Question about Konica Minolta Office Equipment & Supplies
How do I replace the fusing unit in Konica Minolta bizhub C253
I want to replace the fusing unit in Konica Minolta bizhub C253
  • Konica Minolta Master
  • 6,680 Answers
POWER OFF MACHINE! Open the front door remove one screw from the small access UPPER RIGHT cover disconnect the three connectors two carry 120 VAC other sensor signals the open the right side of the machine two screws below the fuser and remove the unit. reinstall opposite direction. Be careful not to brake the sensor connector
Posted on Dec 27, 2015
djklermund
  • 3 Answers
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
Posted on Oct 18, 2009
  • 158 Answers
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Posted on Nov 16, 2009
Bizhubman
  • 108 Answers
SOURCE: how to clear error code c 3421 on konica bizhub
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
Posted on May 19, 2010
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
How do i re-set fuser unit replacement message on bizhub c253
SIR/MAM
TROUBLE RESET
FIRST, If this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
Jun 27, 2016 | Konica Minolta Bizhub C253 Copier
Konica minolta bizhub C253 is showing me trouble code C- 2556. What should I do to pix this problem
Konica-Minolta bizhub C253 Trouble Error Codes List page 4
Code C2556
Abnormally high toner density detected yellow TCR sensor
• TC ratio in the developing machine, which is determined by toner replenishing amount control mechanism, is 11 % or more for a given number of times consecutively. • When the connector of the TCR sensor is disconnected.
Solution:
1 Reinstall imaging unit. 2 Reinstall toner cartridge. 3 M3, M4 operation check (At this time, IU must be non-installation.). 4 Change imaging unit. 5 Change PRCB
Extract from:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C253&page=4
Nov 14, 2015 | Konica Minolta Office Equipment & Supplies
Door stack on konica minolta c 253
Did some one install a new unit such as a transfer belt or transfer roller? Or a fusing unit? Recommend a technician look at it unless you want to yank it open and do some more damage?
Sep 01, 2014 | Konica Minolta Bizhub C253 Copier
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Konica Minolta Minolta Bizhub C253 Copier
What s error code c-2554 of konica minolta bizhub c253?
C 2554 Abnormally high toner density detected Magenta TCR sensor.
Clean the TCR sensor window on the underside of the imaging unit if dirty,reinstall imaging unit or change imaging unit.
Aug 06, 2013 | Konica Minolta Bizhub C253 Copier
How do I clear error message C-2558 for the Konica Minolta bizhub C253
As the Installation Manual and Imaging Unit replacement instructions mention, pay close attention to shaking the Imaging unit properly to level the toner and also keeping the Imaging unit level when installing it into the machine
Jan 24, 2011 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C253 - Displaying status on a webpage
the hp web jetadmin is quite good, it displays whatever info you select. use version 10.2
Mar 31, 2010 | Konica Minolta bizhub C250 All-In-One...
76 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
