Question about Intex Pool & Spa
Something seems to be wrong with my pump in my spa.
The pump has a very high pitch sound while running. I also cant seem to read the digital display or change functions or modes. I was thinking if there was a problem it would display some kind of code.
  • Intex Master
  • 1,631 Answers
A loud, grinding, screaming, or screeching pump motor, will not show up on your Pumps Control Panel, with a fault code. Your bearings in the motor, are shot. And you will need to replace them, or the motor.
2nd possible problem - sorry : (
if nothing is displaying on your topside control panel, then your topside Control Panel appears to be bad, or the fuse that operates it has been blown. If there is a display in the readable part of the panel, but you have no access to make anything work, then you have some dead buttons, and once again you have a bad topside control panel.
Posted on Apr 13, 2015
What is making this 08 caliber 2.0L sxt cvt have a High pitched whining sound at idle and driving?
Possible bearing in one of the drive pulleys. I have changed numerous alternators for this noise. Take the belt off and start the car. If the noise goes away you know it will be pulley related and not transmission related. If noise goes away, spin all pulleys by hand to determine the defective/noisy one
Aug 03, 2015 | 2008 Dodge Caliber
There is a high pitched sound coming from under my 2002 Jimmy. It seems to be originating in the vicinity of the fuel tank, catalytic converter, differential area. But I cannot isolate it. Possibles?
Fuel pump in the tank makes a high pitch sound which is normal. Turn your key in the ignition, but don't start, you should hear the high pitch sound with the pump priming the system. You will still hear it when started, it's annoying but normal. Different brands are quieter than other, I just replaced mine with a Delphi brand fuel pump which is a tad quieter than AC Delco stock pump.
Mar 16, 2014 | GMC Jimmy Cars & Trucks
Hot watertank puts out high pitch sound
It is probably the water passing through some restriction such as a valve or maybe a T or 90. If this is correct changing the water flow will change the pitch and it will be absent when there is no water flow.
If that doesn't change or eliminate the high pitch sound I do not have a clue.
Jan 09, 2014 | American Standard Water Heaters
1985 toyota mr2 engine noise
It still could be the throw-out bearing. When going bad, they have a high pitched whine or whistling, and if bad enough, could imitate a vibrating sensation. IDK, I would have a mechanic there listen to it.
Jul 12, 2012 | Toyota MR2 Cars & Trucks
My whirlpool duet is displaying the error code 888. It works ine through all cycles but the time displays 888. All the lights are illuminated and there is a high pitch alarm sound that remains on until...
Please state brand and model of your washing machine for accurate and specific solution...
There is no 888 error code on my list of whirlpool..I think the 888 flashes is the time remaining..
If the lid opens while the unit is in running mode, time remaining will flash in the display.
Close the lid and press START to continue with the cycle.
Hope it helps..
Dec 03, 2011 | Washing Machines
Noise at pump
Your problem is just a little vague. Noise could be several things including.... vibration can cause noise especially if the pump is not sitting solid on the ground. Cavitation around the impeller can cause the pump to be noisy. something stuck in the impeller can not only cause a number of irregular noises, but also affect performance. If the bearings are going bad they can make a number of bad sounds; anything from just sounding a little noisier than normal or a loud grumble to a loud high pitched squeal the can make a banshee turn and run.
Sep 18, 2010 | Jandy PHP High Head Pump 2 HP Up rated
Intex salt water pump purchased 3mths ago water running threw it but cant get any display no boost no working light noithing?????? any suggestions
The manual says that it's fried. Sounds like something is wrong with the power supply unit. Call their 800 number and ask for a replacement. Hopefully you kept your receipt....
Jun 30, 2010 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
249 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
