Question about VAX Appliances Vax X5 Bagless Upright Cyclonic Vacuum
How do I remove the wheels so that I can get at the two hidden screws so I can remove the bottom plate
Bottom plate wont come off
there are hidden release latches use a thin blade between the two plates
Dec 26, 2013 | Euro-Pro NV22 Shark Navigator Bagless...
Hoover flair needs a belt replacement
Remove the small screws on the bottom of the powerhead. On some models there are 2 hidden beneath the rubber wheels in front. Just pop the wheels out with a flat blade screwdriver and remove those two as well. Remove the hood and you have access to the belt, motor and roller.
Here's the correct belt:
http://vacuummedic.com/product.php?id=86
Good Luck!
The Vac Dr
Jan 30, 2013 | Hoover S2200 Flair Bagless Upright Vacuum
How do I change the belt?
To change the belt on a Hoover Flair Stick Vacuum, remove all 6 screws from the bottom of the beater bar. There are 2 screws hidden under wheels. You must pop the wheels off with a screw driver to remove the hidden screws. The cogged belt is on the left side of the beater bar. Be careful not to pull the wires.
Jan 22, 2013 | Hoover S2220 Flair Bagless Upright Vacuum
I need to change the belt. How do I get it off inside the vac.
Turn the vacuum over so you are looking at the brush.Remove the screws and that plate will come off.The belt fits on the brush,in a groove.The other end of the belt fits on a small wheel about 6 inches back,form the groove on the brush.There may be another plate over the wheel.When you get the plate off the bottom you will see what I am talking about.It is not hard.
May 19, 2011 | Dirt Devil Vacuums
I need to know how to change the belt on a fantom xt
Turn it upside down.On the bottom where the brush is are 4 screws.Unscrew those 4 screws.Remove the plate.Now you can see the belt.There may be a second plate covering part of the belt,if so remove it too.The belt fits around the brush in a groove the same width as the belt.The other end of the belt fits on a small wheel about half way back from the brush.Put the plate back on and you are done.
May 14, 2011 | Vacuums
I need instruction on how to replace the drive belt.
first unplug the device...depending on the model you have there are two screws that hold the cover onto the unit. sometimes they are hidden behind the rubber wall guard and sometimes they are hidden in the random designs on top or even the bottom of the unit. you unscrew the screws (usually 2) and remove the plate. you should be able to see the drive belt now, remove and replace with the new one. (it would be a good idea to clean hair etc out while you are in there :) ) make sure it turns freely and replace the cover, screw it in. vacuum to your hearts content
Sep 16, 2010 | Vacuums
Eureka Fantom Thunder 12V/older model Need instructions on how to change belt and headlights.I could only find 1 screw on the bottom plate none on top plate. Thanks N J
there are two screws on the Fantom Thunder (It was not made by Eureka though) on the back of the unit just above the rear wheels. Remove these two screws and the top cover can be removed to get to the brushroll, belt and headlights. I believe the light bulbs in this unit are 12 Volt, not 110 volt.
Jul 18, 2010 | Vacuums
How to install a U8172-900 belt
your savvy bagless has a geared belt. remove the bottom plate and then remove the 2 back screws near the back wheels to remove the top cover also peel off the hoover decal to access the top cover screw. this will expose all components to replace the belt.
Sep 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
How to remove bottom plate
you will need either a t15 or a t20 torx bit. you should find these at any hardware store.
Aug 24, 2008 | Bissell 5770 Healthy Home Bagless Upright...
VAX Appliances Vax X5 Bagless Upright Cyclonic Vacuum Logo
88 people viewed this question
Top VAX Appliances Vacuums Experts
Jerry Kramer
Jerry Kramer
Tom Chichester
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
