 2008 | HP Compaq Presario V2000 Notebook
Samsung 5.8 cu. ft. Slide-In Gas Range w/ Intuitive Controls - Stainless Steel Logo
93 people viewed this question
Top Samsung Kitchen Ranges Experts
Stephen
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
