Question about Frigidaire Heating & Cooling
Trying to replace the power cord - but I can't remember which wire goes where... white & black wires have same type of connection, and not sure where the ground goes.
I have looked at a wiring diagram but it's not helping me at all... I also tried to add pics, but they're not showing up. If it helps, one of the connections on the unit is bronze, the other is silver. The bronze connection is attached to a black piece of plastic that says "12VDC" and the silver connect is at the bottom of a silver cylinder.
  • Tanya Summers
    Tanya Summers Apr 12, 2015
    Problem solved!! Didn't realize the connections are different sizes... they looked identical at first. Thanks!!
    Top Expert:
  • Frigidaire Master
  • 2,907 Answers
The white wire connects to the larger flat connection on the power plug. The black connects to the smaller flat connection, and the green wire connects to the small round power plug ground pin.
Hope this helps.
Posted on Apr 11, 2015
Testimonial: "Very helpful!"
  • danoyachtcap
    danoyachtcap Apr 12, 2015
    Thanks Tanya, rgds Dano
    Scholar:
  • 125 Answers
Need more information to give exact answer.
If it is 120 volt, then white is neutral and black is the hot wire.
The ground wire is connected to the metal frame, should be a green screw or a connection lug just for this ground wire.
Post a picture of the wires you are trying to connect and a picture of the connection terminal on the ac unit and I can give you an exact answer.
Testimonial: "Horace answered quickly & knows what he's talking about!"
  • Tanya Summers
    Tanya Summers Apr 11, 2015
    Pics should be up soon - thank you!!
Replace the electric cord
IT doesent matter :) just make sure the green connect to the boddy of your dryer.
May 01, 2010 | Roper REX4634KQ Electric Dryer
Tip
Oven Cord and Wiring Oven for 3 Wire or 4 Wire
If you have an Electric Oven, Range, or Cooktop and need to change the style of cord that you have on the appliance or if you just need to install a cord on a new cooking appliance, you may have questions about where the wires need to go. This tip will help you to figure these questions out.
Remember to ALWAYS make sure that all power is disconnected BEFORE beginning your work!!
On the back, underneath, or on the side, of your range or oven will be a cover plate that will have the wiring connection lugs behind it. A screw or two will need to be removed to expose the connection point. Always remember to reinstall the cover after you have finished your connections.
If you have a 3 wire cord the plug will look something like this.
You will have a red wire, a white wire, and a black wire, on the other end from the plug.
The black and red wires will go on the two ends to the matching colors. The white wire will go in the center. If you have a bonding strap make sure that you jumper that from the center lug to the frame of the dryer. If you do not have a bonding strap, then make sure to make one out of #10 ga. or larger wire and a couple of crimp rings. Green wire is preferable.
The connection will look something like this.
If you have a four wire cord the plug will look like this
Here again, you will have the red, white, and black wires. This cord will also have a green wire. This wire gets connected directly to the frame of the appliance. With this cord, you do not need the bonding strap or wire. If you are converting from a 3 wire to a 4 wire then remove the old bonding strap if there is one there.
This connection will look something like this.
When converting from a 3 wire to a 4 wire you just REMOVE the bonding strap or wire and hook the green wire to the frame. If you are converting from a 4 wire to a 3 wire then you ADD the bonding strap or wire. It gets hooked from the center lug to the frame.
Always make sure that the outlet that you are plugging into is wired correctly also. The black and red are each 110 volt legs that have a voltage of 220 volts across them. The black and the red wires need to be wired to a double pole circuit breaker of the required amperage. The wiring needs to be large enough to support the breaker size that you use and the requirements of the appliance. For 30 amps. use 10 ga. wire, for 40 amps use 8 ga. wire and for 50 amps. use 6 ga. wire. The white or neutral wire goes to the neutral bar in the power panel and the green wire goes to the ground bar in the power panel.
