Question about GE Washing Machines
My GE Washer has no power. There is power at the wall. The schematic shows an internal fuse on the Red White RW wire. Can't find the fuse.
High Eff. Top Loader Mod WHRE5550K2WW We had a nearby lightning strike and the washer hasn't worked since. I can't see any damage to the PCB or internal wiring. Nothing else was effected. A breaker was tripped but not on this circuit. Is the fuse part of some other component? UPDATE: I bypassed the door magnetic switch. NO HELP! I found and jumpered the A/C Fuse: NO HELP! Tried holding down the ON/PAUSE button as suggested with rotation of load knob. NO HELP! Am out of ideas.
  • GE Master
  • 5,323 Answers
The fuse is usually located inside the panel but sometimes elsewhere? along the back side coverd by a plate
Posted on Apr 11, 2015
JTP56 Electric Double Oven Dead after self-clean. Power Pigtail comes into back of top control enclosure in flex conduit. The three red,black,white conductors are spliced to 2 molex connectors. I am...
I doubt there is a fuse on the pigtail, it sounds like your black wire is grounded somewhere. Check black to red, if you get 120 or close to it, your black is shorted to ground.
Jun 07, 2011 | GE Profile JTP56 Electric Double Oven
My front load GE washer would not drain . balance looks fine. pulling the power source and replugging did not help WCVH6800J1WW Serial IS205695T -
if this washer has a control board on top of motor try opening the lid six times within 6 seconds... then start washer .... if it does have board ontop of motor look at board is green indicator lit up if not replace fuse link white wire with red line threw it from motor has a one time fuse link in wire replace fuse link or jump across to test
Jan 24, 2011 | GE WJSR2070B Top Load Washer
I the manual wiring doesn't match what I have in the switch box. This switch is to operate 2 outside porch lights., previously wired to a single pole switch as follows.. one black wire to one screw and 2...
I test these timers.
GE 15071 timer has internal clock that runs on electricity. That's why timer has extra wire.
Intermatic, GE, Tork, Leviton, Sylvania, Woods, Utilitec etc in-wall timers each wire the same way.
The only tiny difference is GE doesn't have green ground wire.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Here's what to do:
1) Old switch has two screws (excluding green ground screw)
One screw on old switch has 2 black wires >> these are hot wires > timer black wire connects to these hot wires. This will power the timer.
2) The other switch wire connects to timer red wire. This will send timer signal to lights.
3) Timer white wire is for the timer clock.
Timer white wire connects to other white wires that are twisted together and covered with wire nut >>> these are neutral wires, and now timer clock will operate
4) For EZ connection to other white wires, strip back another inch on timer white wire so stranded wire can wrap like a candy cane around solid copper wires. Then twist wire nut on very tight.
5) When wiring is complete, push door on timer for manual override. Lights should turn ON-OFF. If lights do not turn on, reverse timer red and timer black wires. Make sure outdoor bulbs are working.
Add a comment any time
Dec 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
15265 In-Wall Digital Timer - I am replacing an Aube with this new timer. Timer is to operate a wall plug (outdoor soffit). Timer is inside. The old switch had 3 wires - only two were connected (I think...
GE -15265 manual
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
Ah, the usual how to connect 4 wires to the old 'was-3-wire and now-2-wire' problem.
I tested and wired these timers.
Aube timer has internal rechargeable battery, and therefore does not need another wire to run internal clock.
GE timer has extra wire to run internal electronic clock, just like alarm clock is plugged in.
Heres what to do in simple format
1) Timer-green-wire connects to bare ground wire.
2) Old timer has 2 wires. Take both wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This action will complete circuit to internal clock.
4) If electric box does not have white wires described above, then connect timer-white to bare ground. This works because bare ground and white neutral both connect to neutral busbar inside breaker box.
5) Turn on electricity, push in timer door for manual override. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
If light does not come on, double check that outdoor bulb is good, and that breaker not tripped.
Timer can also be reset in event of short. Reversing red and black wires will not short timer.
Add a comment of you need more help
http://waterheatertimer.org/See-inside-main-breaker-box.html
Nov 30, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Am replacing an old wall timer with a GE Smart Digital Timer. The old timer had two black wires connected to two black wires from the wall. The new timer however has red, black, white and green wires. I...
I've tested these timers.
Here's what to do:
1) Connect green to bare copper
2) Switch has 2 wires. For now, connect these two wires to timer-black and timer-red. Choose either one.
3) In back of wall box are white neutral wires twisted together and covered with wire nut. Timer-white wire connects to these white neutral wires. This action gives power to time clock.
4) If wall box does not have white neutrals described above, then connect timer-white to bare ground wire. Bare ground connects to neutral busbar in breaker box.
5) Turn on power and click manual override button or switch. If lights turn on, timer is wired correctly. If lights do not turn on, then reverse timer-red and timer-black wires.
Nov 16, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Hello sir i am sasi from india pls tel me international color codes electrical wiring
Well colors can vary, but basically bare copper or green are grounds, white is the neutral wire (but it is powered in a switch loop, and when used in a switch loop it is taped with a piece of electrical tape to show it is powered). Black, red, blue, brown, and pretty much any other color except green and white can be a power wire (black red and blue are the most common colors used).
May 26, 2010 | General Electric GE ELECTRICAL TQD22200X2...
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
My GE 7-Day Digital Timer model 15086 flashes on
I just bought one today and installed it. It does the same thing - flashes the lights off and on. After some research on the net, it seems that the problem is that an old house is wired with two pole wiring and the new fixtures, (timers included) are 3 pole. The conclusion I have found is that it will not work in a 2 pole wired house. There supposedlly are timers available for 2 pole wiring. I hope this helps. If you find out anything different, please let me know.
Oct 17, 2009 | Hardware & Accessories
Washing Machines Logo
93 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
