Pls help me out to get my password
1. Boot up your computer and immediately hold down f1. If it boots up normally then restart your computer and try f2. try all of the f keys and try del or esc until it boots up into your BIOS setup. This will look like a bunch of very blocky graphics. (usually the buttons are either f1, f2, f8, f10, del, or esc)
2. Once in your BIOS, navigate with the arrow keys and enter until you find the option to boot into "safe mode with command prompt" select that option, save your preferences and reboot your computer.
3.Once you've booted into safe mode, log on as the administrator or guest. Usually it does not require a password.
4. At the command prompt type "net user *" but type that without quotes and where it says you're user name just type you're user name without the 's.
5. It will ask you for a password. Type in the password you would like (It won't show the keys or even * that you are typing so that's ok). It will ask you to retype the password so do that.
6. reboot your computer and hold down whichever key that you used to get into setup.
7. Once in setup change the option from booting into "safe mode with command prompt" to the default option which will usually say boot into windows or something to that effect.
8. Log in as yourself using the password that you typed in at the command prompt.
Hope that helps
