Question about Cuisinart DGB-300 Coffee Maker
How do I set the time on the LED clock? - Cuisinart DGB-300 Coffee Maker
How to set clock on musky
Unsure which model Musky. Example of DY28.
https://www.banggood.com/Musky-DY-28-Touch-Sense-Mini-Bluetooth-Speaker-TF-AUX-Colorful-LED-Light-Alarm-Clock-p-1084269.html?cur_warehouse=CN
Time Mode and Alarm Mode:
Press and hold MODE to enter the setting time mode, you can begin to set the time based on your local time.
In Alarm mode, long press MODE key to enter the setting alarm mode. Once you see a bell photo shines on the display, you can set alarm time as you need.
Musky DY 28 Touch Sense Mini Bluetooth Speaker TF AUX Colorful LED Light...
May 15, 2018 | Audio Players & Recorders
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? (i am in Australia.) Thank you in anticipation.
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? Philippines Thank you in anticipation.
Jul 12, 2010 | Vacuums
How do i set the time on my timex clock? its the nature sounds alarm clock pleas help
press the time button and hold until the time starts to blink then use the < > to change the time then press Enter to set the time.
Nov 13, 2009 | Timex Nature Sounds LED Clock Radio
Setting time and adusting display
Hi, Press on the word clock then hit your hour and minutes to set your time. Hope this helps.
Mar 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Alarm clock won't change time with daylight savings
unless it is an automatic , atomic clock none I have ever owned do the change automatically
Feb 27, 2017 | RCA Audio Players & Recorders
Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Jan 01, 2008 | Timex Nature Sounds LED Clock Radio
Pi0oneer blue led reciever cd player
For most Pioneer single CD players, you can set the clock using the following steps: 1.Press and hold the SOURCE button until the unit shuts off. 2.Press and hold SOURCE again until the clock appears. With some models you will press and hold the FUNCTION or AUDIO button instead of the SOURCE button. 3.Press the left or right arrow to select the segment of time you wish to adjust. 4.Press the up or down arrows to increase or decrease the numbers in the blinking segment. 5.Once the clock is set correctly, press the SOURCE button to exit.
May 11, 2007 | Pioneer 45X4 DFS BLUE LED CAR CD
Cuisinart DGB-300 Coffee Maker Logo
49 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
