Our washer is vibrating so bad it is moving as much as 6" across the floor it is level and all the leveling bolts are solid and shipping bolts have been removed
    Top Expert:
  • Washing Mach... Master
  • 10,875 Answers
The weight on the tub came unsecured,have it serviced
Posted on Apr 11, 2015
Walking machine spin
Good Morning Jason, thank you for your inquiry!
If the washer is walking or vibrating, then more than likely it is not sitting solidly on the floor. Move washer until it sits solidly and the leveling legs may need adjusting. This issue may also occur if the shipping blocks and bolts weren't removed when the washer was installed, or you have an unbalance load.
Best regards!
Oct 13, 2013 | Frigidaire Gallery GLWS1339EC Top Load...
Bad vibration when washer is spinning.
If the washer is vibrating, it's not sitting solidly on the floor. Move it until it sits solidly. If needed, adjust the leveling legs. It might also vibrate if the shipping blocks and bolts weren't removed when the washer was installed, or the wash load isn't distributed evenly.
If all this looks good, check the shock absorber to see if one has broken.
Nov 03, 2012 | Frigidaire Affinity ATF7000E Front Load...
Was installed on a solid, level floor, adjustable legs flat at their lowest level and cannot wash a load of clothes due to the shaking vibration and banging around of the unit.
GE thats rare///Is the unit solid frount to back corner to corner can;t be any movement there at all///more inportant to be solid then level grab corner of machine and see if there is any movement from rear corner left to front corner right and then the other side also are the shipping bolts and spacers 4 removed from the rear of unit..hope this helped.....good luck if I helped you please vote
Feb 06, 2011 | General Electric WCVH6800J Front Load...
My Frigidaire Affinity dryer has started vibrating more and more during operation. Is the motor going bad or is there another problem?
Hi
Try the following to reduce the noise--
Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor.
• Shipping bolts and foam blocks have not been removed during installation. Check out the installation instructions for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please post back for any further assistance.
Daniel
Jul 24, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Washer shakes bad
You probably have already checked this but since you do not say.........
Is the unit solid and level on the floor........with the leveling legs turned down as low as possible with the lock nuts tight.......?
If you put a glass of water on the dryer next to the washer, can you see the water vibrating when the washer is in spin? You may have weak floors.........Cement floor is the best floor, after that you need to check........
You do not say there is any noise, is the unit walking on the floor?
When new and installing there are shipping bolts and or straps to remove before using......
good luck,
enjoy the weather
Mar 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
WE recently purchased a front loading Frigidaire washer. I love it except we can't seem to get it level so it doesn't vibrate. It is on a concrete floor and thought the feet were self leveling but that's...
Make sure you have removed all the shipping bolts and straps. Front loaders come with bolts that go thru the back to keep the drum from moving during shipping. If you brought the washer home yourselves you may have left in these shipping bolts. Refer to you installation manual. It will give detailed instructions on how to set up your washer. If bolts are left in place the washer will vibrate and shake excessively and cause major damage if left in for too long.
Feb 03, 2010 | Frigidaire GLTF1670A Front Load Washer
Vibration during spin cycle - "walking" across floor
dear sir/mam
please check the floor level of your washer by using the spirit level,if there is difference please adjust the level by screwing the legs of the washer,then vibration will be stopped.
Jun 01, 2009 | Whirlpool Inglis IP4400 Washer
Front load washer- spin cycle is like a hurricane
be sure all the shipping materials have been removed ..next adj all feet up as close to bottom of washer as possible ..try rocking machine ..if movement detected adj only foot necessry to firm up washer ..still have vibration suspect floor ..front washers need a good SOLID floor
Aug 16, 2008 | Washing Machines
Whirlpool duet sport..vibrates during spin and "walks"..on pedistal.sitting on tile
I just bought this washer and had two problems with it. 1 the vibration at medium spins and 2. a squeeking spring (every time the drum rotates a little squeek, but when spinning the squeek sounds constant.
What I discover in solving both my problems with the same solution. I had to ensure all 4 feet well on the ground and that the top of the washer was perfectly level. At one time I was out only about 2 mm on one side, but the bubble was slightly to one side on the level but still in between the level's markers. I tested with a load, and both problems were still there. Turn feet 1/2 turn on the side needing adjusting. Ran another load and you guessed it, no squeak, no vibration, spinning was quiet, I had to go over to check to see if the machine was going through the cycles. I couldn't believe that a few millimeters could make such a difference.
Now I am pleased with the performance, not to mention how clean the clothes are and the savings on water and drying.
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
