Question about Carrier Beverage Air DD68C Commercial Beverage Dispenser
Ice maker will not make ice
It did not come with a manual so i hooked up the water and turned it on but it will not make ice it just goes throw its cycles it is a everstar icemaker hdim35
  • lowrider1 Apr 17, 2008
    my friend gave me his ice maker model everstar HDIM35 to fix it since i am an hvac/r tech. and I found the problem in the ice full prove. the ice full prove located inside the compartment it got stock on the ice full position and it needs to be replace the problem now i can't find the part. it looks to me this product needs to be recall.
  • bigcheeze Aug 04, 2008
    made ice for the first 3 days then it started to beep. reset it many times and all it does is beep. It looks like home depot will not stand behind what it sells.
This is a Franklin ice maker and here is a link to the manual
Posted on May 16, 2009
  • 39 Answers
I have one of these. It stopped making ice after about 6 mo. The solenoid water valve was the problem. Its a common Frigidaire valve that has an orifice to let in the right amount. If it restricts the unit won't reject ice as a certain amount water is required in addition to hot gas compressor cycle to release ice. If too much water flows in during a cycle the ice making bin overflows and melts the ice it just made. Replace the valve if it looks like you have a problem with ice rejection or overflow or if ice is poorly formed.
Posted on Dec 26, 2008
  • 1 Answer has parts for most machines, including HDIM35.
Posted on Apr 18, 2008
Well this product is skechy at best. I bought one at Home Depot and had the same problem. Well under warranty pressure they engaged Sears as the repair facility. Well four trips later the thing makes ice but now it all melts within a few hours.
Sears is here for the 5th time.
Everstar HDIM35 is not worth the trouble. Buy ice bags for your parties.
Posted on Jan 24, 2008
Where does the water go in the model IM90 emerson ice maker
open the lid and remove the plastic ice basket. Look on the walls under the ice basket and you should see a "fill line".. Water should be poured into that area (below where the basket goes) no higher than the max fill line.
Oct 21, 2014 | Emerson IM90 Portable Ice Maker
Ice maker stopped filling with water
where the tube (water supply)cumes into the ice maker inside the freezer may be froze shut /locate it and see if it is use something small to open it up easy!
Apr 10, 2013 | Kenmore Refrigerators
The water is leaking from the ice maker . how can I turn it off, or close the tap
U can trace the line back to where it hooks in to water line and un hook it
Dec 19, 2012 | Refrigerators
My ice maker is not working model #ED2LHAXMB00 made 05/03 the
Before you replace the Water Valver - Shut your water off - disconnect the water line to the from the back of the refrigerator at the top where it goes into the icemaker. I used zip tie or something flexable to see if it would go all the way through to the
tube inside the refrig. If you have obstruction - use your hair dryer
to thaw the ice from inside the refrigerator tube. When the flexable goes all the way through. Hook back the water line to the icemaker. You will have ice soon. If still no ice, replace the water Inlet valve.
Read more:
Jun 05, 2010 | Whirlpool ED2FHGX Side by Side...
Ice maker won't make ice
With ice makers it is almost always one of two things. The ice maker itself, or the water valve. Figuring out which one is easy, and I will help explain.
First thing is the frig has to be cold enough for the ice maker to even start working. I'm assuming we have the cold part taken care of. Next, the machine will start a cycle and ask for water. Here is where the valve comes in. The ice maker energizes the valve and it opens allowing water to rush up the back of the frig and into the ice maker. After the ice freezes the ice maker goes into harvest and dumps the ice.
In conclusion, you either have an ice maker that stalled at some point during that cycle (in which case you need a new ice maker). Or the water valve is not opening, thus no water enters the ice maker and you get zero ice.
If you have ice in the ice maker and it is not dumping, you need a new ice maker. If it is empty, you have to either wait for it to ask for water or manually advance the ice maker into cycle so you do not have to wait.
At this point you will hear the water valve energize or not. If it never energizes, the ice maker is not working right, if it energizes and you get squat, the valve needs to be replaced.
If you have experience with a multimeter you could detach the harness going to the ice maker and simply hook up your leads. When the ice maker asks for water, you should get 110v reading on the meter. If you do, the valve is bad and needs to be replaced.
If I can be of any further assistance please let me know. good luck!
Oh, and the valve probably sells for between $50 and $100 depending on where you buy it. The ice maker should run between $100 and $180.
P.S. There is a remote chance the filter needs to be replaced. An old filter can cause water pressure issues and you may not get enough water into the ice maker.
May 29, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I just moved my side by side and hooked up the water line. I have water to the dispenser but it doesn't seem like there is any water running into the ice maker. Does it take a while??
Yes, I would leave it alone for at least 24hours, when it starts making ice you should throw away the first couple of ice cycles.
Aug 02, 2009 | Refrigerators
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water shooting out the icemaker hose
(I hooked up the lines and water goes heywire) You hooked up the lines to what? If you changed the water valve you may have the dispenser and ice maker lines reversed along with the electrical connections to the top of the valves.
May 13, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
How to hook up Ice & Water dispenser on freezer door
The water valve is on the back of the refrigerator. The water line connects directly to that valve. If there is no line available then you will need to run one from a cold water line in the plumbing using a drill type (1/4") saddle valve on that pipe. Hope this helps. If you need more instruction let me know!
Oct 06, 2007 | Refrigerators
Carrier Beverage Air DD68C Commercial Beverage Dispenser Logo
2,655 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Level 1 Expert
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