By following this tip you should be able to hookup a new appliance or convert your existing appliance cord. Recheck all your connections before turning the power back on to the appliance.
http://www.fixya.com/support/r4319770-maintenance_range_stove_or_oven
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Apr 06, 2010 | Ovens
Tip
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
If you have an electric dryer and need to change the style of cord that you have on the dryer on if you just need to install a cord on a new dryer, you may have questions about where the wires need to go. This tip will help you to figure these questions out.
On the back of your dryer will be a cover plate that will have the wiring connection lugs behind it. A screw or two will need to be removed to expose the connection point. Always remember to reinstall the cover after you have finished your connections.
If you have a 3 wire cord the plug will look like this.
The black and red wires will go on the two ends to the matching colors. The white wire will go in the center. If you have a bonding strap make sure that you jumper that from the center lug to the frame of the dryer. If you do not have a bonding strap, then make sure to make one out of #10 ga. wire and a couple of crimp rings. Green wire is preferable.
If you have a 4 wire cord the plug will look like this
Here again, you will have the red, white, and black wires. This cord will also have a green wire. This wire gets connected directly to the frame of the dryer. With this cord, you do not need the bonding strap or wire. If you are converting from a 3 wire to a 4 wire then remove the old bonding strap if there is one there.
Always make sure that the outlet that you are plugging into is wire correctly also. The black and red are each 110 volt legs that have a voltage of 220 volts across them. The black and the red wires need to be wired to a double pole 30 amp. circuit breaker. The wiring needs to be a minimum of 10 ga. wire. The white or neutral wire goes to the neutral bar in the power panel and the green wire goes to the ground bar in the power panel.
By following this tip you should be able to hookup a new dryer or convert your existing dryer cord. Recheck all your connections before turning the power back on to the dryer.
http://www.fixya.com/support/r4312805-dryer_maintenance
http://www.fixya.com/support/r3866744-dryer_not_working_dryer_not_drying
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
on Apr 06, 2010 | Dryers
I am trying to replace a two wire light switch(both white) with a leviton photoelectric 3 wire motion activated light control(red, black and green). I am trying to determine which wire goes to which?
one of the white wires has power on it constantly....that wire connects to the black wire of the leviton.......the other white wire which has no power to it is going to whatever needs power so that wire connects to the red wire of the leviton....the green wire connects to the metal box where your mounting the leviton.
Feb 08, 2010 | Leviton Decora Light Dimmer Switch
Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
May 24, 2009 | Ovens
4 prong power cord to a 3 prong monunt I'm trying to replace a 3prong cord with a 4 prong but there is an extra wire, what do I do with it?
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
May 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Replace power cord on GE cloths dryer
just remember on a 3 wire cord(if it is gray) the middle wire always goes on the middle of the terminal,the 2 outside wires get mounted one on each side on the terminal broke,if it is a 4 wire cord the white goes on the middle of terminal block,the red and black get mounted one each each side of the terminal block(it does not matter which side you put the red or black wire they are both 120 volt) the green wire gets mounted to the cabinet where ever you can mount it(to metal) your done-mike
Mar 24, 2009 | Dryers
Changing an Electric Dryer’s Power Cord from a 4-Prong Plug to a 3-Prong Plug
Black and red wires go to the outside terminals. (either way, just so one is on each) and the white goes to the center terminal. If your cord does not have color coded wires and is one of those flat wire types, just make sure the center wire goes to the center terminal. If the 4 wire cord had been properly installed the installer would have removed a wire or metal strap which connected the center terminal to the dryer's frame. Make sure you have this is place to ground the frame of the dryer to neutral.
Nov 07, 2008 | Dryers
Replacing Power Cord Kenmore Progressive Upright
That actually sounds correct, if it's the model I'm thinking of. As long as you're talking about connecting to the wires that are held in by the wire nuts you should be good to go.
-R
Oct 25, 2008 | Kenmore 23613 Progressive PowerMate Bagged...
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
Heating & Cooling Logo
184 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
