Knob won't work
This may sound obvious but the backstory is when I first turned the washer on it overflowed. i shut everything off and about an hour later ran the cycle through and it worked fine . . . no flooding. 15 minutes after the cycle finished, water started flowing into the machine without my permission . . . the knob hadn't been set. I turned the water off and then on again and no matter how I turned the knob, the water would stop. Is this a duh? question or maybe I should try and see if it will run a regular cycle by letting the water run through.
  • Washing Mach... Master
  • 5,323 Answers
The water inlet valve is bad
Posted on Apr 11, 2015
  • 473 Answers
Easy check for water filling problem like yours. Unplug the power and see if water still flows into machine. If yes----your inlet valve on the washer is stuck open and needs replaced. It is the part on the washer back where your fill hoses attach to. If the water is flowing into the machine while plugged in and it stops when unplugged, you have something in the control panel sending power to that inlet valve even when the machine is off. You would now need to find out where the power is coming from. If its an electronic control washer, the main board may need replaced.
Crosely won't play usb
If it's a turntable with a usb connector, those connections are usually outputs only. USB on a turntable is used to output the audio to a computer to rip albums to digital audio.
Jun 17, 2013 | Crosley Audio Players & Recorders
Kenmore washer 90 series - 1/2 hour ago we replaced the coupler and clutch because it would not spin. Now, it spins great - if you manually set the knob to spin! It will not move through the cylcles...
the first thing to check is if the small appx. 3/8" diameter clearish rubber hose got disattached from the side of the outer tub espically if before replacing cluctch is didnt overflow
Aug 12, 2011 | Kenmore Washing Machines
06 Nissan Altima 2.5 SE. Car won't start, not even turn over. interior light on, key hole light on, windows work, radio works, batterly light on apply breaks everything shuts down. Ticking sound in...
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.They have repair manuals at a very less cost.
2006 Nissan Altima
Dec 16, 2017 | 2006 Nissan Altima
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
My GE WCSR2090D top load washer has flooded our house in the past, and when looked at by a repair man he said nothing seemed wrong... so we continued to use it and it now leaks/floods only once in every...
You might have a partially clogged drain past your drain hose
(In the wall etc)
Thats overflowing behind the washer.
Watch the drain for a few washings and see if it overflows
It may be second or third or fifth load. Its hard to catch
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 08, 2010 | General Electric WCSR2090D Top Load Washer
Wont stop filling up. It will overflow with water
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Washer over fills and water comes out the door. Water continues to run even durring the pump out cycle just before the spin cycle
  1. Water inlet valve. It may not be able to shut completely when the electricity to it has been turned off. The valve may leak and drip water into the clothes tub. Water may accumulate substantially and overflow. Remove the washer's cabinet to access it.
  2. Water level switch. This switch senses the water level in the clothes tub. It is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the air pressure in the tube increases and activates the switch when the water reaches a certain level. When the switch is obstructed, it cannot tell the water to shut off and the machine overflows.Clear it from any obstruction.
  3. Air-hose. It is connected to the water level switch through a tube. If the tube or hose is cracked or broken, no enough pressure builds up to trigger the switch and shut the water supply off. Check it for any obvious damage.
Oct 08, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fills with water but doesn't stop
the washer timer control has failed, u will need to replace it.
Jul 23, 2009 | Kenmore 24032\24036 Top Load Washer
When i turn on the washer the water never stops running and it is overflowing into my floor
The usual culprit for a washer that will not stop filling is the pressure switch. The switch is located inside the operator console behind the load size, or water level knob (this knob has different names based on the washer model). Before assuming the pressure is defective, however, inspect the pressure switch and ensure the small plastic air hose is still attached to it. It is common for this small air hose to come loose or develop small cracks or breaks. Without the hose installed, the switch cannot detect the appropriate pressure in the wash tub and will not shut off. The result: as washer that continually fills and will overflow. What appears to be a significant problem may only be a loose hose and few minutes of your time. Please inspect the switch, check the entire length of the hose for cracks and make sure the electrical connection(s) are intact and not corroded, then get back to me. I hope this helps you.
PS Make sure you UNPLUG the washer before servicing!
Thanks.
May 26, 2009 | Washing Machines
Water pours from drain hose overflow in front of washer
That drain hose in front has a stopper, to prevent discharge. Either it is not there or not tight or something. You can always clog it shut with a round wood bit inserted or something........I don't think it is too difficult.
May 08, 2009 | LG WM0001HTMA Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
