Question about Poulan Garden
Starts and runs for 4min and dies, wont restart. entire fuel system has been replaced or rebuilt. replaced coil. still the same? what can I do to fix
  • 2,160 Answers
Check fuel line, tank, filter
Posted on Apr 11, 2015
86 4.3 4BC 1500 Chevy Die rolling up to light Started up and ch of fuel and it died 3 times now no start smell fuel and quit yellow spark Have replaced cap rotor plugs wires EGR coil ECM Rebuilt carb
It sounds more like a fuel problem to me then a bad coil or spark ign the spark should be blue but its hard to see in daylight
You say you rebuilt the carb are you sure your main mixture jets are at least 2 to 3 turns out off the stops .
Try pouring fuel down the barrel fill the float bowl if it runs then dies its fuel don't let it catch unfire you should have 45 sec. of run time then adjust the the mixture screws 2 turns is base but when its is running good turn them in 1 at a time and give it 30 sec. to adjust until it starts to stumble then back it out a 1/4 two 1/2 turn then repeat on bank 2
Nov 23, 2016 | Chevrolet Cars & Trucks
I need help !!!!!!!! I have a 2000 ford focus that was running good and while driving it just turned off and wont restart. I have checked the entire fuel system and everything seems to be in good work
Try to reset the inertia switch. It is usually around the front kickpanel and has a reset button on it. If that does not help, use a little starting fluid to see if it will run a bit. What the starting fluid will tell you is if you have fuel problems. If it runs or fires with starting fluid then the spark side is working and you can concentrate on a injector or fuelpump problem.
Feb 16, 2015 | 2000 Ford Focus
Toro Timecutter 14.38Z Model 74301 Briggs & Stratton Engine Model 280H07-0166-E1 Has NIKKI carb Starts & runs for ~ 15 minutes then stops. Will restart after 5 minutes rest and run...
Recheck spark when the unit cuts out. I am gonna guess you spent a lto of money chasing a bad coil! When a coil starts to go bad they become temperature sensitive. Time does the rest!
Dec 27, 2012 | Garden
Husqvarna 455 rancher Starts fine and runs great for about 5 mins. Stalls and wont restart until cold. Problem than repeats
Try removing the fuel cap for a moment to see it can be restarted immediately. If this works, check the fuel tank vent for plugging problems. Also, check for spark at the plug when it dies--if no spark, try a fresh plug gapped at 0.020". If nothing, the ignition module may be failing with heat. Good luck!
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I AM RESTORING A T020 MF. I REPLACED ALL WIRING AND IGNITION SYSTEM AND REBUILT THE CARBURATOR, AND ADJUSTED IT TO SPECS. I GOT IT TO START RIGHT AWAY AND IT SOUNDS GREAT. HOWEVER, IT WILL ONLY RUN FOR...
Ok a quick check. When the engine cuts out and you go for restart it dies within 5 seconds. Next time put the ignition at position 2 (on but not starting) and wait one minute, then start the car. If the engine again runs for 30 seconds before cutting off this tells you its is a fuel problem. If the fuel is supplied slowly it fills the carburettor fuel bowls and when the car starts it quickly uses up these local reservoirs of fuel faster than they can be replenished. When you try to restart immediately there is only a tiny amount of fuel and so it used up almost immediately. By leaving the ignition on 2 for while it gives the pump time to fill the carburettor bowls and this takes a while longer to run down when the engine starts. Just before moving on does the car have a choke OK remove the low tension connection to the coil, basically remove any chance of a spark. Put a big old towel around the carb. Now remove the fuel line at the carburettor and put ignition on 2 to engage the starter pump. Listen to pump operation and look at the rate of fuel being pushed from the disconnected fuel pipe. If the flow is slow check on pump and filters.
Sep 13, 2010 | Ford F-100 Cars & Trucks
Chainsaw wont stay running
check crankshaft seals,maybe sucking air. most of the time the seal on the starter side. hope this helps.
Jul 09, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
