Question about Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer
This front load washer is unbalanced all the time and shakes the whole house. Is it worth it to fix it?
  • Amana Master
  • 5,323 Answers
Yes of course it may simply be a balnce problem, the legs need to be re adjusted. I use a level to check the balance. adjusting each leg accordingly, another thing it might be is that the counter weights balance rods are needing replacing or re greasing with lithium bases greased
Posted on Apr 11, 2015
  • 1 more comment
  • E grodz
    E grodz Apr 11, 2015
    Thanks, I'll check the level first. I'm suspecting that it has to with more than simple level. Counter weight balance rods...didn't think of that. Not sure what you mean by "re greasing with lithium bases greased" Thanks for the reply
  • Jorge Rendon
    Jorge Rendon Apr 13, 2015
    WELL SOME COUNTER WEIGHT RODS DEPENDING ON THE TYPE U HAVE CAN BE REGREASED THE LONG METAL ROD HAS A TUBE THAT MOVES UP AND DOWN WITH A WASHER TYPE COVER, U SIMPLY PUT MORE GREASE IN THEM THEN CLOSE IT BACK UP
  • Jorge Rendon
    IF U HAVE CONCRETE COUNTER WEIGHTS THEN UR PROBLEM MAY BE A BROKEN WEIGHT THAT NED RAPLCING
How do I fix a front load washer that shakes violently on the last spin cycle?
CLOTHES UNBALANCED? OR COUNTER BALANCE SUPPORTS BROKEN, AND NEED REPLACMENT? WASHERS have many different weight balancers but sounds like u need to take body off and have look at the counter weights set up while running machine, just jumper the door switch to keep a closed line. and then agin sometimes its as simple as making sure ur washer is leveled on ur floor, check ur leg adjusters as they do get funny at times..
Sep 13, 2014 | Washing Machines
Stackable washer and dryer. The dry shakes when the washer is on spin cycle.
The washer spins real fast and can shake like he**. The load can also be unbalanced.
Jun 14, 2010 | LG WM3431 Front Load Washer / Dryer
Washer has worked great for almost a year but now all the loads seem to be unbalanced. It doesn't matter if they are large, small or on any particular cycle, they all sound unbalanced and shake my house...
The motion dampers that control the outer tub's movement within the cabinet may be loose or damaged. Lift up on the inner drum when the machine is off to see if the drum moves with a 'clunking' sound which would indicate a bad drum shaft bearing (not a cheap fix). If it seems ok, remove the top and back panels to check the action of the dampers when the outer drum is shaken. Hope this helps!
Jan 07, 2010 | LG WM2487H Front Load Washer
Shaking
Most common cause for the machine to shake during the spin cycle is due to a unbalanced load. A load of a couple of small bulky items or a small load in general may not be able to distribute the weight properly causing the machine to be unbalanced. It is best to wash full loads whenever possible. We have a brand new front loader as well, our first load about took the walls down...We just tossed a couple things in to see how it worked....thats how I learned to wash full loads. Now with the knowledge of why it shook so bad, we have had no more problems. Hope this helps
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machine Shaking
Please take the time to give this a fix ya rating
clarkco
New front load washer shakes my whole house
remove the shipping material...read install instructions that came with owners maneul
Dec 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Hot point WD440 wash/dry :How to put tumble spin off.
i know this may sound stupid but did you follow the instructions on removing the Transit Braket? with tht un removed it will cause the machine to "Dance" around the room
Jan 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Unbalanced load
If your washer goes severely off balance you need part # W10112113 to fix it.
Nov 25, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer Logo
95 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
