Question about Miscellaneous
What do I put in this compartment - Miscellaneous
    Genius:
  • 1,585 Answers
If thats the lid off the trap nothing
Posted on Apr 27, 2015
Where do you put the soapin a maytag neptune
On the neptune washer, on the top there is a dispenser on the left hand side, lift up the lid, there will be 3 compartments, the compartment closest to the control panel is the one you put the soap into, the middle compartment is for bleach, the other one is for fabic softner.
Aug 15, 2012 | Maytag Neptune MAH6500A Front Load Washer
My washing machine won't use soap from the drawer
are you useing the right draw for main wash try putting on a wash and open the draw there should not be any water leaking if you do this and look in the compartment that you put the powder in and see if the water is going into the compartment that you use and see which compartment is filling thats the one to put the powder in
Nov 14, 2011 | Washing Machines
I dont know were to place the bleach at in this machines
Hi.
There should be three compartments in the dispenser, you would normally put the bleach in to the
main compartment of the dispenser where you put the normal wash powder
This is the largest of the 3 compartments,and is usually in the middle, but sometimes on the right, but it is the largest of the 3,
Dec 01, 2010 | Zanussi FJ1254W Front Load Washer
Need to figure out how to put the compartment that
Are you talking glove compartment? I don't know about an 05 but some earlier models all you have to do is flex the sides in and let glove box falls open. Then it will come right off if my memory serves me correct.
Dec 07, 2009 | 2005 Ford F 350 Super Duty
Do I put powder detergent in the same place I put Liquid detergent?
Detergent compartment
Add liquid or powdered detergent to this compartment for your
wash cycle. The detergent separator must always be in place,
either in the front or back position.
 Do not fill beyond the “MAX” level.
 Liquid or powdered color-safe bleach may be added to the
Main Wash compartment along with the same type of
detergent, liquid or powdered.
 Liquid detergent: Put the SEPARATOR in the front position,
between the guides, as shown as shown by Position 1 below.
There will be no gap between the bottom of the wash cycle detergent
compartment and the bottom of the separator.
Powdered detergent:
Put the SEPARATOR in the back
position, behind the guides as shown by Position 1 below. There will be
a gap between the bottom of the wash cycle detergent
NOTE: The separator will be in the POWDER (back) position
when shipped from the factory.
Nov 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Which tray ( A,B or C) does the fabric conditioner go in?! Also, should it be put in at the beginning of the cycle?! Thank you!
Put it in tray B. You should see one end of what is a U shaped pipe (upside down) in the tray. The fab con should be put in the tray at the beginning of the wash cycle at the same time you fill the detergent tray.
Usually from left to right the main detergent / powder goes in the left compartment, the fab con in the centre compartment and the prewash / soaker / starch goes in the right side compartment.
Oct 22, 2009 | Washing Machines
Where ecxactly do you put washing powder and stasoft
Washing powder should go in the right hand side compartment, if it is not going down, then check that water is coming into washer.
Conditioner should go in the smallest of the compartments.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Apr 04, 2009 | Kenmore Dishwashers
Whirlpool Quiet Partnet II Rinsing solution compartment
WITH REGARDS TO YOUR MACHINE NOT TAKING THE FULL BOTTLE OF RINSE AID YOU WILL HAVE TO TRY AND CLEAN OUT THE SOAP POWDER THAT WAS PUT IN THERE YOU MIGHT NEED TO STRIP THE DISPENSER DOWN IF YOU CAN NOT CLEAN IT FROM THE TOP.
IF ALL FAILS IT WILL BE BNEST TO CHANGE THE DISPENSER :-(
GOODLUCK.
MOHAMED
Jun 01, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Miscellaneous Logo
27 people viewed this question
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
