Clothes not getting clean
Not wet or clean when finished
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check inlet valve
Posted on Apr 13, 2015
Bosch maxx Classic. 7 yo. Washing cycles are not finishing. Timer is showing 1 but does not turn off. Clothes are still quite wet. Have cleaned filter. Anything else I can do?
Looks like the solenoid that controls the drain motor is malfunctioning.
Whenever this happens, the water does not get drained fully and remains in the chamber thus keeping the clothes still wet.
Speak to your local service representative and get the part replaced.
Feb 22, 2015 | Bosch Washing Machines
Spin cycle
moduel or triack motor controler
Aug 12, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Xbox360 not reading disc and continues to open
Disk cleaning
If your disk is unreadable, skipping, or is slow in playback, it may just be be dirty. Even if your disk has a few scratches, a little bit of cleaning may be all it takes to make it good as new.
Required tools:
  • Microfiber Cloth
  • 85% Rubbing Alcohol
Process:
(1) Get a nice clean cloth, preferably a micro fiber cloth. Silk should also work fine. Avoid using a Kleenex, paper towel, or cotton cloth, as it may scratch your disk. Micro fiber clothes are available at most grocery stores, but if you can't find one, pick one up at any place that sells glasses.
Rubbing alcohol can be obtained at any pharmacy and 75% should still work fine. The higher concentration does work a little better, but the difference isn't substantial. Don't substitute rubbing alcohol with Windex or other solvents, as they may damage the reflective coating on the disk.
(2) Wet the cloth at one edge with rubbing alcohol. This is best achieved by plugging up one end of the alcohol bottle with a part of the cloth, flipping the bottle over, and letting the cloth soak for a bit before flipping it back over. If done properly there, shouldn't be much alcohol spilled.
(3) Hold the disk firmly in one hand in-between your thumb and middle finger. Use the thumb of your other hand to apply pressure though the wet area of the cloth to the disk and move the cloth in and out from the center of the disk to the edge and back again. Use the index finger of the hand you are holding the disc with to support the non data side so you can apply more pressure. It may take a few tries to find a comfortable position. Continue to work the wet cloth out from the center of the disk toward the edges until you're satisfied, or until you find a spot you can't seem to get.
If you find a particularly bad spot that has a lot of dirt or grime that you just can't seem get, try getting it wet by re-wetting the cloth and allowing the area to absorb the alcohol. If that still doesn't help, apply more pressure by using the tip of your thumb or your nail on the cloth when you're rubbing the area. Be careful when using your nail as, you may cut through the fibers of the cloth and end up scratching the disk. You should never touch the data side of the disk with anything except the micro fiber cloth.
(4) Once you've finished with the wet part of the cloth, use the dry part of it. Again, use your thumb to work the cloth in and out from the center to the disk to the edge. This is mostly cosmetic and you can skip this step.
(5) Allow the disk to dry for one to two minutes and you should be done.
Nov 21, 2010 | Microsoft Xbox 360 Console
What do i clean the screen with?
Cleaning is simple. Vacuum the rear vents to remove any dust that has built up.
For screen and the fascia, -
1. Unplug the monitor from the power supply.
2. Fill a bowl with warm water with some washing up liquid - just as you would to clean dirty dishes. Soak a soft clean cloth in the water (Kitchen cloth - NONE ABRASIVE!! and not a sponge!), and wring the cloth out so that it is damp (not wet!) and gently wash the screen. When finished use kitchen roll to dry off the monitor.
3. Stubborn marks on the LCD, using the same damp cloth, apply a spot of neat washing up liquid to the cloth. Clean as before - DO NOT PRESS on screen. When finished, use kitchen roll as before.
Voila!
May 14, 2010 | Acer 22" X223w LCD Monitor
Scratched Finish on Screen While Cleaning
Here are some solutions to consider. Try in an inconspicuous place first.
1) Use a clean WHITE pencil eraser. Yes WHITE pencil eraser. Some people use a pink eraser and then a white eraser over that for faster removal. Wipe residue off with a damp cloth.
2) Use White Petroleum Vaseline Jelly over the stratches. This may have to stay on an hour before wiping off.
3)You may also get commercial LCD scratch removers on the 'net.
An LCD screen should only be cleaned by using a damp(not wet) with water microfine cloth. Never use household cleaners of any kind.
Mar 13, 2009 | Sony Televison & Video
Some clothes not clean or even completely wet after wash cycle finished
Ebay item number 200262803398 is a cheap PDF service manual for this model.
prem
Oct 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes are still sopping wet when finished
If your clothes are wet after the wash it is quite possible your outlet filter is blocked. Check this out and clean out. This requires periodic cleaning, according to your usage. Refer to your user manual.
Aug 28, 2007 | Malber WD1000 Front Load Washer/Dryer
Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
Jun 10, 2007 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
