This article is about two printer error codes, 22551 and 22531. These codes are associated with the OCE Plotwave 345 printer. The error code 22551 means that the printer has lost its connection to the computer, and the error code 22531 means that there is a communication problem between the printer and the computer.
This error 22524 could be as simple as a fuse on the Distribution PBA. If you replace it, ensure that it is the EXACT match. Not using the EXACT match may cause further damage to your system. If all the fuses are intact on the Distribution PBA, it could be the Distribution PBA, itself, the 48V power supply, or the I/O PBA. In that case, call an authorized Oce/Canon service representative.
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
This machine has a battery. When the machine keeps turned off and no conectec with the eletricity, the baterry cant charge and the machine lost de parameters.
The solution is reinstall the machine.
I have one machine stopped with this problem, but I cant find the instalationmanual to solve the problem. If somebody has...
Output OP paper rejection roller drive malfunction.Try to reset the malfunction code to Open/close the front door.If not reset: Turn OFF the copier. Press and keep pressed the Utility key and turn On the copier. Keep pressed the Utility key and wait while Trouble reset message displayed. Release the Utility key and touch the message. Turn OFF the copier ,wait 1 minutes and turn ON.
EE Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
