Question about Onkyo Audio Players & Recorders
My pro remote will not operate the receiver. It was working earlier was dusting the receiver and may have press one of the buttons on the receiver
  • Official Brand Answer
  • 333 Answers
Hi Torin, if this has not been resolved please email me the units model number so that I can be of better assistance, you can email me at askOnkyo@us.onkyo.com, Thanks, JT
Posted on Jul 31, 2015
3 Suggested Answers
SOURCE: The pioneer remote receiver VSX 097 stop working
can i hook a avr2500 to a avr589 with the preouts and use the power from the 2500 like it was a amp
Posted on Feb 12, 2009
  • 336 Answers
SOURCE: Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Posted on Feb 13, 2009
Can't get any sound
Remove the batteries from the remote. Press all the buttons on the remote to eliminate the possibility of a stuck one. Reinstall the batteries and test operation.
Jun 20, 2016 | Yamaha RX-V995 Receiver
Remote not working...
Remove the batteries. Press all the buttons to eliminate a stuck button as the problem. Reinstall the batteries or install new batteries. Check remote operation.
May 18, 2013 | Denon AVR-2807 Receiver
My pioneer pro 1140hd elite remote is not functioning. A spare remote doesnt' work either so it must be the tv itself. How to fix?
If the remotes have both been tested (shops can check with a tester all buttons) you may have a remote receiver in the set that is bad--some the remote will not work or only works with remote very close to set.
Many digital cameras in a very dark room will react the same way when a remote is pointed at them and buttons pressed---a faint flash on the camera display.
Dec 03, 2012 | Televison & Video
My remote is fine, but i don't know which button to push or sequence once I've changed batteries to for it to work the receiver. Each time I change the batteries it doesn't interact with the receiver, but...
It's likely that you've pressed one of the input mode buttons accidentally while changing the batteries. You've probably switched the remote for operation of a TV or DVD player or some other device.
To correct this problem, simply press the RECEIVER (TAPE/AMP) button once, then try the remote again. Pressing this button informs the remote that you wish to operate the receiver with it again. The RECEIVER button is about halfway down the left-hand side, above the TV button and below MACRO 1.
Please try this first. If the receiver still does not respond, switch the receiver off and back on again. It may have lost the communication with the remote. Resetting the receiver will usually correct this problem.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric.
Feb 26, 2011 | Onkyo TX-SR703 Receiver
Remote control stopped working.
Hi forlillis,
1. Make sure there are fresh batteries in the remote, and they are installed correctly.
2. Make sure the area between the remote control and receiver is not blocked by some object,
and the distance is no more than 15 feet at an angle no greater than 30 degrees from the
front of the receiver.
3. Make sure strong lighting is not directed towards the IR sensor of the receiver.
4. Press each button on the remote and verify proper operation.
If these steps are taken and remote control still does not function properly
5. This step discharges the capacitor and resets the remote control. (You do not need to point
the remote control at the receiver or even have the receiver turned on.)
A: AVR35  Press the TV and the M4 buttons at the same time and hold for 12 seconds.
To Test: Make sure your AVR35 is ON, press each button on the remote and verify
proper operation of your receiver.
Let me know how it went.
lykohavi
Aug 05, 2010 | Harman Kardon AVR 35 Receiver
Dish network control not working on 2nd. tv
You have a dual receiver and 2 remotes. make sure that receiver is in dual mode. That you press the sat key on remote 2 if it will still not operate take remote 2 to the receiver. With remote #1 press the menu button twice you should then be on they system info screen. Pick up remote #2 press and hold sat key until it blinks press record 3 times . press red power button and if tv2 light goes off and on the remote should work again for tv2 . Use remote #1 press select exit screen,
Jun 02, 2010 | DISH Network IR Remote Control
Since our neighbors got DishNetwork our second TV randomly changes channels. Can I program to a different frequency?
this is due to a " remote war" you will need to cahnge your tv remote adress to a differnt number: Dual-Tuner receivers can have the same remote address for both, but ONLY if one remote is IR and the other is UHF.
Note: If you start this procedure and at any time do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Other UHF and UHF Pro receivers should be powered off before beginning.
  1. Verify the remote is a DISH Network remote. Look for the DISH Network logo on the bottom of the remote and Mode buttons or lights at the top. Why?
      We have the codes for all DISH Network remotes and would be happy to help you with your DISH Network manufactured remote. Please contact the manufacturer of your remote for further assistance. Detailed instructions may be included in the owners' manual that came with your equipment. If not, there may be a toll-free technical support number listed.
  2. If using a remote with Indicator Tab (3.0, 4.0, 5.0, 5.2, 5.3, 6.0, 6.2, 6.3) verify the Tab is configured for the correct receiver operation. How to?
    Green Indicator Tab with a green 1 Green Indicator Tab with a black 1 Green Indicator Tab with a green 1 UHF Blue Indicator Tab Black Indicator Tab Silver Indicator Tab IR UHF Pro Only UHF Pro Only UHF Pro Only UHF & IR UHF Pro Only 522, 625, 942
    TV1 942 only
    TV 522, 625 only
    TV1 522, 625, 942
    TV2 501, 508, 510, 721 381, 811, 921
      Reconfigure Remote
      1. Remove battery cover.
      2. Confirm remote is configurable. Note: if remote label says "IR", it can NOT be reconfigured.
      3. Place thumb nail between the colored piece, above the number, and the body of the remote. Pull down towards the bottom of the remote.
      4. Turn colored piece over to desired format and reinsert until a "snap" is heard.
      5. Replace battery cover.
  3. With the receiver on, press the Info or System Info button on the front panel,
    if not present remove the Smart Card and wait 5-10 sec,
    if no Smart Card power the receiver off from the front panel and press the up or down arrow button.
    System info will appear on screen. (This procedure is not applicable for the DISHPlayer or the DishDVR 721)
  4. Press and hold the SAT button (about six seconds) until all mode button backlights come on, then release.
  5. Use the number buttons to enter a number from 1 to 15. The light will blink off after each digit is entered and then return to a steady light.
  6. Press the POUND (#) button. If the code entered is valid for the remote, the SAT mode light flashes three times.
  7. Press the Record button. The number in the Remote Address field should match the one you input.
  8. To verify the code, press and hold the SAT mode button until the mode lights come on. Then press the POUND (#) button twice. The light will flash the address.
  9. Reinsert Smart Card
Sep 24, 2009 | DISH Network DVR-625 DTV Receiver /...
Remote Code
We would be happy to help you with getting your DISH Networkremote to control your LG REAR PRO. Pressand hold the TV button located on the top of your remote until all mode buttonback lights come on, then release. Use the number buttons to enter thecodes for your LG TV; here some of the codes we currently have: 506, 520, 627, 581, 766, and 512.Press the pound (#) button. To check that the code works try several differentfunctions on the remote to make sure it will properly operate the TV. Keep inmind that some codes may not be compatible with your equipment. If this is thecase, please try the other codes listed for that device until you find one thatis compatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
May 30, 2009 | DISH Network ViP 211 DTV Receiver
No response from remote
Hi on my ONKYO amp i have to press the receiver button to work most features if you press the volume button and this dose not light up the remote is trying to work something other than the amp,eg if the dvd button lights up it is working your dvd player if you have it set for this.PRESS the receiver button and it should work.
hope this helps.
CABLE GUY.
Jul 12, 2008 | Onkyo TX-NR801 Receiver
Dish network remote
i would suggest trying power scan again...
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
63 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
