How do I know if it is completely if the printer is finished?
Installed w/ cdrom wizard says installed do I have to do ?? Anything else? ?? Is icon on computer screen? Tried going back thru the steps ?? Not right page just gives me troubleshooting faq
  • 473 Answers
It the screen says installed it should be ready to print. Go to your control panel>>>settings>>> printer and fax folder and see if your printer is listed. If YES--- click the properties and you should see a tab or box that says print a test page. Click that and see what happens.
Posted on Apr 11, 2015
Mising docproc.msi error; HP all-in-one 5610
Windows installed is trying to configure the missing .msi file.Please follow the below steps to remove the msi files.
  1. Download the Windows Installer Clean-Up utility (see Resources for link). Click the link on the download page on the Microsoft website and save the file to your Windows desktop.
  2. Double-click the utility setup icon on the desktop.The icon is labeled msicuu2.exe. Follow the prompts and the installation wizard instructions to install the utility. Click the "Finish" button in the installation wizard when it is finished.
  3. Open the utility. Click Start > All Programs >Windows Installer Clean-Up. This opens the Windows Installer Clean-Upwindow.
  4. Click to highlight the program whose MSI files "DOCPROC" you want to remove, then click the "Remove" button. Thisopens a warning prompt window.
  5. Click the "OK" button in the warning prompt window.The utility will remove the MSI files for the "DOCPROC"application you selected.
Regards,
Rizwan
Jan 28, 2010 | HP Officejet 5610 All-In-One InkJet...
I installed Open Office Office Suite and the ihe installation wizard indicated that installation was complete but there is no icon and it is not listed in Programs
I guess you just installed is not open office suite but open office installer.. To check this , click on start and you can see open office installer icon under windows update.. just double click on that and it will start installing open office.. once its finished you can see open office
soluzia.net
Jan 04, 2010 | Computers & Internet
Pc Game Error
Hi! I'm trying to install My Horse and Me the PC game, the installation goes through everything normal and but when I press Finish it gives me this error message
Unhandled Exception
Error Number:0x80040702
Description:Failed to load DLL:GameuxInstallHelper
When I press OK the installation window where you press Finish pops back up and it says
InstallShield Wizard Complete
The wizard was interrupted before MyHorseAndMe could be completely installed.
The system has not been modified.To install this program at a later time,run the installation again.
Click Finish to exit the wizard.
So I press Finish and then if I try to go and find it its not there its been uninstalled. And I have tried installing it several times with no luck .
So if you could please help me that would be wonderful because I really want to play my game.
Thank You!
Nov 14, 2009 | Atari Video Game Consoles & Games
Failed Wireless Setup/could not create new port
Check this link for wireless setup:
http://downloads.canon.com/MP620/Intro_to_MP620_Setup_Guide.htm
There are Vista 64 drivers on the CD that came with the printer, but if you want to download, you should download the network drivers if you are installing the printer to work on a wireless local area network (LAN).
Jun 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HP Photosmart C5280 - continually reinstalls the software.
I have exactly the same problem. Found a solution onthe Microsoft forums:
"Checkpoint: Unhide Hidden Devices in the Device Manager, view the problem
devices and remove them manually from there.
This workaround is for an HP Printer, use accordingly:
1. When the Found New Hardware Wizard starts at startup of the computer,
click <next>.
2. When it asks you for the HP disk, (the next thing that will require a
response from you probably), click <ok>. However, do NOT insert the disk
into your CD-ROM drive.
3. On the next screen that comes up, there will be a button that is already
highlighted telling the wizard where to find the printer driver (which is
what it is looking for). This button will be pointing it at "other media,
CD-ROM,etc.
The trick is to DESELECT this button. At that point, the button for your C:
drive will become active and you can select the C: drive. It will also
probably be prompting you with the location for the already installed HP
printer driver that is somewhere on your C: drive. (If not, you need to
click browse and locate the driver).
4. After you have deselected the CDROM and selected the C: drive, click
<ok> (or <next>) The Wizard then makes a second copy of your printer driver
(and, by the way, creates a second "installed printer" in your Control
Panel/Printers). And then, the wizard finally completes and tells you that
you have successfully installed the new hardware.
5. On subsequent startup, the Wizard should then NOT run."
Feb 08, 2009 | HP Photosmart C5280 InkJet Printer
Am having problem installing my hp laserjet6p printer
just check out the instructions its for both inkjet and laser printers. When installing a new printer with the Add Printer Wizard, you can choose between adding a local printer (one that's directly cabled to your computer through one of the ports) or a network printer (a printer that's connected to your network with an Ethernet connection, just as your computer is connected to the LAN).
To install a new local printer with the Add Printer Wizard, follow these steps:
1. Click the Start button on the Windows taskbar and then click Control Panel on the right side of the Start menu.
2. Click the Printers and Other Hardware hyperlink if the Control Panel window is in Category View.
Otherwise, double-click the Printers and Faxes icon if the Control Panel window is in Classic View.
3. Click the Add a Printer hyperlink in the Printers and Other Hardware window to start the Add Printer Wizard and then click the Next button, or press Enter to advance to the Local Printer or Printer Connection dialog box.
