Question about Hoover Washing Machines
Hoover washing machine model dny d8p error code ao3.makes some cranky noise while washing ,,specially when spinning..not drying well
The softener is not going down,pump is good,,water outlet is ok,,and sinning great.just the noiseand ,its not drying good.plus showing errora03
  • Hoover Master
  • 5,323 Answers
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Posted on Apr 11, 2015
My hoover washing machine model dyn d8p has a code error of ao3/t know what is wrong ..its new and just used then 3 month now but it was not drying well and showing that error code
if it is 3 months old , I suggest that you call the repair shop as it is under warranty
touching it yourself or having any unauthorised person fix it will void the warranty.
Apr 10, 2015 | Hoover Washing Machines
Hoover 600MB not spinning. Help please
NOTE: A 600 is not a fast spinner. towles and jeans etc do not come out very dry.
Helpful information prior to diagnose
Have you checked to see if the pump filter is blocked so that all the water can drain away.
Does the machine just stop with all it's water still in it.
Does the machine finish it's cycle.
Does all the water pump out, do you hear a sucking noise (means no water left) or a humming noise( means pump jammed)
Oct 01, 2014 | Washing Machines
My hoover visionhd washer is making a rattly noise and keeps coming up with an error message half way through wash
i would check the filter incase there is someting stuck in the pump. would explain the rattling noise and also the error code.
Feb 16, 2011 | Hoover Washing Machines
My washing machine wont spin back and forth. it will fill up, make the sound of washing, but then it just spin dries. theres no "washing" taking place.
make sure the agitator bolt is tight. open lid, remove plastic ring where in most washers you pour the fabric softener. take the fabric softener unit out and you should be able to see a nut, it may a bit gooey from fabric softener. make sure the nut is tight. if all is good here it means your tranny is not shifting properly.
Jun 15, 2009 | Washing Machines
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Washing Machines Logo
46 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
