Question about Dryers
Can only use time dry. The other dry options do not dry clothes
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Sounds like your timer needs to be changed
Posted on Apr 17, 2015
Takes turning on the drying cycle several times in order for the clothes to be dry.Is there a “best” setting to use?
A clothes dryer is as simple as heat and airflow just like a hair dryer. If you have heat then you are probably lacking airflow. Check that the vent is not crushed or pinched behind the dryer and also make sure the main line is not full of lint or anything else that could be blocking airflow. If this is beyond your skill, strength, or aggravation level then you can call a dryer vent cleaning company. Timed dry cycle is the old reliable setting and clothes should be dry between 30 and 50 minutes. The "best" cycle on a dryer is one that utilizes a moisture sensor bar and thermister to determine drying time without over drying the clothes. This will be found on cycles other than timed dry if your dryer has that feature. Always pay attention to the care labels on your clothing as they will tell you how to care for your clothing such as "tumble dry low temperature".
Feb 21, 2018 | Dryers
How to turn off steam option from spitting out water?
You turn the water supply to it OFF! It's not pulling water out of its but. Lol.
Feb 22, 2015 | Kenmore Elite HE4 Electric Dryer
Why doesn't my dryer dry clothes?
You can find the Installation Instructions and your owner's manual here: http://www.kmart.com/whirlpool-duet-174-7.4-cu-ft-he-gas-dryer/p-02692332000P The links are about halfway down the page and are in red. There are instructions for cleaning the lint screen, which if clogged, will effect the drying time. Hope this helps.
Jun 25, 2014 | Whirlpool Duet WGD96HEAW 7.4 cu. ft. Front...
Dryer will not stop when clothes are dry in auto-sense mode
Try "timed" cycles. If it shuts off on timed it's not the timer. It's more likely it's not cycling on the thermostat due to an airflow problem like the vent. To rule that out (or in) run ONE load through it with the vent disconnected. If it shuts off you'll know where to look
May 03, 2014 | Admiral AED4475TQ
I have a Kenmore 70 top load dryer that is not heating. And the timer doesnt turn off anymore either. Both items seem to have malfunction at the same time. Help?
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
Feb 08, 2011 | Kenmore Dryers
Hi, I have a Maytag dryer, model # mdg308daww Legacy series. It heats up just fine, dries clothes great but the problem I am having is that the Auto dry features are not shutting off as they were before....
you may need to replace the moisture sensor bars inside the dryer.also you may need to check the air flow if timed dry is nnot drying them properly
Dec 19, 2010 | Dryers
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Washer/dryer combo- i just want to use the dryer!
You can check this by closing your faucet on the wall, & trying the spin only option. If you suceed in the clothes being dry, you have an inlet problem, replace the water inlet valve at the top of the machine, you can do it yourself. Power off the mains. You could also check out your filter & pump.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
Mar 17, 2009 | Washing Machines
DLE5932W - Not shutting off when clothes are dry - keeps running
You have a computer control board problem and needs to be replaced.  The internal program has a problem and won't time down properly.
Jun 24, 2008 | LG DLE5932W Electric Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
