Question about Philips Televison & Video
How do I fix a burned out power supply board on a Philips FWD 185/94
When connected to mains, smoke is seen coming from transformer marked T901 on the power supply board.
  • Philips Master
  • 715 Answers
Hi Qdiv,
If the power supply has burnt; it is better to replace it rather than repairing.
Good luck.
Posted on Apr 11, 2015
Testimonial: "Thanks. But Philips support is unwilling to help - where else could I get a spare board or if I am able to get the transformer I could replace on the board. If you could share info on any sources that you / others are aware of, would be very useful, please."
  • 6 more comments
  • Sp Gupta Apr 12, 2015
    Which country are you from? Here in India we can get almost all kinds of transfarmers rewound. If you have someone doing in your area get the transfarmer rewound. Can you please post the picture of the power supply ?
  • qdiv Apr 12, 2015
    I am in India, ~60km from Chennai. I plan to hunt around Ritchie street for a board or transformer; I do not know where to get it rewound. I am attaching a photo of the board, component side. The yellow block near centre is the one that I think smokes though no external damage is visible (yet).
  • qdiv Apr 12, 2015
    A service manual is available on the internet at This gives the circuit diagram but actual voltages are not known;
  • Sp Gupta Apr 12, 2015 Please try this website for a complete diagram.
    If you say smoke coming from or near the transfarmer, sure there will be some other components around it. Please check them thoroughly.
  • ravnil kumar Dec 18, 2016
    Hi can i know the resistor color coding of r915 of that power supply pcb.
    Hi can i know the resistor color codings of R915 of that power supply.
  • Sp Gupta Dec 26, 2016
    can you please give the colour codes on the resistor?
Sony str-av1020 reciver Power supply transformer burned!
Aug 19, 2016 | Sony Audio Players & Recorders
I accidentally plugged a speaker output into bridge and right output at the same time. All fuses are good. Did I smoke the transformer? If so where can I get one?
Probably not. The fuses would have blown if the transformer had been overloaded.
These amps do not have output transformers. The transformer you see inside are likely switching transformers to increase the supply voltage substantially. They are pretty rugged. There likely fuses on the circuit board that you don't recognize. If there are surface mount components on the board, look for white rectangular that are square when looking from the end. Usually they will have xxA marked on them, a 1 or 2 digit number followed by an A. There are other shaped fuses, but they should all have a similar marking. Usually, the left and right amplifiers will each have TWO fuses associated with thir power supply and sometimes an additional one for the speaker.
Feb 01, 2015 | Car Audio & Video
How do I test a High Voltage Transformer on my Vizio VU42L-FHDTV10A?
It could be the main board. The main board controls the standby light on the front of the set. Check and verify that your 5vdc standby voltage is working. Next, I would check the "on" or "ps on" input on the power supply board. When you turn the set on (either my side buttons or remote) the main board should send a 3.3vdc signal into the "on" terminal on the power supply. This "on" signal from the main board turns on the other half of the power supply thus turning on your set. If you are not getting this signal from the main board, I would suspect the main board. To test your power supply, you can simply put a jumper from 5vdc to the "on" terminal on the power supply. Your 12vdc, and 24vdc power supplies should then become active.
Oct 31, 2012 | Vizio Televison & Video
I have a Olevia lt37hvs, When i plug it in the blue(olevia)light comes on then goes off and the screen will be blue for 5-6 second then go black for 1-2 seconds then screen goes blue again and it just...
tried to connect again the supply for main board and disconnect the supply for the inverter board of back light. and turn on the tv, if the indicator stay the inventer board was the cause of voltage drop at the power supply board.
Sep 08, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Fitnex t60 display says prg bad, what does that mean and how can i repair it
1) You must test first the power supply for +5DC for I.Circuit( Including EPROM, ROM, etc)
2) Test the flexible cable between KeyPanel and display board, and clean.
3) Chechk the connector between Display Board with the lower board(Main Controller Motor)for loose connection, loose wire.
4) Test the transformer controller supplying the 12VCA, to the power supply at the Main Controller Board since this supply the +5vd to the Display Board.
Finally you must have Strong Conclusion if the problem is 1)Display Board faulty, 2) Power supply Faulty, 3) Transformer Controller Faulty 4) Main Controller Board Faulty.
For All test you must use Dvoltmeter.
Nov 21, 2011 | Fitnex T60 Light Commercial Treadmill
Hi i am trying to find the output voltage of the mains transforma ? 120v in whats the output
Mains transformer output volts are 12V AC for Sony ICF-CDK50
Circuit location is T901 and part number is 143591722 .... TRANSFORMER, POWER (US, CND)
Hope these info will help you.
Nov 05, 2010 | Sony ICF-CDK50 Clock Radio
Smoke rolled out and then the unit shut itself down
By and large, electronic devices need the smoke to stay in for them to work. Once the smoke comes out, they generally don't work anymore.
Joking aside, the only parts that can generate enough heat to produce smoke will be the power supply transformer and capacitors. If you're lucky, the damage will be limited to the power supply, but there's a good chance that it went unregulated while it was failing and so dumped 120V into the main circuit board and cooked other components there.
If you are up for soldering, then open the unit up and post details of what components have visible damage, as well as detailed info about the circuit board revisions.
If you're not, then it's probably time to shop for a new receiver.
Sep 06, 2010 | Samsung HT-TX72 Theater System
It does not start up and have already replaced the control board
Beffore the control board was replaced it was important to check that the power supply was correct. Hope the secondary/main transformer is working.if supply is not coming to the main board check the fuse and this sub transformer.
A check will indicate that the line is correct and the power comes to the board. If the board is not acitve then the front panel touch board could be faulty. Also check the main capacitor for the magnetron to function or the magnetron itself..
Hope you try this out.
Aug 25, 2010 | Microwave Ovens
No picture ,No sound except high pitch shriek from transformer/JW14140
check your power supply board,higher voltage than the normal voltage coming out to your power supply,replace the oscillator that control your regulator.
Sep 25, 2008 | GE 31GT740 31" TV
Unit won't power up completely
The clicks you hear are the relay that completes the circuit for 110V AC to the main power transformer. Mine had the same problem and here's how I've gotten it to work. A lightning strike near our house caused it to fail, and I traced it to the power transformer relay activation circuit. The tuner and amp were fine. I found a bad transistor in the relay circuit, but didn't have a replacement on hand, so I soldered a jumper wire across the relay switch connections on the power transformer circuit board. This connects the 110V AC directly to the power transformer. DC Power to the amp and tuner circuits will still be controlled by the power switch, but the transformer will be supplying all the AC voltages to the main board. If there is a real problem with the circuits that load the transformer or the transformer itself, then the fuse will blow. If the fuse doesn't blow then I suspect the problem is just in the power sequencing circuit itself, that is not needed for operation other than to make the unit "Energy Star Compliant". A lot of electronic items have a transformer that is not switched, and only fused, so that the supplies are available at all times.
Jan 24, 2008 | Audio Players & Recorders
Televison & Video Logo
134 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
