Question about Garmin nuvi GPS
Only turns on when connected to a power cord but does not go pass the logo screen with copyright info.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
I have the identical symptoms on a 2797 and can not get past this screen. I have charged it with the genuine 12v power cord and the battery last about two hours but still will not get to the map loading stage.
Kevin H
Posted on Apr 19, 2015
2 Suggested Answers
HarryHarley
  • 343 Answers
SOURCE: Garmin Nuvi 260W will not start up. When not
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If the device does not power on it could be a result of a extremely low battery. Please ensure that the device is receiving a charge while it is connected to the vehicle power cable. If the battery is receiving power from the vehicle power cable then the battery icon (located next to the time) would disappear from the Main Menu. clip_image001.jpg clip_image002.jpg
If the unit does not power on while attached to the vehicle power cable please follow steps from below to perform a soft reset:
  1. Connect the device to an external power source1
  2. Slide and hold the power key to the on position for 15 seconds
The device should power on. Notes:
  1. Preferably the vehicle power cable or a USB cable from a computer
  2. Some of the older Nuvi 200 series will have a reset button on the bottom of the device. It can be found on the bottom of the device on the same sticker that the serial number is printed on.
If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
Posted on Jan 17, 2010
My Apple ipod nano 16 GB MC694LL/A is having volume issues, it will only stay on one level and if I try to turn it down it will not go back up and if I try to turn it up it will not change. Also my screen,...
Hi - Sounds like it may need to be reset. Here's how:
  • Connect your iPod to the power cord for at least ten minutes before resetting.
  • Reset the iPod by holding down the Sleep/Wake button AND the Volume Down button - together - until you see the Apple logo appear. When you see the Apple logo appear, let go of the keys.
  • Connect the iPod to your computer and make sure it appears in iTunes.
See if that helps. If not, leave another message - there's another procedure you can also do, but it's a little more complicated.
Oct 29, 2013 | Apple MC694LL/A iPod nano 16 GB
Tip
IPod Nano/Video/Touch Resetting
One day your using your iPod and all of a sudden, boom. It turns off and refuses to work or read by your computer.
You might get the apple logo, but thats where it ends. In this case, theres a few things that can probably bring you device back and kicking.
iPod Nano/Video(Classic)
6th Gen Nano
Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
4th and 5th Gen Nano/Classic/Video (CLICK WHEEL VERSION)
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
In case the reset does not work, the alternative is to connect the device in disk mode and restoring it.
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears. zero77cool.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
This will enable a black/white display. Restore it using iTunes.
If the above doesnt work, then Im afraid its time to repair your device.
Note: images and part of help copyright © 2011 Apple Inc. All rights reserved
on Mar 13, 2011 | Electronics - Others
My LG55LE5500 suddenly stopped working this morning. Last night, we switched it off in proper working condition. This morning, when we switched in ON, only the initial LG logo screen comes and stays there...
Check whether the product is turned on. I Try another channel. The problem may be with the broadcast. I Is the power cord inserted into wall power outlet? I Check your antenna direction and/or location. I Test the wall power outlet, plug another product's power cord into the outlet where the product's power cord was plugged in. From the LG manual kolbrun
Sep 18, 2013 | LG 55LE5500 55 in. HDTV LED
Help please, just replaced lid on emachines d620, all went well, just turned it on and screen is completely black. The logo shows very feigntly as it powers up, boots up fine but completely black screen.
It sounds like the cord connecting the lcd screen to the laptops motherboard has been disconnected. You will probably have to disassemble the screen portion of the laptop and reconnect the power wires.
Jun 28, 2011 | Computers & Internet
Screen is blank (white) when turned on.
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Turn off the system. Unplug the power cord from the mains. Keep the power button of the cpu (not the monitor) pressed for 5-6 seconds. turn the unit bcak on and check.
Please reseat the monitor cable that connects to the desktop ensuring a secure connection.
Further, if you are able to see the Lenovo Logo on startup try booting to safe mode by tapping F8 key on the lenovo logo itself.
Howevre, in case you are not even able to view the lenovo logo on startup, then it could be a fault with the lcd monitor itself requiring a repair.
Nov 17, 2010 | Lenovo L191 (Black) LCD Monitor
My Dell Inspiron 1545 on Windows 7. After a system restore will not start. You switch on, The Dell logo appears, then the screen stays blank except for the cursor arrow which remains and can be moved...
Power drain your computer, remove all the accessories connected on it, including battery and power cord then press the power button for 1 minute.
Connect the power cord then turn on the computer.
This is a possible Operating system corruption and it needs a complete reloading of your operating system or reformat your HDD and install the OS again.
May 15, 2010 | Computers & Internet
Have a gateway Mt3708 it started turning off on its own now I have no screen. I had gotten message reading as follows: YUKON Pxe V4.17.8.1 (alpa) (20060116) (C) copyright 2003-2006 Marvell (R) all rights...
when the logo comes on, press the "tab" key. It should turn the logo off and show you what the computer is doing. This may help:
THIS IS FOR HP AND COMPAQ USERS (it might help others as well)
i had the same problem with my compaq preasrio v6000.
ALL U HAVE TO DO IS
1- START UP UP UR COMPUTER AND PRESS F10
2-GO TO DIAGNOSTICS
3-RUN A HARD DISK TEST
IF IT PASSES THEN YOU JUST NEED TO RE-INSTALL TO YOUR OPERATING SYSTEM
IF NOT YOU WILL HAVE TO CHANGE YOUR HARD DISK.
Or try this:
Go into the BIOS.. Go into the BOOT options.. and hit Shift+1 to disable the Realtek boot option.. pop in the disk you want to boot from.. and make sure you set your boot options to CD-Rom and then HDD.. and just wait.. be patient.. and the blue screen (for booting) will show up! :)
Mar 15, 2010 | Computers & Internet
ITouch screen frozen on USB and ITunes
ipod touch only reads apple's usb cord are you using apples usb cord
Jan 11, 2009 | Apple iPod touch
Unable to boot
pls give the following detail
model of notebook
is not able to boot into any of the mode??
May 19, 2008 | Toshiba Satellite A25-S207 Notebook
Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
GPS Logo
244 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
