I need to replace the hose on my machine - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Outlet hose held on to pump via spring clip
Posted on Apr 13, 2015
I need to know how to change the hose on the washer dryer LG WD combo machine
should just be a few clips that you take off and replace it
Oct 12, 2014 | Washing Machines
How to replace hose (tire inflator)
I don't know that machine specifically, but you'd probably have to get inside the machine wherever the hose attaches to replace the whole hose.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
Aug 05, 2014 | Schumacher Xp2260 1200a -engine Starter/...
Model - LG F1480FD. Need to replace drain hose. Please advise best way to get in to replace drain hose (? from bottom side etc.)
underneath......
drag maching to outside door and let old hose hang outside
this will drain alot of water out of machine then upend it to replace old hose with new 1
cheers
Mar 27, 2011 | LG WM-1480FHD Front Load Washer
The cold water is not flowing well into the machine. It is just dripping. I've swapped the hose with the hot (this has not helped). The hose, when disconnected from the back of the machine seems to have...
Hi just read your posting.Now the place you unscrewed the hose from on the machine end is the water valve.If you look at the water valve from the back of the machine you should see a plastic filter inside the water valve.Clean this filter if it is blocked.Now refit hose to machine and try a fill cycle again.If it still has inadequate water flow then the water valve needs replacing.If it needs replacing I can guide you step by step to replace the valve.Looking forward to your reply.
Oct 03, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Same as everyone else have to restart it 3-4 times in order to use it the stupid f1 code keeps showing and stopping the washer
It is fault code indicating an Out-Of-Range Pressure signal caused by either a faulty Pressure Transducer which is an integral part of the Machine/Motor Control Board or a pinched/kinked pressure hose. Check the pressure hose and make sure it is not pinched or kinked. The Machine/Motor Control Board needs to be replaced if there's no issue found with the pressure hose and the faut code keeps flashing. It simply mean the Pressure Transducer is at fault and since it is an integral part of the Machine/Motor Control Board, the assembly needs to be replaced. Unplug the machine before doing any checks or repairs.
Unscrew the rear panel from the back of the machine to access and check the pressure hose.
Remove the three hex-head mounting screws from the rear of the console then lift the console off the cabinet to access the Machine/Motor Control Board for replacement and the pressure hose for checks.
Aug 19, 2010 | Washing Machines
Water leak at hose connection end at machine
hello it is a simple repair , you either need to tighten the hose connection or replace the hose , you can buy them from bunnings store, if the hose is old better replace it
Jul 23, 2010 | General Electric WHRE5550H Top Load Washer
Zanussi 1050 washing machine will not fill with cold water . Cold water hose replaced because of a leak in old hose but machine will not now fill
Assuming water supply to machine is okay and no kinks in the hose Then its the solonoid valve that is faulty and needs replaced
Apr 01, 2010 | Washing Machines
there is a kit available to replace just the part from the back of the machine.normally the drain hose comes with the wiring loom big job.not sure what country you are in.kit is available in australia.
Nov 15, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