4. Make sure that the Add Printer Wizard selects the Local Printer radio button, and the Automatically Detect and Install my Plug and Play Printer check box beneath this radio button before you click the Next button.
5. If the wizard is unable to detect your printer in the New Printer Detection dialog box, click Next to install the printer manually.
6. Select the port for the printer to use in the Use the Following Port drop-down list box in the Select a Printer Port dialog box and then click the Next button.
7. Click the manufacturer and the model of the printer in the Manufacturers and Printers list boxes, respectively, of the Install Printer Software dialog box.
If you have a disk with the software for the printer, put it into your floppy or CD-ROM drive and then click the Have Disk button: Select the drive that contains this disk in the Copy Manufacturer's Files drop-down list box and then click OK.
8. Click the Next button to advance to the Name Your Printer dialog box.
If you want, edit the name for the printer in the Printer Name text box. If you want to make the printer that you're installing the default printer that is automatically used whenever you print from Windows or from within a Windows program, leave the Yes radio button selected beneath the heading, Do you want your Windows-based programs to use this printer as the default printer?
9. Click the Next button to advance to the Printer Sharing dialog box.
If you want to share this printer with other users on the network, click the Share Name radio button and then, if you want, edit the share name (this is the name that the other users on the network see when they go to select this printer for printing their documents) that the wizard gives the printer in the Share Name text box.
10. To print a test page from your newly installed printer, click the Yes radio button selected beneath the heading, Would you like to print a test page? in the Print Test Page dialog box.
11. Click the Next button to advance to the Completing the Add Printer Wizard dialog box, where you can review the settings for your new printer before you click the Finish button or press Enter to finish installing the new printer.
To use the Add Printer Wizard to install a printer that's available through your Local Area Network, you follow just slightly different steps:
2. Click the Printers and Other Hardware hyperlink if the Control Panel window is in Category View. Otherwise, double-click the Printers and Faxes icon if the Control Panel window is in Classic View.
3. Click the Add a Printer hyperlink in the Printers and Other Hardware window to start the Add Printer Wizard and then click the Next button or press Enter to advance to the Local or Network Printer dialog box.
4. Click the A Network Printer or a Printer Attached to Another Computer radio button in the Local or Network Printer dialog box and then click the Next button or press Enter to the Specify a Printer dialog box.
5. If you know the name of the network printer, click the Connect to This Printer (or to Browse for a Printer, Select this Option and click Next) radio button and then enter the network path in the Name text box.
If your network printer is on a network that uses an Internet address and you know this URL address, click the Connect to a Printer on the Internet or on a Home or Office Network radio button and then enter the address in the URL text box. If you know neither of these pieces of information, leave the Browse for a Printer radio button selected and then click Next to advance to the Browse for Printer dialog box.
6. In the Browse for Printer dialog box, locate the printer in the Shared Printers list box by clicking the network icons until you expand the outline sufficiently to display the printer icon.
When you click the printer icon in this outline, the wizard adds the path to the Printer text box above.
7. Click the Next button to advance the Default Printer dialog box.
8. Click the Next button to advance to the Completing the Add Printer Wizard dialog box, where you can review the settings for your new printer before you click the Finish button or press Enter to finish installing the new printer.
After you add a printer to your computer, you can start using it when printing with programs such as Word 2002 and Excel 2002, or when printing from Windows itself.
To switch to a new printer that you haven't designated as the default printer in programs such as Word and Excel, you need to open the Print dialog box (choose File-->Print) and then select the printer name in the Name drop-down list box.
Feb 02, 2009 | HP LaserJet 6p Printer
Epson stylus c46
Go here: http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20C46-_E
You can get the user guide as well as a setup guide.  If this helps please rate my solution.  Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
Dec 11, 2008 | Epson Stylus C46 InkJet Printer
I have a H-P Compaq Presario A900 Notebook PC and it came with a Canon Pixma MX310 all in one printer. It has windows vista 2007 on it (computer) and one of the instructions says to open the vista program...
To install the printer do this:
Nov 23, 2008 | Office Equipment & Supplies
I need help installing this printer to my computer no disc
You can download the driver here:
http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Epson Stylus C66 InkJet Photo Printer
D-LINK DP301U
TCP/IP printing for windows xp:
you must know the IP address of the print server and the port name.and the pc's ip address must be in the same subnet as the print sever's ip address.
Step 1 Go to Start > Settings > Printers and double-click the Add Printer icon to open the Add Printer Wizard.
Step 2 Select Local Printer and click Next.
Step 3 Select Create a New Port and choose Standard TCP/IP Port from the drop-down menu and click Next.
Step 4 This will bring up the Add Standard TCP/IP Printer Port Wizard. Click Next.
Step 5 Enter the IP address of the print server and the port name and click Next.
Step 6 The next window will prompt you for the Device Type. Select the Standard radio button and use Generic Network Card from the drop-down window.
Step 7 Click Finish to close the port configuration wizard.
Step 8 This will bring you back to the Add Printer Wizard. Step through the remaining windows of the Add Printer Wizard, accepting the default values to complete configuration.
May 29, 2008 | D-Link DP 301U (DP-301U) Print Server
k24674
jasbo
jasbo
