Looking for a wireing diagraam for a whirpool washing machine model # cx2640045 # Mzwc6sewed have one wire harness with a red cover on it And i don't know where it plugs in.. help?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Sounds like a live of some sort check inter lock pump element inlet valves capacitor and the list goes on
Posted on Apr 13, 2015
vest6
  • 196 Answers
SOURCE: installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
Posted on Jan 13, 2008
SOURCE: whirlpool duet washing machine door lock error
My front loader has the door locked and I can't open it. I have already turned off the power and that didn't solve the problem. The manual says that if you try to open the door too soon after the cycle completes, then the door locks. How do I open it now? What do I do?
Posted on Jul 03, 2008
SearsTechToo
  • 261 Answers
SOURCE: GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Posted on Oct 03, 2008
SOURCE: Bosch Model WFB 1605 washing Machine
Hi
I have a user manual - swedish, Suomi, Norwidian and danish
Posted on Jan 21, 2010
erpaalai
  • 999 Answers
SOURCE: washing machine lint trap
There is no trap per say. The lint catcher is self cleaning when the water is pumped out. It sounds like you are overloading it and the clothes are hitting the agitator. Operation should be agitation by water movement not beat by the plastic fins, run a wash cycle hot water no clothes to flush things out and try smaller loads.
Eric
Posted on Mar 14, 2010
F6 error code whirpool duet
The F6 error code for this model indicates a drive motor tachometer error. The control board is unable to properly detect the motor speed.
Jan 09, 2016 | Washing Machines
I need an electrical wiring of my whirpool washing machine model AWM243
it is inside the washer, take the control panel apart and the wiring diagram is inside
May 03, 2012 | Washing Machines
Hi i have whirpool awm 8900 and i have fault f11 what is this?
In your service manual it states for the f11 code
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
If you have any further questions message me back I await your reply Thanks again Rick
Jun 20, 2011 | Whirlpool AWM8000 Front Load Washer
The washer does not run through the wash cycle. The door locks but nothing further happens. There is an "LE" error message but I do not have a manual that explains what that means. Please help.
The LE error message means locked motor error and it is almost always accounted for an out-of-order Hall Effect Sensor. Other causes includes defective Main Board and broken wiring harness.
To check the Hall Effect Sensor:
  1. Unplug the machine.
  2. Remove the top plate assembly by unscrewing the two screws on the back of the top plate.
  3. Look for the Main Board assembly on the rear left side of the machine.
  4. Remove the power connector and sensor switch assembly.
  5. Remove the Main Board assembly protection cover by releasing the latches along its sides.
  6. Look for the 4-pin white connector with white, gray , red, and blue wires. It is the wiring harness going to the Hall Effect Sensor. Disconnect it from the board.
  7. Using a multimeter, check the resistance between the white and blue wires and between the white and red wires. Resistance should read about 10k ohms.
  8. If either resistance reads open, check for a broken wiring harness and repair or replace as necessary. Otherwise, the Hall Effect Sensor is defective and must be replaced.
  9. If the tests above show that the Hall Effect Sensor seemed to be good, you have to check if the Main Board delivers 10 to 15 Vdc supply to it.
  10. Reconnect the machine to the power outlet.
  11. Press POWER but DO NOT PRESS START.
  12. Set the multimeter to DC volt and measure the voltage between white and gray wire terminals on the Main Board. Voltage should be 10 to 15 Vdc. Otherwise, the Main Board is defective and must be replaced.
  13. Connect the red test lead to the red wire and the black test lead to the gray wire.
  14. Turn the motor rotor slowly by hand.
  15. You should measure a pulsating 10 Vdc if the Hall Effect Sensor is okay.
  16. Repeat the step with the red test lead connected to the blue wire.
  17. If you measure a 10 Vdc but not pulsating, the Hall Effect Sensor is defective and must be replaced.
Feel free to inform me if the Hall Effect Sensor or the Main Board needs to be replaced and if you want to replace it yourself.
Dec 31, 2009 | LG WM-2277HW Front Load Washer
I need to know what f06 error code is on a whirlpool washing machine
As per Whirlpool, this code refers to :-
Drive Motor Tachometer Error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
Causes/Repair
1.Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
2. Check the Drive Motor 3.
3. Check the MCU
4. Check the Wire Harness
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 14, 2009 | Washing Machines
F11 alert in the Duet Whirpool Front Load Washer
F11-Serial communication error
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.(you can find the location of CCU and MCU through the manual)
All the best,
sunny
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool waher
f/06 is a drive motor tach error.
Check wiring harness, drive motor,mcu.
and check that the drum turns freely
Oct 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have to change the plug on a whirpool drier as the wall plug at the rented house is different. i have bought the new cord to install and when i took the cover off the old wiring, all wires are grey and...
ok on the terminal block looking in from the back you have 3 terminals on your new cord there is a Black a red a white and a green the Black goes to the far left terminal the white goes in the center terminal the red goes on the left terminal the green goes to gound or a green screw on the back of the unit if there is not a green screw then use the screw that holds the cover plate on
Aug 20, 2008 | Dryers
Installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
Is there a white or black connector that clips on the motor switch? it should be an easy unplug and plug the new motor in.
I dont of any Manufacturer that uses single wire connectors any more.
Are you sure you got the correct motor?
Apr 22, 2008 | Maytag Legacy Series Top Load Washer
Jan 10, 2008 | Maytag Performa PAV2200
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
